HTPCHome
gracen
Well you need to download the weather images. In order to avoid a big install file we decided to seperate this.
Christian
Link to comment
Christian
Found the images... unpacked, but not sure where to put them as there is no readme. file. Before I randomly put them into images or plugin or main folder can you give me a hint? thx.
Link to comment
  • 1 month later...
hi Oliver...thank you for your ateintion,i made the same as you told Gracen,i got the information about the weather but there is no icons displayed..;) where is the problem can you help me ...thx
Link to comment
