plazma Posted May 11, 2005 Posted May 11, 2005 hi anyone knows how can I get signal with twinhan 1020a? at website I read DVBViewer 3,1 works with twinhan ci but I cant get signal and DVBViewer cant find any channels. I just registered and I think I bought a program that I cant never use Quote
hackbart Posted May 11, 2005 Posted May 11, 2005 hmm, well i use the same sdk like the twinhan software. So if this one does not work, the DVBViewer also wont display dvb data. I'm not sure what's the reason for in your special case, but at least i work with twinhan to figure out some problems i even have with the card. Christian PS: Am i right with the thesis you deal with the dvb-s card? Quote
Guest Oliver Posted May 11, 2005 Posted May 11, 2005 In the German part there's another user having problems with this card. Bye Quote
plazma Posted May 11, 2005 Author Posted May 11, 2005 (edited) hi again I havent got enough knowledge about dvb-s cards to decide what the problem is maybe u tested your program with twinhan 1030 a and I guess that its different from 1020a btw I dont know what the sdk is my card works with some other dvb apps. is your program recognizes the dvb-s card automaticly or needs any special setup for different cards? But I havent found setup option for different dvb-s cards at dvbviewer3.1 Maybe disecq problem ? Maybe I cant watch sat channels but at least I can watch mpg files and listen music with remote control Good osd man Edited May 11, 2005 by plazma Quote
hackbart Posted May 12, 2005 Posted May 12, 2005 The Twinhan Applicaton as well as the DVBViewer use the thsource.ax which is part of their SDK. I'm quite sure that even the red card you have is supported. All functional chipsets are //PCI HW_DST_FTA_CARD HW_DST_CI_CARD HW_DCT_FTA_CARD HW_DCT_CI_CARD HW_DTT_FTA_CARD HW_DTT_CI_CARD HW_DTT_AD_CARD //FPGA HW_MANTIS_FTA_CARD HW_MANTIS_CI_CARD //MANTIS // Satellite HW_VP_10260 HW_VP_1026A HW_VP_10270 HW_VP_1027A HW_VP_10330 HW_VP_10340 HW_VP_10410 // Cable HW_VP_20230 HW_VP_20331 // Terrestrial HW_VP_30230 HW_VP_30240 HW_VP_30410 HW_VP_40430 HW_M_MT352 //USB HW_DTT_FTA_USB HW_DTS_FTA_USB If the card is recognized it will be added in the options under directx. There you find a list with useable device which should include your VisionDTV DVB-S. Christian Quote
Pseudex Posted May 12, 2005 Posted May 12, 2005 i have the same card and the same problem. under directx i chosed visoinDTV dvb-s but it doesn't work. in this topic i posted some log outputs http://www.DVBViewer.com/forum/index.php?showtopic=7694 Quote
hackbart Posted May 12, 2005 Posted May 12, 2005 Could you please check this module? Just extract the folder in to the DVBViewer directory and select the Twinhan Entry in the DirectX Options. Christian Quote
Pseudex Posted May 12, 2005 Posted May 12, 2005 (edited) it is workin. thanks alot i replaced the thsource.ax with the one of ProgDVB. now it's workin fine. before this replacement DVBViewer was ternimating after a while! Edited May 12, 2005 by Pseudex Quote
plazma Posted May 12, 2005 Author Posted May 12, 2005 hi again twinhan module didnt solve my problem Still I cant see visionplus cı under the current device tab. I only see dvb file device,unicast network device,multicast network device options. and I discovered thet my card is not 1020a its 1030 with ci and not red its yellow. according to their website twinhan stopped supporting yellow cards. Probably my card will necer work with dvbciewer I started to think buying SS2:) Quote
plazma Posted May 12, 2005 Author Posted May 12, 2005 HMMM I dont know what happened but it works fine now and performance satisfied me . fast and elegant program Quote
charelke Posted May 15, 2005 Posted May 15, 2005 (edited) Hi, I am a complete newbie when it comes to DVBViewer. However, I would like to know how to get my Twinhan 1020 to work. Or am I to understand this would only work for a 1030a or the twinhan's equipped with a CI interface? I installed the lastest version of the Twinhan drivers. I found them on TwinHan.com under donwloads I am using the latest stable relesase from their website address and not the beta on offer. All works fine in MyTheatre v3.26, my registered copy. Also the TwinhanDTV software and application work fine and that for all my dishes (4). I am using a typical 4 in one switch (1.0). Sadly enough, any of the DVBViewer install files I downloaded from the Technisat site fail to recognise my Twinhan hardware. Any help is welcome. I really would like to see if I can get this twinhan to work under DVBViwer 3.1. I am interested in the broadcasting capabilities of DVBViewer and even wrote a long time ago to Hackbart, asking if something could be done in DVBViewer to support the Twinhan PCI boards. It seems this has noiw been done. What DVBViewer version should I buy or download, I never saw an option when installing DVBViewer for the so called Twinhan compatible device driver, which can be thicked in the instsallation process. Please help, I checked most DVB websites, google and this forum, but this is the closest thread I found to an answer. Can someone offers a step by step explanation on how to achieve this install on Windows XP SP2 with a working Twinhan 1020 installed. I am also interested in the driver development as this might mean my Twinhan can now be seen as a directX input device. never achieved to do this as such drivers were not available allows use of software like Windows Media Encoder for archiving of ie. recorded programs. Please help. Many Thanks in Advance for all help, Charles Osstyn My Webpage Msn messenger chosstyn@hotmail.com please get in touch if you know how to solve this problem! charlie@osstyn.com Edited May 15, 2005 by charelke Quote
Guest Oliver Posted May 15, 2005 Posted May 15, 2005 You only need the DVBViewer Pro 3.1 and the additional module posted above. Bye Quote
charelke Posted May 15, 2005 Posted May 15, 2005 Thanks very much for that info but where can I find this download. And when ordering is this the software I will get the ordering page does give no version info regarding the software I will purchase???? many thnaks in advance, Charlie PS, Oliver please msn me if you can I need help! Quote
Guest Oliver Posted May 15, 2005 Posted May 15, 2005 http://www.DVBViewer.com/oliver/Einfuehrun...ml#einfuehrung5 Bye Quote
the death Posted May 30, 2005 Posted May 30, 2005 hi all, I faced a problem with DVBViewer and twinhan blue card in scanning, the program can open the LNB of the card, but no channels to scan any help, thanks Quote
crs Posted June 26, 2005 Posted June 26, 2005 hello im new to DVBViewer i have twinhan 1022 that works well in my theatre ritz progdvb and dream , i just purchased DVBViewer i have read the post here and even added the module. and still can't scan any channels also can a 4 in 1 diseqc work right now i just have 1 sat hooked up straght. before i shoot to far in the dark will this work with the 1022a twinhan thanks crs Quote
yaRincewind Posted June 27, 2005 Posted June 27, 2005 @crs At the moment the DVBViewer isn´t runnig fine with twinhan, but next update is to bring a solution so just wait a little time, it will work then... Quote
acount1002 Posted August 20, 2007 Posted August 20, 2007 Should work now. hi.. still the same problem exist for me even after using the module and filter mentioned above please any one nows any solution for twinhan vp 1020a (blue board) on dviewer 3612? support.zip Quote
Tjod Posted August 20, 2007 Posted August 20, 2007 Pleas install the current Version 3.8.0.0 no support for old Versions. Quote
