eXtremeDevil Posted June 9, 2023 Posted June 9, 2023 Hi. I'm using the DVBViewer controller app for android and I've noticed that I can't delete recordings or list tasks. Now, I know that those functions should not work with DMS Basic, but, I've seen a couple of thing that makes make wonder if those functions would really work with the paid version of DMS. 1 - The app hasn't been updated since 2020, so maybe some things have changed on the DMS end and the app can no longer access to it, regardless of the free or paid DMS version. 2 - When trying to listing tasks, the app fails with the message "HTTP Code: 404 when accessing url: XXXXXXXX/api/tasks.html?all=0 I've tried the XXXXXXXX/api/tasks.html?all=0 address on the local machine when DMS is running and it is indeed not found. So my question is, even with the DMS paid version, would the tasks option work on the app? Or has this been outdated? And what about the recordings deletion, also within the app? Thanks in advance. Quote
Griga Posted June 10, 2023 Posted June 10, 2023 On 6/9/2023 at 11:21 AM, eXtremeDevil said: The app hasn't been updated since 2020, so maybe some things have changed on the DMS end and the app can no longer access to it, regardless of the free or paid DMS version. The API used by add-ons is carefully kept compatible. On 6/9/2023 at 11:21 AM, eXtremeDevil said: When trying to listing tasks, the app fails with the message "HTTP Code: 404 when accessing url: XXXXXXXX/api/tasks.html?all=0 Since tasks are security relevant, the Media Server does not allow to read or change them with guest rights. Please read more about the Media Server Basic resrictions here. On 6/9/2023 at 11:21 AM, eXtremeDevil said: with the DMS paid version, would the tasks option work on the app? Yes. Quote
eXtremeDevil Posted June 12, 2023 Author Posted June 12, 2023 (edited) On 6/10/2023 at 3:55 PM, Griga said: Since tasks are security relevant, the Media Server does not allow to read or change them with guest rights. Please read more about the Media Server Basic resrictions here. I know, but as I said, I tried that api URL on the machine the server is running and it was also 404, is that normal as well? Edited June 12, 2023 by eXtremeDevil Quote
Griga Posted June 12, 2023 Posted June 12, 2023 2 hours ago, eXtremeDevil said: I tried that api URL on the machine the server is running and it was also 404, is that normal as well? It is normal if you are using the Basic version, because it only allows API access with guest rights. Quote
eXtremeDevil Posted June 12, 2023 Author Posted June 12, 2023 I see, although I would have expected a 403 forbidden instead of a 404 not found. Thanks! Quote
