Frikop Posted February 8 Posted February 8 Hi, where can I find older TransEdit versions in the members section? Version 4.3.4.2 and 4.3.3 have a bug that prevents recording the 16APSK mux on 19e 11816V 31430 which was FTA when i tried earlier. When trying to open the broken recordings in a media player, it fails and when dragging the TS files into TransEdit itself, it says "Tuning Error". Tested on two computers and with 3 different TBS cards. Its not a driver issue either since other tools can record this fine with these cards. This is the only time where i encountered this issue in 20 years, so please let me know where I can find older (working) TE versions. TransEdit 3.9.5 for example, definitely works with the mux but sadly i deleted it the other day, wrongfully assuming that the only two easy to find versions of TE in the members section would NOT have a critical bug... Thankful for any help in locating older versions Quote
Griga Posted February 9 Posted February 9 Am 8.2.2026 um 01:31 schrieb Frikop: where can I find older TransEdit versions in the members section? Not available anymore. We should rather focus on fixing the bug in the current version, if there is any. Am 8.2.2026 um 01:31 schrieb Frikop: Version 4.3.4.2 and 4.3.3 have a bug that prevents recording the 16APSK mux on 19e 11816V 31430 which was FTA when i tried earlier. All video/audio streams are now encrypted. I've recorded the whole mux with the Analyzer. No problem whatsoever. What do you mean by "prevents"? Am 8.2.2026 um 01:31 schrieb Frikop: when dragging the TS files into TransEdit itself, it says "Tuning Error". Can't reproduce it either. Can you upload a sample somewhere so I can check it myself? If you have no web space, you may want to use WeTransfer. AFAIK you can upload up to 2 GB. Quote
