DVBViewer don't close process in win XP.
dragon131
Hi, i observed that under win  XP. DVBViewer create the process DVBViewer.exe.
But It don't close It when you close DVBViewer.
The consecuente its, that apart of stay here eating  ram. Hbbtv don't work more if you reload DVBViewer until you  close manually the process with crtl+alt+supr.
Does it also happen without HbbTV add-on?
You can deactivate it temporarily by launching Tweaker.exe (see DVBViewer program directoy) and checking "Disable HbbTV". There is a similar setting for disabling MHEG-5, which is also provided by the add-on.
Tested:
It close ok with hbbtv+mheg-5 disabled.
It close ok with mheg-5 enabled +hbbtv disabled.
Don't close with mheg-5 disabled and hbbtv enabled.
Like you said.
Its is also cumulative, if you open/close DVBViewer 10 times, 10 process of DVBViewer.exe remain in ram.
Edited by dragon131
