fast and high-quality MPEG2 transcoding
darkman
SolveigMM MPEG2 Requantizer Component.
SolveigMM MPEG2 Requantizer Component is an engine designed for a fast and quality recompression of MPEG-2 high bitrates video.
The component was implemented as DirectShow filter.One of its main purposes is a fast DVD back up.
The demo application inputs are MPEG-2 Video Elementary Stream, MPEG-2 Program Stream, DVD VOB files.
It splits video/audio streams, recompresses MPEG-2 VES in concordance with set compression ratio (picture 1) and writes audio/video streams to respective files.
Audio streams are dumped as is, without recompression.
Total audio/video files size is approximate size MPEG-2 or VOB of file containing these streams after multiplexing.
Such one can estimate potential VOB size decrease.
http://www.solveigmm.com/?Products&p=MPEG2Requant
Edited by darkman
  • 1 month later...
  • 2 months later...
Did You try it built in the graph (so to say as live-recording)?
How well did it work?
What are the limitations (as it's only a demo)?
How much is it (or is the direct show filter free)?
Thanx in advance.
Thanx in advance.
Hi Technofriend,
sure it operates within a graph while live-transcoding,recording.
If you need the requantizer API, you can either contact us at info(dog)solveigmm(dot)com or get the information here : http://forums.dvbowners.com/index.php?showtopic=3033
Best Regards,
Dmitry Vergeles
Thanx for your answer and the interesting forumlink. :bye:
