AndreaB Posted January 14 Posted January 14 Hi everyone, I am experiencing an issue with the latest version of TransEdit and my Terratec Cinergy T2 stick. The problem occurs during the scanning process: If I scan a single frequency (or just 2-3 of them), everything works perfectly: the scan finishes correctly and the LCN column is fully populated. However, when I perform a full scan (Scan All), the software throws an "Access Violation" error (see attached image). This is followed by a blank "Channel numbering selection" window, and once the process is over, the LCN field is empty for all channels. Troubleshooting already performed: I am using the latest available drivers for the TV card. I have already tried increasing the PAT, SDT, and PMT Timeout values to 8000 ms, but the issue persists. Has anyone encountered this "Access Violation" during full scans, or is there a specific setting I should look into to fix the LCN detection? Thanks in advance for your help! Andrea Quote
Griga Posted January 14 Posted January 14 Rather looks like a TransEdit bug, not hardware or driver-related. Please attach your TransEdit.ini, so I can see your settings. vor 8 Stunden schrieb AndreaB: However, when I perform a full scan (Scan All), the software throws an "Access Violation" error (see attached image). In theory there should be no difference to scanning a single frequeny. Maybe due to a transponder close to the end of the list? Quote
AndreaB Posted January 14 Author Posted January 14 (edited) Hi Griga, I performed a single scan for all individual transponders, and the scan was successful for the first 9 with a usable signal. However, an error consistently occurs with the last two frequencies that have a signal: 674,000 kHz and 690,000 kHz. If I disable the option 'Scan NIT, BAT, and VCT...', the problem does not occur. I managed to resolve the issue for the 674,000 kHz frequency by increasing the 'PAT Timeout' to 6500. As for the 690,000 kHz frequency, I haven't found a PAT value or any other setting that prevents the error. I checked the Analyzer and all the indicated values (packet counts) are increasing. This suggests that the stream is being received, yet the LCN remains missing and the error persists during a standard scan. Ciao, Andrea PS: Is it possible to have a little more space for attachments? I have to keep deleting old images to post new ones, but the old ones might still be useful... TransEdit.ini Edited January 14 by AndreaB Quote
Griga Posted January 15 Posted January 15 vor 9 Stunden schrieb AndreaB: As for the 690,000 kHz frequency, I haven't found a PAT value or any other setting that prevents the error. I I think I have found the cause. There is something happening that TransEdit does not take into account, because usually it should never happen. A value stored as LCN ID is 0. This lets TransEdit use an uninitialised object and read data from the memory address 00000008, causing an access violation, of course. Please verify it with the test version, that I have provided as attachment of a personal forum message (PM) for you. It avoids the access violation, but only cures the symptom. Additionally it has to be investigated, how the LCN ID can become 0. For this I would need a recording from a transponder that triggers the error. Please proceed as follows: Select the transponder and click Analyze. Wait a bit until the PID list at the right of the Analyzer window is complete. Right-click the PID list and click "Select Main SI PIDs". Click Start Record (see Settings -> Analyzer -> Output Directory where the recording gets stored). Stop the recording after approx. 1 minute. Do you have web space where you can upload the recording? If not, you can use WeTransfer and send me the download link as PM. Quote
AndreaB Posted January 16 Author Posted January 16 You can download the captured data stream here: https://www.swisstransfer.com/d/c34e8250-62e5-49c8-b86b-edf8d8f44aed (I requested more storage space specifically to attach images like the two below, as the system is notifying me that I have run out of available space). With the new version, the error no longer occurs, but: For the two problematic transponders (frequencies 674 and 690), once the individual scan finishes, a 'Channel Numbering Selection' window appears. In the list, only the Provider name is shown (29 is the ONID number). This consistently happens with frequency 690 and occasionally—mostly during the first scan—with frequency 674. After clicking OK, the LCN column is populated. If I run 'Scan All', the same window appears showing three Provider names; however, even after confirming with OK, the LCN column remains empty." Ciao, Andrea Quote
Griga Posted January 17 Posted January 17 vor 17 Stunden schrieb AndreaB: For the two problematic transponders (frequencies 674 and 690), once the individual scan finishes, a 'Channel Numbering Selection' window appears. In the list, only the Provider name is shown (29 is the ONID number). Should not happen. This already indicates that something is wrong. The Channel Numbering Selection window should only appear if there is something to select, or if it is opened manually (Right-click the Scanner Window...). However, the 690 MHz transponder only contains a single provider with 29 as Original Network ID = LCN ID, so there is nothing to select. I've found the reason for it. It is a side effect of this fix. In order to capture the network name in any case, TransEdit creates a dummy LCN data set with the name as soon as it appears, plus (in case of DVB-T) with the Original Network ID as LCN ID, and stores it. Since the Original Network ID appears later in the NIT, and maybe even in another NIT section, TransEdit has to use the Original Network ID that has been read before from the SDT. Unfortunately this Original Network ID is still 0 if the SDT arrives later than the NIT section containing the network name. This explaines, why the issue sometimes happens and sometimes doesn't. It depends on the order in which the SI tables arrive. There we are... difficult to handle. I have to think about it. I can provide a quick fix that will probably work in your case (see new test version in the PM), or with other words, as long as the NIT only consists of only one section, or the SDT arrives before the NIT section that contains the network name. But I can still imagine cases where it won't work. In this case "Unknown" will be displayed as network name. Quote
AndreaB Posted January 24 Author Posted January 24 Hi Griga, for the time being, I have 'bypassed' the issue by accepting all the fake duplicate channels (the ONIDs) at the end of the full scan and checking the 'Remember LCN IDs' box. By doing this, after saving the channel list and reloading it in DVBViewer, they are still sorted by LCN, just like on a TV. 🙂 Ciao, Andrea Quote
Griga Posted January 24 Posted January 24 Am 17.1.2026 um 08:03 schrieb Griga: I can provide a quick fix that will probably work in your case (see new test version in the PM), Why don't you use it? You didn't download it up to now. Quote
AndreaB Posted January 25 Author Posted January 25 Hi Griga, sure, I downloaded and installed the new version of TransEdit, but it still has the issue I described in my message from January 16: instead of offering a choice between duplicate channels, it shows the ONIDs. I simply accepted the ONIDs because, if I don't, TransEdit won't display the LCNs. Then, I selected all channels and manually deselected one of the duplicates with the same LCN. I hope that was clear. Ciao, Andrea Quote
Griga Posted January 25 Posted January 25 vor 14 Stunden schrieb AndreaB: sure, I downloaded and installed the new version of TransEdit, No, you didn't. Check the PMs. They still show 0 downloads for the latest TransEdit attachment. Quote
AndreaB Posted January 25 Author Posted January 25 Hi Griga, I hadn't realized you had sent me another new version, my apologies. This latest version resolves the issue with the 'Channel Numbering Selection' prompt during a single scan: it no longer appears. However, the problem remains with the 'Channel Numbering Selection' prompt at the end of a full scan, which, as mentioned before, still shows ONIDs. Additionally, a new issue has emerged: if I select the displayed ONIDs and check 'Remember LCN IDs', the LCN column is NO longer populated. Ciao, Andrea Quote
Griga Posted January 26 Posted January 26 vor 9 Stunden schrieb AndreaB: However, the problem remains with the 'Channel Numbering Selection' prompt at the end of a full scan, which, as mentioned before, still shows ONIDs It is supposed to work like that. If scanning yields LCNs originating from different ONIDs (which means, different sources), the Channel Numbering Selection window enumerates all sources that have been found during the scan. LCN sets from different sources/DVB networks may be conflicting or ambiguous. The same LCN may be assigned to different channels, or different LCNs to the same channel. In this case it is necessary to select the LCN set that shall be used. The user has to decide which set is appropriate for him. Please have a look here. The screenshot shows the LCN Selection Window after scanning a transponder of a Dutch cable provider. It provides LCN sets for different regions. If someone is living in Amsterdam, he has to select the Amsterdam LCN set, otherwise he may get wrong or missing LCN -> channel assignments. However, it is also possible that sets from different sources are needed together. That's why the Channel Numbering Selection window supports multi-selection. Unfortunately LCNs are handled quite differently in different countries and DVB networks. TransEdit has to cover all possible cases, which makes the whole thing difficult, both for the developer and for users. You won't encounter such problems with a DVB receiver, because mostly they are tailored (localised) for a certain region and reception type. The appropriate LCN handling is part of the firmware. Of course we can't provide x TransEdit versions for all regions/networks all over the world, as you will understand. vor 10 Stunden schrieb AndreaB: Additionally, a new issue has emerged: if I select the displayed ONIDs and check 'Remember LCN IDs', the LCN column is NO longer populated. This is clearly an issue, that should not happen. However, regarding the TransEdit code, it is not possible that using the checkbox can cause it. Up to now I can't imagine how this can happen, and I can't reproduce it here with the Dutch sample file of a single transponder that yields more than on LCN set. Unfortunately there is also no way for me to reproduce issues resulting from scanning more than one transponder, if I can't receive them myself. Quote
AndreaB Posted January 26 Author Posted January 26 Hi Griga, in my case, I have several examples of different channels sharing the same LCN, as shown in the image for LCN 3 with the same ONID. The problem is that TransEdit does not offer a choice between these actual channels; instead, it prompts for a choice between 'non-channels'—specifically ONIDs—as shown in the previous screenshot in other message. 29, 272, and 8572 are not duplicate channels, but ONIDs, and only 8572 actually contains duplicate LCNs. Ciao, Andrea Quote
AndreaB Posted January 26 Author Posted January 26 15 hours ago, Griga said: Unfortunately there is also no way for me to reproduce issues resulting from scanning more than one transponder, if I can't receive them myself. If you'd like, I can organize a guided tour of Bergamo, with the opportunity to run a TransEdit scan at the end! 😁 Ciao, Andrea Quote
Griga Posted January 27 Posted January 27 vor 9 Stunden schrieb AndreaB: I have several examples of different channels sharing the same LCN Obviously there are three RAI 3 versions for different regions. For saving bandwidth they share the same Video PID. It's quite logical that LCN 3 is assigned to all of them. It's handled similarly in German DVB-T2 (without LCNs): Most of the time both WDR HD versions are identical, as the PIDs indicate. Only during a certain time called "local time" they broadcast different programmes. If we had LCNs, I'm sure the two WDR HD versions would also get the same number. vor 8 Stunden schrieb AndreaB: The problem is that TransEdit does not offer a choice between these actual channels; Of course it does. Just select the scan results that you don't want and delete them. If you want to keep them all, but LCN 3 only assigned to one of them, you can achieve it in the DVBViewer Channel Editor (set the other ones to 0). Or take care that the one that you want is located above the other ones in your list. AFAIK DVBViewer will select the first matching channel from the top if you press 3 on your keybord. I think you expect a bit too much from TransEdit. As already said, it can't be tailored exactly for your needs and the broadcasting habits in your country. vor 8 Stunden schrieb AndreaB: If you'd like, I can organize a guided tour of Bergamo, with the opportunity to run a TransEdit scan at the end! 😁 Thanks a lot. Unfortunatley I can't afford travelling to other countries just for TransEdit tests. Quote
