RadioDataSystem
EnoSat
Would it be possible to add the display of RDS data from the stream to TranEdit?
etc. as some box
A RDS Analyzer would be nice, but programming it would be quite time-consuming. Unfortunately looking after DVBViewer Pro and the Media Server occupies most of my time, so that there is only little time left for TransEdit.
Currently new features are only added to TransEdit, if they are needed as tool for DVBViewer development. I can't fulfil user requests anymore, except little ones that don't require more than one hour of work.
However, DVBViewer is able to display the radio text of your MPEG Audio stream in its OSD. I've just tried. See Settings -> Options -> TV/Radio -> Show radio text.
  • Thanks 1
