DVB-PC TV Stars
pjmitch
Hi all
I have just bought a new dvb-t pci card all is working well. My only problem is that I had hoped to down load the digital teletext that is avalible. Is this card able to capture the digital teletext.
Regards
Peter
Hi Oliver
The digital teletext service that i refer to is the BBCi service on freeview. I think the same system is user to deliver the radio station logos that you can see if you use a set top box. I should mention that I recieve this service from the black hill transmitter.
I was just a little let down, I had expected it to be almost the same if not better than the set top boxes that are avalible.
The problem is most likley a software issue.
Regards
Peter
BBCi uses MHEG/OpenTV applications (DVB-T/-S), something completely different from traditional teletext services like Ceefax - I'm not aware of any end user-compatible implementations on the PC.
