darkman Posted March 28, 2005 Posted March 28, 2005 (edited) There is an alfa version of SolveigMM ASF Multiplexer that is needed to be tested. http://www.solveigmm.com/files/SMMASF_2005_03_28.zip The muxer allows the user to multiplex any pre-compressed or raw audio/video streams (DIVX, H264,MPEG-2,WM, etc.). It takes to the input a video stream as framed structure (i.e. one DirectShow Sample has to contain an integer number of Video frames). Such a video structure is supported by most video encoders. Input audio/video samples has to have valid time stamps. As for H264, it only operates for the present with Moonlight H264 Encoder. In spite of Encoder mediatype the muxer wtites to an ASF file a mediatype with fourcc - AVC1. For operating SolveigMM ASF Muxer the Windows Media Format 9.0 Runtime has to be set up. There are DirectShow graph types the muxer can be tested within: File Source-> AVI Splitter [DivX]-> SolveigMM ASF Multiplexer ____________________[AC3]-> File Source-> MPEG2 Demuxer->MPEG2 Decoder->Moonlight H264 Encoder-> SolveigMM ASF Multiplexer __________________________[MPEG1]->--------------------------------------> etc... Any suggestions,notes, bug reports are really appreciated. __________________ Regards, Dmitry Vergheles Solveig Multimedia Edited March 28, 2005 by darkman Quote
darkman Posted April 6, 2005 Author Posted April 6, 2005 (edited) There is a new version being tested of SolveigMM ASF Multiplexer. http://www.solveigmm.com/files/SMMASF_2005_04_06.zip It has been improved operating with MPEG2 and H264 streams. Since there is still no an official mediasubtype for H264, the multiplexer allows an user to set mode - "Treat input video as H264" and disregarding an input subtype set one with own fourcc (AVC1,H264,X264,VSSH, etc). It is necessary to use it with various H264 decoder/encoders. __________________ Regards, Dmitry Vergheles Solveig Multimedia Edited April 6, 2005 by darkman Quote
darkman Posted April 21, 2005 Author Posted April 21, 2005 The new muxer verion being tested is available (2005.04.21) http://www.solveigmm.com/files/SMMASF_2005_04_21.zip there have been fixed some bugs, including quote: -------------------------------------------------------------------------------- x264 in avi,connect avi splitter stream00 to SMM multiplxer,if check "treat input as H264",ther result asf file can't play with mpc,if uncheck it,output asf can play with mpc. -------------------------------------------------------------------------------- There is no more restriction for a video to be frame based for H264 and MPEG-2. The muxer is able to receive H264 and MPEG-2 as a bitstream. This feature permits to use the muxer with MPEG-2 TS/PS demuxers directly. f.e. Src (MPEG-2 )->MPEG-2 dmx [vid] -> ASF Muxer Quote
darkman Posted June 3, 2005 Author Posted June 3, 2005 There is a new version being tested of SolveigMM ASF Multiplexer. http://solveigmm.com/files/SMMASF_2005_06_01.zip The archive also contains the muxer application Quote
