bogdan29 Posted December 25, 2023 Posted December 25, 2023 (edited) I want to buy a new internal PCIe tv tuner card.The name of the card is DVBSky T9580 DVB-T/T2/C and DVB-S2 Dual PCIe .Someone can tell me something about this card,if is good or not?I want to replace my old tv tuner just because my old technotrend is on PCI and this new is on PCIe,and with this ocassion i don't need anymore riser card... http://dvbsky.net/Products_T9580.html thanks, Edited December 25, 2023 by bogdan29 Quote
Griga Posted December 26, 2023 Posted December 26, 2023 8 hours ago, bogdan29 said: Someone can tell me something about this card,if is good or not? Search with Google for site:dvbviewer.tv DVBSky T9580 to find reports about it (and use Google translation for German posts). Though the DVBSky site is still online, the company does not exist anymore since several years, as far as I know. It will be difficult to find a shop that still sells the T9580. Even if you find one, don't expect driver updates in the future. Quote
bogdan29 Posted December 26, 2023 Author Posted December 26, 2023 (edited) so the TBS is a better choice? DVbSky still have support from what i see http://dvbsky.net/Support_win.html Edited December 26, 2023 by bogdan29 Quote
Griga Posted December 26, 2023 Posted December 26, 2023 2 hours ago, bogdan29 said: so the TBS is a better choice? TBS may be ok, as long as you are not using a CI/CAM for decryption. Many users experienced instabilities with the TBS CI/CAM DLL , including me 2 hours ago, bogdan29 said: DVbSky still have support from what i see Have a look at the driver dates. The latest for Windows 10 are from 2018. There are no later releases. Neverthelesss DVBSky devices and drivers are running pretty well with DVBViewer under Windows 10. At least a DVBSky S960C does here. However, problems may come up in future with Windows 11, who knows... 1 Quote
bogdan29 Posted December 26, 2023 Author Posted December 26, 2023 (edited) yes for windows 11 i am 100% sure will not work,but my system is not ready for win 11 and windows 11 as far as i know is a killer resource☺️ I ordered this model of DVBSky tuner, I hope all will be fine.Only thing i don't like is have +12V molex https://imgur.com/a/PfWjd9W Edited December 26, 2023 by bogdan29 Quote
Webturtle Posted December 27, 2023 Posted December 27, 2023 Hello, for the use under W11 look here: https://www.DVBViewer.tv/forum/topic/68648-tv-karten-treiber-für-win11/?do=findComment&comment=512784 . Quick translatiion by Google: Spoiler Hello, I just installed my old DVBSky S950C in my Windows 11 23H2 computer after not using it for a long time, installed the Windows 10 drivers from http://dvbsky.net/Support_win.html and DVBViewer and everything worked straight away including CI and ORF, The Windows 11 core isolation is also still intact, older drivers often cause problems here. I hope this message helps a little.. LG Thomas Many greetings Webturtle 1 Quote
bogdan29 Posted December 28, 2023 Author Posted December 28, 2023 I installed right now this tuner dvbsky 9580 and with this it seems is working properly.With my old Technotrend c1501 i had problem and i m sure the problem was on riser not card it self. I installed latest 2018 driver and in win 10 is working perfectly,don't know if win 11 is accepted. https://imgur.com/a/7S9bM5a 1 Quote
Frankobert Posted December 28, 2023 Posted December 28, 2023 I own the DVBSky T9580 DVB-T/T2/C and DVB-S2 Dual PCIe since a couple of years and I use it for DVB S2 and DVB T2 in Germany with no problems on my Windows 11 system with driver win10drv_180820. 1 Quote
bogdan29 Posted December 29, 2023 Author Posted December 29, 2023 is a good product from what i see🙂 Quote
bogdan29 Posted January 2, 2024 Author Posted January 2, 2024 (edited) i installed clean windows and i try to download driver for DVBSKy 9580 driver from http://dvbsky.net/Support_win.html .And support driver is no available anymore.Their site is shutting down.404 not found😐 Someone can help me with dvbsky 9580 driver support please? Edited January 2, 2024 by bogdan29 Quote
Griga Posted January 2, 2024 Posted January 2, 2024 It was quite clear that this site would be switched off sooner or later, so I've downloaded all the drivers and made a backup For Windows 10: https://www.dvbviewer.com/griga/DVBSky_Driver/win10drv_180820.zip Filenames for earlier Windows versions see https://www.dvbviewer.com/griga/DVBSky_Driver/DVBSky_Driver.txt 1 1 Quote
Webturtle Posted January 2, 2024 Posted January 2, 2024 (edited) Hallo, auf der Wayback Machine ist die Seite noch zu finden: https://archive.org/web/ und dort als Suchbegriff http://dvbsky.net/Support_win.html eingeben. Für den S 960 habe ich es gerade mal probiert und der Download hat funktioniert. Viele Grüße Webturtle Addendum Hello, sorry, I missed that. The page can still be found on the Wayback Machine: https://archive.org/web/ and enter http://dvbsky.net/Support_win.html as the search term. I just tried it for the S 960 and the download worked. Best regards Edited January 4, 2024 by Webturtle Addendum, Translation Quote
Griga Posted January 3, 2024 Posted January 3, 2024 @Webturtle This is the English part of the forum, so please post in English or, if you are not able to do it, use a Google translation! Quote
bogdan29 Posted January 3, 2024 Author Posted January 3, 2024 is web archived.I download driver for my 9580 to be sure in case this site will be closed too🥲 http://web.archive.org/web/20230207184832/dvbsky.net/Support_win.html Quote
bogdan29 Posted January 3, 2024 Author Posted January 3, 2024 23 hours ago, Griga said: It was quite clear that this site would be switched off sooner or later, so I've downloaded all the drivers and made a backup For Windows 10: https://www.DVBViewer.com/griga/DVBSky_Driver/win10drv_180820.zip Filenames for earlier Windows versions see https://www.DVBViewer.com/griga/DVBSky_Driver/DVBSky_Driver.txt thank you Griga 🥲 Quote
