Can't Del-Add Channels
harithajam
Go to the Edit Tab of the channellist window. I'm quite sure you'll find a Delete Button there.
For adding channels use the Add Button, after you've entered the channel data. For duplicating a or moving a channel to another category change the category name, and then click Add resp. Update.
However, the channel editing facilities of the TE are quite poor. Upgrade to DVBViewer Pro resp. DVBViewer GE, if you want more (e.g. sorting channels by drag & drop)
Link to comment
