DVBViewer 3.1 released
Guest Lars_MQ
Guest Lars_MQ
Christian released the DVBViewer 3.1. As usual you can get it in the Membersarea.
DVBViewer V3.1
- added: Skystar1 CI support (100% Twinhan compatible model)
- added: default DVD subtitle and default language can be selected in DVD-Options
- added: DVD Speedcontrol with OSD-Left/Right
- added: Common Interface support incl. MMI Window
- added: EPG Filter for broadcasters with multiple event information languages
- added: graphless timeshift and recording
- added: Ability to call OSD-pages via sendmessage commands directly (useful for girder).
- added: more options inside the recorder window
- added: DVD: default subtitle and default language can be selected in DVD-Options
- added: DVDplayback: Added prev. + next chapter to contextmenu (OSD-Blue).
- added: General: Added ability to create custom home menus
- added: General: If a afterrec action is to be executed the user gets a 20 secs. warning so he can cancel the action.
- added: General: Middle Mousebutton opens OSD, if closed.
- added: General: On ending Mediaplayback last viewed channel is tuned
- added: General: Prev / Next in Playlist via remote/keyboard
- added: General: The "don't exit if recording in xx minutes" Option is also applied on afterrec actions.
- added: General: The sendmessage commands now works also with the OSD.
- added: General: TS and mpeg2 playback now can use the filesource -> replay recording while recording.
- added: Mediaplayback: Context menu where DVD-Subtitle and Language can be selected
- added: Mediaplayback: Context menu with media control
- added: Mediaplayback: Context menu with OSD-Blue
- added: Mediaplayback: OSD-Red in DVD-mode calls DVD-Menu
- added: OSD-EPG: EPG-Search for timeline, ChannelEPG and What's now EPG in context menu.
- added: OSD-Home: Context menu where DVD-subtitle and language can be selected
- added: OSD-Home: Context menu with media control
- added: OSD-Home: Context menu with OSD-Blue
- added: OSD-Home: OSD-Menuitem for disableAV
- added: OSD-Home: OSD-Red in DVD-mode calls DVD-Menu
- added: OSD-Home: OSD-Red now calls what's now window.
- added: OSD-Home: OSD-Yellow calls favourites menu in LiveTV mode.
- added: OSD-MiniEPG Skin: Added color markers to show which colorbutton shows which info.
- added: OSD-MiniEPG: OSD-Red calls the Timeline
- added: OSD-Musicoption "Assume yes on autoplay" of Audio-CDs to get rid of the dialogbox
- added: OSD-Musicoptions in OSD
- added: OSD-Musicoptions OSD skinfile
- added: OSD-Recordings: "Save info" menuitem added to popupmenu
- added: OSD-Teletext: OSD-Left / Right shows subpages (if available)
- added: OSD-Teletext: OSD-OK shows page 100
- added: OSD-Teletext: OSD-Up/Down switches pages up/down
- added: OSD-Teletext: The last page shown is remembered until a new channel is tuned.
- added: OSD-Timeline: Noon, Afternoon, Evening, late Evening as directjump via contextmenu
- added: OSD-Timeline: switch single/overview mode via contextmenu
- added: OSD-Timelineoptions in OSD for setting times of above mentioned
- added: OSD-Timelineoptions in OSD skinfile
- added: Recordingwindow: Added hint showing the complete timerinfo if mouse is over a timer.
- added: Recordingwindow: Added recordingtype to timerlist (single, repeating, instant).
- added: Recordingwindow: Added runningstatus to timerlist (waiting, recording, disabled).
- added: VCR: Ability to stop and change running VRP recordings (needs newest VRP).
- added: Zoomsettings: Recallable zoomsetting (0..3) added. Also to OSD-function-engine -> callable via OSD.
- added: OSD-Channels: If a recording is running only channels on the same transponder are shown.
- changed: DisableAV: Now uses the DVBViewersource mechanism.
- changed: General: Musicplayback isn't stopped anymore when starting a slideshow
- changed: General: Remote PowerOff calls normal or extended exit, configure it in Options/shutdown
- changed: General: When selecting exit while recording a dialogbox is show to confirm exit.
- changed: Mediaplayback: If playing a audio file OSD-Left/Right control the volume not speed.
- changed: Options: Optimized options applying for OSD (should be faster)
- changed: OSD-DetailEPG: Timeout now is always menu timeout
- changed: OSD-MiniEPG: closes also on OSD-OK
- changed: OSD-MiniEPG: Timeout only while switching channels
- changed: OSD-Timer: Color marker for status: red = recording, green = OK, Yellow = conflict, blue = disabled
- changed: OSD-Timer: Context menu item enable/disable Timer
- changed: OSD-Timer: now sorted by date
- changed: Recodingwindow: Defaultvalues for new timer if nothing is selected
- changed: Recordingwindow: The Channellist width can now be adjusted.
- changed: Timeshift: OSD-Left/Right now control the volume if watching a timeshift recording
- changed: VCR: Better integration of VRP-Plugin.
- changed: VCR: Disabling a running recording or canceling it doesn't trigger the after recaction anymore.
- changed: VCR: Instantrecording now use default recording action.
- changed: XML: Completely reworked xml-support, no need for MS-xml anymore.
- changed: Zoomsettings: Left/Top Offset now with smaller range (-500 .. 500) instead of -1000..1000.
- fixed: EPG-Window: programmed recordings didn't use default disableAV
- fixed: General: Channelswitching or starting mediafile caused only partial display of picture in htpcmode
- fixed: General: Create infofile was ignored
- fixed: General: Inputdialog didn't accepted Input
- fixed: General: Minor skinproblems
- fixed: General: Up/Downcontrol calculated wrong fontheight resulting in ugly display of recording dialog.
- fixed: General: Wrong medianame in Mediaview when file opened with filemenu
- fixed: Options: Weatheroptions: were not saved correctly
- fixed: OSD-ChannelEPG: If no valid Channel was tuned the window didn't show up.
- fixed: OSD-Cutout: when setting overscan values it wasn't positioned right
- fixed: OSD-Home: Menuscrolling only if menu is visible and mouse in scrollsensitive area.
- fixed: OSD-Musicplaylist: Clearing of Playlist didn't work
- fixed: OSD-Musicplaylist: Showing current playing item now updates correctly
- fixed: OSD-Musicplaylist: Under certain circumstances the database update of a scan wasn't successful
- fixed: OSD-Slideshow: interrupts recordings
- fixed: OSD-Timeline: now shows actual channel as selected
- fixed: OSD-Timer: disabled timers can't cause a conflict anymore
- fixed: OSD-Videoplaylist: Clearing of playlist didn't work
- fixed: OSD-Videoplaylist: Showing current playing item now updates correctly
- fixed: OSD: Disable mouse was ignored
- fixed: OSD: Inputdialog ignored videowindow settings.
- fixed: Recordingoptions: Changed max. recordingtime to 1439 minutes.
- fixed: Recordingwindow: Changing the channel didn't enable update-button.
- fixed: Recordingwindow: DisableAV checkbox wasn't moved when resizing window
- fixed: Recordingwindow: DisableAV default value was ignored if nothing is selected
- fixed: Recordingwindow: endless Refreshloop
- fixed: Recordingwindow: Repeating timer date-display wasn't correctly updated after finishing recording
- fixed: Timeshift: Jump in timeshift now works as expected.
- fixed: VCR: DisableAV with one recording wasn't activated, if the recording-channel was on the same transponder
- fixed: VCR: If "tune channel" as recording action is selected, the channel will only be tuned once.
- fixed: VCR: Multiple calls of recording plugins
- fixed: VCR: Now calculating the epg info before recording starts, so the filename is correct.
- fixed: VCR: Now recording PAT and PMT for TS files.
- fixed: problem with network client under windows 2000
- fixed: problem with nordic DVB Subtitles
- fixed: a couple of smaller bugs
- fixed: Problem with ATSC Cards
- updated: General: WindowDef.xml has now version 1.06
- updated: languagefiles
Link to comment
Is it possible to add manual ECM selection in channel properties? Some channels are encrypted in 2,3 or even 5 systems. How looks the proper ECM selection by SS1CI?
Link to comment
Well technically the CAM Module "eats" the Program Map Table (PMT) and the Conditional Access Table (CAT) and decides which ecm/emm combination is required for a proper decoding. Yet another selection inside the channel list would be a nightmare - right now i collect the PMT always in background to read things like MHP Pids, DVB Subtitle Pids etc. without asking for.
Christian
Link to comment
Hello Christian and everybody, I have not been using DVBViewer for about one year because of HD1 encryption but now that there is support for the SS1 CI and I have one of these cards, I want to try it.
I downloaded DVBViewer V 3.1 today and also the new Twinhan V 2.602 drivers and software. I installed the SS1 CI card and the latest Twinhan drivers, then I installed DVBViewer 3.1 but I am getting no signal. I then installed the Twinhan software (which is very basic) and it works ok so the card and drivers are ok. Is it necessary to have a SS2 card in the system (I don't have one installed at the moment) for DVBViewer to work? I might just be doing something stupid, very tired today. Is there anything I can do to test if the DVBViewer is seeing the SS1 CI card? The symptoms are as if there was no DVB card installed.
Thanks.
Jim.
Link to comment
Thanks.
Jim.
Just to be sure:
Did you choose the right device in Options DirectX page 'Current Device'?
Everything is working just fine for me :)
Edited by kookoo
Link to comment
So I was doing something stupid, thanks kookoo. It is working perfectly, including HD channels and decrypting HD1 without any problem.
Now that it is working I will have a whole list of questions, like operation of the remote control that came with the SS1 CI and the USALS feature of the card which I need.
Thanks again.
Jim.
Link to comment
Christian
The standard says that the host (DVBViewer) has to send the ca_pmt to the application (module). That makes the module totally dependent from the host concerning the ecms. A ca_descriptor_prefilter could block the unwanted ecms by not sending these descriptors to the module. Only emms are filtered independently by the module (module reads the cat but not the pmt).
Link to comment
About the remote device bundled with the skystar1. I did not installed it, but i guess it's just translates the remote key into keyboard keypresses. Assigning the keys in the keyboard map should solve the problem.
Christian
Link to comment
Is there yet way to change the font or size of EPG? I'm using this via tv and composite cable, and the EPG is unreadable(or atleast very hard to read) because of the tv resolution.
Link to comment
I have acquired from little dvb wiever, I wanted to know if the card hauppauge dvb-s nexus is supported? in the case I can obtain the same performances of the ss2? thanks
Link to comment
@paperokk
Nope. The DVB-s Nesus is something completly different. It´s a full featured card.
Only Technisat Skystar 2/Airstar/Cablestar/Skystar 1 CI (Twinhan model) products are supportet at the moment.
Keep in mind that the Skystar 1 CI from Technotrend/Twinhan is something completly different form the Nexus. The Nexus is a Technotrend Skystar 1, and has nothing to do with the Skystar 1 CI :)
So, the cheapest way is to get a Skystar 2 (about 50€, eBay, or the Twinhan Skystar 1 CI, about 90€, eg. www.kmelektronik.de in Germany)
cu,
Rince
Link to comment
@paperokk
cu,
Rince
they are in possession of a ss2, I wanted to put the nexus why little works hardware employing the cpu
Link to comment
If you have little CPU power, you can still record while turning of the display, so CPU consumtion will not be a problem anymore.
Link to comment
the epg display can be easily changed with the skineditor located in the members section. Just open the xml's and change the font size.
Christian
Link to comment
Hi there,
I just installed 3.1 and the first thing I found was a bug:
the extended exit menu on pressing the powerbutton on the winlirc does not work!
the normal shutdown menu appears but without any description:
anything else is fine so far
servus,
daflory
Link to comment
I solved it by opening the setup.xml, changed the entry
"ShutdownAction">0</entry> to another value (2 or 3), started and closed the player and then rechanged it to 0. i saved the file and now it works ?
bye
oli
Link to comment
I just got DVBViever Pro and tried it with my TwinhanDTV Mini Cab (downsize version of TwinhanDTV Cab-CI). I can't find any channels (in the Twinhan software channels are fine).
Anyone know why? Could it be that my Mini Cab uses a different chipset from Cab-CI or something? In directx-options "current device" I use "VisionDTV 1 (DVB-C CI)".
I live in Finland.
Thanks.
BR,
Miika
EDIT 1:
OK, I've got it working after I received a ``special´´ version of the executable file from Mr. Hackbart. I also had to check the box ``Free to air only´´ in the channel scan tab..otherwise I could not find any channels.
However, WOW! This is a _great_ piece of software! I think we should persuade Twinhan to buy DVBViewer as a bundled software with their cards! :blink:
Twinhan should also consider treating their customers with equal care and support response time I have received with this program..
Edited by miika
Link to comment
Hi!
The new version is really great! Have not yet taken a look at all the new feature but from what I have seen so far, I really like it!
I have found one thing that has to be improved. I permanently use the Pan & Scan function in order to kill the black borders around the tv picture. When I start the teletext from the OSD menu its borders are also cut. The same thing happens after switching to another channel. In the upper left corner the tv channel logo is not shown completely.
Hope this will be fixed soon!
Daniel
Link to comment
