Volume not consistent
otis.lewd
Is it normal when changing TV stations to get different volume levels for each station? Is there any way so that the volume is the same no matter what channel I switch to? I don't know why some TV stations (US) are louder than others. Thank you and Merry Christmas to all. I have played with computer settings and different audio "drivers", but that doesn't seem to be the problem or the solution. I mainly use LAV filters for audio.
You are using DVBViewer, I suppose. Is "Settings -> Options -> TV/Radio -> Remember volume for each channel" checked?
vor 12 Stunden schrieb otis.lewd:
Yes, that is checked.
Uncheck it. This setting probably causes or worses the problem. Lately we had a discussion about this topic (in German, Google translation).
vor 23 Stunden schrieb otis.lewd:
Yes, sometimes stations are using different volume levels, sometimes even within a single station for different program types. "Settings -> Options -> TV/Radio -> Remember volume for each channel" was supposed to mitigate this problem, but it doesn't really.
