Twinhan DTV Cab-CI scan problems
mhelin
So what's the situation with this card? I've tried the posted Twinhan module but DVBViewer will not show correct Channel Scan window / parameters. I've heard that some people have received some beta version which tunes also DVB-C channels (at least for some). There was also the SDK issue. Could you put all of the files into download area so I could also get them (yes, I have paid for the software which doesn't work).
In tuning DVB-C channels will DVBViewer try to use polar inversion?
In transponder list for DVB-C there are next stuff:
[sATTYPE]
1=4000
2=Cable (QAM 128)
[DVB]
0=9
1=138325,4,6900
2=378137,4,6900
3=386012,4,6900
4=346012,4,6900
5=417950,4,6900
6=402137,4,6900
7=386012,4,6900
8=418137,4,6900
9=426262,4,6900
The first parameter in "1=138325,4,6900" after "=" is frequency, the second modulation (4=QAM128) and the third is the symbol rate. In my cable network the spectral inversion should also be used but it's not listed on the transponder list.
