Rico0612 Posted March 12, 2005 Posted March 12, 2005 ... as mpeg Audio Decoder. Worked fine with Version 2.2. Since I installed 3.0 I cant get it to work. My Receiver wont get the AC3 Signal either and shows PCM instead of Digital. Has someone a hint ? Thx in advance Rico Quote
Guest Lars_MQ Posted March 13, 2005 Posted March 13, 2005 Which version of the AC3 Filter do you use? maybe it needs an update. If I remember correctly there where some problems with older versions of this filter. Quote
Rico0612 Posted March 13, 2005 Author Posted March 13, 2005 Thanks for your reply Lars. If i remember correctly (cant look right now, iam working with the laptop) its a 1.0.5 Version. Its definitely not the 0.70b Version anymore. Its strange. As soon as I choose the AC Filter in the options the picture gets black but the sound stays. Guess I get back to Version 2.2 of DVBViewer for now. Tonights the big night as Spiderman goes HDTV on German Televison Pro7 Greetings Rico Quote
Guest Oliver Posted March 13, 2005 Posted March 13, 2005 Take a look at the graph with graphedit. Sometimes the AC3 decoder and another decoder are used simultaneously. In this case you must limit the AC3 decoder to AC3 decoding. Bye, Oliver Quote
