Warlord007 Posted April 18, 2005 Share Posted April 18, 2005 hi all just a quick question, think it has been answered in the german area, but i dont understand german does DVBViewer work with the WinAmp Multimedia PC Remote ? got me finger over the purchase button, not sure though if this dosent work has anyone got any alternatives thanks in advanced warlord Quote Link to comment
Guest Lars_MQ Posted April 18, 2005 Share Posted April 18, 2005 does DVBViewer work with the WinAmp Multimedia PC Remote ? Erm don't know, what kind of RC is this? Can you use it with winlirc oder girder? Every RC supported by winlirc or girder can be used with the DVBViewer. If you use DVBViewer Pro 3.1 or GE there is a girderplugin in the membersarea which will simplifiy the use of girder. And remember the more buttons the better Lars Quote Link to comment
Warlord007 Posted April 18, 2005 Author Share Posted April 18, 2005 does DVBViewer work with the WinAmp Multimedia PC Remote ? Erm don't know, what kind of RC is this? Can you use it with winlirc oder girder? Every RC supported by winlirc or girder can be used with the DVBViewer. If you use DVBViewer Pro 3.1 or GE there is a girderplugin in the membersarea which will simplifiy the use of girder. And remember the more buttons the better Lars <{POST_SNAPBACK}> thanks for the fast reply LarsMQ here is the remote h**p://tekgems.com/Products/winamp-remote-control.htm it seems to support all 3 does the girder plugin work with 3.0 as 3.1 has a big bug with crashing on channel swapping tnx warlord Quote Link to comment
Guest Lars_MQ Posted April 18, 2005 Share Posted April 18, 2005 No this plugin will only work with the GE or 3.1 not the 3.0, sorry. lars Quote Link to comment
Warlord007 Posted April 18, 2005 Author Share Posted April 18, 2005 No this plugin will only work with the GE or 3.1 not the 3.0, sorry. lars <{POST_SNAPBACK}> ok thanks Lars, well i have ordered the remote, so will have to test it with v3.0 and winlirc will let you know how i get on when it arrives and tested warlord Quote Link to comment
