Frodo B Posted July 19, 2024 Posted July 19, 2024 Hi all, I am using Dvbviewer7.3.00 with this hardware: TechnoTrend BDA/DVB-S tuner for SAT and TT-BudgetCT2_4500 DVB-T/T2 Tuner for Terrestrial TV. Now I am trying to use also TBS viewer (to see if my black border problem is present also with this product). Since TBS viewer looks like DVBViewer I am trying to scan device buttom and then I would try to scan sat (Horbird and astra19.2) and terrestrial to find the channels that I see with DVBViewer. Unfortunatly the devices are not with TBSviewer. Question: can TBSviewer found technotrend device or only TBS device can be found? Thanks Frodo B Quote
Griga Posted July 19, 2024 Posted July 19, 2024 vor 2 Stunden schrieb Frodo B: can TBSviewer found technotrend device or only TBS device can be found? Only TBS devices, as far as I know. Please note that TBS is responsible for any support concerning TBSViewer. Quote
Frodo B Posted July 19, 2024 Author Posted July 19, 2024 Ok, thanks again. Isolved the problem of the dark border witha Factory reset of GPU. Ciao Frodo B Quote
