TransEdit 4.3.4
EnoSat
After installing TransEdit 4.3.4, the application window does not appear, although it appears in running applications.
Quote
Important change: Currently we are using a self signed certificate for signing our software (please read more about it here). For Windows this is the same as “unsigned”, because it can’t verify the publisher. This may trigger misleading "Windows protected your PC" warnings when launching TransEdit.exe for the first time. You need to first click "More info" and then "Run anyway" to get it going (see here). This will particularly happen if you download TransEdit_4_3_4.zip with a browser and use the Windows Explorer for extracting the content to the DVBViewer program directory. The warnings do not appear if you use 7-Zip for extracting or the DVBViewer Downloader for downloading and installing TransEdit (recommended, see Windows start menu → DVBViewer).
This window did not appear
The certificate in the system is:
certifikat2.png.09f5a7a1e8b417a7fdfd1889e369d9ec.pngcertifikat1.png.bafe79cb0f8691e1b2a91474e568fd6d.png
When I start TransEdit 4.3.3, everything is fine.
Edited by EnoSat
added support.zip
Maybe the problem was the missing DVB IPTV Type in 4.3.4
vor 4 Stunden schrieb EnoSat:
Confirmed. An old IPTV Network Device in the device list causes an infinite loop when TransEdit 4.3.4 loads the device list from the file TransEdit.ini.
In your case there is an easy fix: Simply delete in your old TransEdit. ini everything from Name.3=IPTV Network Device down to (and including) the last line. However, it is not so easy if the IPTV Network device is not the last entry.  Looks like I have to upload a hotfix version. ;)
Anyway, thanks for your researches!
  • Thanks 1
new TransEdit versions (4.3.4 and 4.3.4.1) do not open any of my .m3u files. It shows empty. (no problem with 4.3.3.0 version)
any suggestion
vor 4 Stunden schrieb umitcakiroglu:
Confirmed (see here). Sorry, a stupid bug ;) I hope it is the last one. Please download again.
Hi. Thanks to fix. Now IPTV device only in TS Stream ?
Planned added support for DVB-I and DVB-NIP ?
vor 17 Minuten schrieb EnoSat:
Yes.
vor 18 Minuten schrieb EnoSat:
No plans yet.
