VDR & DVBViewer Media Server
hello
i have VDR and want add satip to /etc/vdr/conf.d/50-satip.conf
i read this : https://github.com/rofafor/vdr-plugin-satip/blob/master/README
and add:
[satip]
Quote
-d 12
-s 192.168.100.6:554|DVBS2-12|DVBViewer:0x08
but not working
my description.xml:
Quote
<satip:X_SATIPCAP xmlns:satip="urn:ses-com:satip">DVBS2-12,DVBT-0,DVBT2-0,DVBC-0</satip:X_SATIPCAP>
<satip:X_SATIPM3U xmlns:satip="urn:ses-com:satip">/rtspchannels.m3u</satip:X_SATIPM3U>
what correct setup?
Edited by Nayef
Which is your DVBViewer Media Server version?
Does it work without the :0x08 quirk?
Make sure the RTSP port of your Media Server is 554. If another RTSP Server is running on your PC (e.g. the Windows Media Player as background RTSP Server), the DVBViewer Media Server may be forced to use 8554. You can see the RTSP port that is actually used on the Web Interface -> Status page.
i have v3.3.1.12
tuner 1 to 8 = 13e
tuner 9 = 26e
tuner 10 to 12 = 7w
my setting now:
Quote
[satip]
-d 12
-s 192.168.100.6:554|DVBS2-8:S13E|DVBViewer:0x08
-s 192.168.100.6:554|DVBS2-1:S26E|DVBViewer:0x08
-s 192.168.100.6:554|DVBS2-3:S7W|DVBViewer:0x08
but no connect server
vor 4 Stunden schrieb Griga:
Please answer.
vor 17 Minuten schrieb Nayef:
tuner 1 to 8 = 13e
tuner 9 = 26e
tuner 10 to 12 = 7w
Are the tuners connected to different dishes? Are you using channel groups in DVBViewer and the Media Server to tell them wich tuners must be used for channels from a certain orbital positions?
same issue without
yes i have 3 tuners without Splitter/DiSEqC, Each tuner has its own independent satellite.
Yes, A: for 26e & B:7w & C for 13e
Edited by Nayef
vor 1 Stunde schrieb Nayef:
yes i have 3 tuners without Splitter/DiSEqC, Each tuner has its own independent satellite (...) A: for 26e & B:7w & C for 13e
Unfortunately Sat>IP does not support such a setup. This complicates it considerably. The VDR plugin has no idea which tuners can receive which satellite position. There is nothing like "Channel Groups" in Sat>IP. Therefore the Media Server maps tune requests from the VDR to group A, because this is the default. So it should at least be possible to receive a channel from 26e. Did you try that?
However, you can bind channels to a specific frontend (tuner) of the Media Server by using the FE parameter in VDR. The following paragraph in the VDR plugin Readme refers to it:
Zitat
A channel can be assigned into a specific SAT>IP frontend by giving the
identifier number in RID field of a channels.conf entry:
FE = RID % 100
Valid range: 1 ... 99
The frontend numbers equal the tuner position in the Media Server device list, counted from the top. See Media Server Options (svcoptions.exe) -> Hardware. The topmost tuner has frontend number 1, the next number 2, and so on down to the bottom. So if a channel is configured for FE 1 in VDR, the Media Server will use the topmost tuner in the device list for it, provided it is free. Otherwise it will send an error code to the client.
This is the only way to select a specific tuner for a channel with Sat>IP.
For finding out what is going wrong you may want to have a look at the svcdebug.log (see DVBViewer configuration directory). There you can see if tune requests from VDR have arrived, and the Media Server response. You can also attach the zipped svcdebug.log here as file, so I can have a look at it.
i try several option:
1- only one tuner:
Quote
-d 1 -s '192.168.100.6:554|DVBS2-1:S13E|DVBViewer'
or more one
set  /var/lib/vdr/sources.conf
Quote
S26E 1  Badr
S7W  2  Nilesat
S13E 3  Hotbird
/50-satip.conf :
Quote
-d 12 -s '192.168.100.6:554|DVBS2-8|Hotbird:S13E-3;192.168.100.6|DVBS2-1|Badrsat:S26E-1;192.168.100.6|DVBS2-3|Nilesat:S7W-2'
The problem is that it only sees one tuner. The server received 12 requests at once, but it only sees one device, as shown in my status section.
  (Digital Devices DVB-S/S2 Tuner 2 (5)-76%)
Log in vdr:
Quote
vdr[1284415]: [1284421] SATIP-ERROR: Connection timeout - retuning [device 0]
vdr[1284415]: [1284421] SATIP-ERROR: Detected invalid status code 454: rtsp://192.168.100.6/ [device 0]
vdr[1284415]: [1284421] SATIP-ERROR: Connect failed [device 0]
vdr[1284415]: [1284420] SATIP: Detected 1 RTP packet error [device 0]
or
Quote
Mar 26 01:00:36 myast.ddns.net vdr[890756]: [890760] SATIP-ERROR: Detected invalid status code 454: rtsp://192.168.100.6/ [device 0]
Mar 26 01:00:36 myast.ddns.net vdr[890756]: [890760] SATIP-ERROR: Pid update failed - retuning [device 0]
Log in svcdebug & hardware: attach
svcdebug.zip hardware.xml
For inspecting the Media Server tuner configuration I need the file svchardware.xml from the config sub-directory of the DVBViewer configuration folder. hardware.xml is for DVBViewer.
I guess it is the first tuner in your device list that is configured for channel group A, right? As already said:
vor 13 Stunden schrieb Griga:
The only way to override this is to let VDR use the frontend (fe) parameter, that selects a specific tuner in your device list. In your svcdebug.log I see two VDR tune requests that used fe=6, for example this one
Zitat
26.03.26 01:34:32.130 SETUP                200              src=1&fe=6&freq=11488&sr=27500&msys=dvbs2&mtype=qpsk&pol=h&fec=78&ro=0.35&pids=0,21
that selected the 6th tuner from the top, which is TBS 6909x DVBS/S2 Tuner 5 (9).
It is very difficult to address satellite positions with Sat>IP, if you are not using DiSEqC (which is the src parameter, src=1 is PosA/OptA).
Unfortunately I cannot help you with VDR configuration. I have never used it.
Yes, this first tuner for Group "A"
DiSEqC
VDR have logic option for  DiSEqC i think support group channel
svchardware.xml
why group here ( 2 4 1 ) not A B C ? -
Should I set the groups in the VDR to letters or numbers?
svchardware.xml
vor 21 Minuten schrieb Nayef:
Because a tuner can be configured for more than one group. The value is a binary coded set of groups. For example, a tuner that can be used for group A, B and C has the value 1 + 2 + 4 = 7. The default is all groups A...H = 1 + 2 + 4 + 8 + 16 + 32 + 64 +128 = 255.
vor 26 Minuten schrieb Nayef:
Forget it. Channel groups are a proprietary DVBViewer and Media Server feature. No other software knows channel groups. Sat>IP does not know channel groups. When using Sat>IP you can configure DiSEqC 1.0 (useless in your case) or Frontend (may help, but with serious restrictions).
Here is a solution for you.
It is no good solution. But at the moment there is no better solution, because you are not using DIsEqC for selecting satellite positions, and because of Sat>IP limitations.
The solution uses the frontend number (fe) and the following mapping:
  • group=A, position= 26e, Digital Devices DVB-S/S2 Tuner 2 (5) -> fe=9
  • group=B, position=7w, Digital Devices DVB-S/S2 Tuner 4 (4) -> fe=14
  • group=C, position=13e, TBS 6909x DVBS/S2 Tuner 7 (7) -> fe=8
The fe=... numbers must be entered in the VDR channels.conf file according to this
FE = RID % 100
and this: https://www.linuxtv.org/vdrwiki/index.php/Syntax_of_channels.conf
Here is an example. Satellite channels in the channels.conf file look like this:
BBC Arabic TV;BBC World Service:12597:vC34M2O0S0:S13E:27500:1001=2:1011=ara@3:0:0:8203:318:9400:0
The last number 0 must be replaced by the fe number:
  • For all 26e channels replace it by 9.
  • For all 7w channels replace it by 14
  • for all 13e channels replace it by 8
Please note that you must stop VDR before editing the channels.conf file.
This solution is not really good because
  • VDR can only use three tuners in the Media Server, one for each satellite position.
  • If you change the order of tuners in Media Server Options -> Hardware -> Devices, it will not work anymore in VDR.
A better solution requires a new option "Use fe numbers as channel group" in the Media Server, which means, a new Media Server version. It will let the Media Server use fe numbers as channel group (fe=1 -> group A, fe=2 -> group B,....). I will add this feature soon. You can have this version for testing,  if you want. With this solution
  • VDR will be able to use all tuners in the Media Server.
  • you can change the order of tuners in the Media Server device list without affecting VDR
  • Like 1
vor 23 Stunden schrieb Griga:
This is now implemented in Media Server 3.3.1.14. Let me know if you want to try. Then you will get a beta test version as attachment of a personal message.
With this new version, you first have to do the following:
  • Stop the Media Server
  • Start DMSTweaker.bat from the DVBViewer program directory. A window with expert settings appears
  • In this window search for the "Use Sat>IP frontend parameter as channel group" checkbox
  • Check it and save.
  • Restart the Media Server
Now the Sat>IP server uses frontend (fe) parameters sent by clients as channel group, not as device list index. This allows clients a tuner selection by channel group. fe=1 is mapped to group A, fe=2 to group B etc. up to fe=8 for group H.
Please note that the VDR channels.conf file must now be configured differently than before. The last number must be replaced by the channel group number:
  • For all 26e channels replace it by 1 (= group A)
  • For all 7w channels replace it by 2 (= group B )
  • for all 13e channels replace it by 3 (= group C)
Thanks Griga, I'll work on the experiment, maybe in a couple of days. The holiday is over and I'm busy with work now. I'll write about my experience with the new version here soon.
OK, I have sent you a personal message with a Media Server 3.3.1.14 test version.
  • Like 1
ok, Now i test, and now group connect via fe=1 A & 2 B & 3 C,
I've noticed that if I request a channel from 7w, the busy tuner is the one that switches to group B. Similarly, if I request a channel from 13e, it automatically goes to group C. However, the problem lies in the performance and frequent connection drops. I've tried several solutions, but the random disconnections persist.
here my Setup:
#Satip : /etc/vdr/conf.d/50-satip.conf
Quote
[satip]
-d 12
-r 67108864
-s 192.168.100.6|DVBS2-12|DVBViewer:0xCF
(0xCF) = (0x01 + 0x02 + 0x04 + 0x08 + 0x40 + 0x80)
cat /proc/sys/net/core/rmem_max
67108864
#Setup.conf
Quote
ZapTimeout = 10
streamdev-server.AllowSuspend = 0
streamdev-server.HTTPBindIP = 0.0.0.0
streamdev-server.HTTPServerPort = 3000
streamdev-server.MaxClients = 30
streamdev-server.StartHTTPServer = 1
streamdev-server.StreamBuffer = 65536
streamdev-server.SuspendMode = 0
vnsiserver.MaxClients = 5
vnsiserver.Timeout = 30
#channel.conf
Quote
Al Jazeera Documentary;Telespazio:12111:VC34M2S0:S13.0E:27500:240=2:241=@3:0:0:705:318:7000:3
MBC Action;MBC:11919:HC34M2O0S0:S26.0E:27500:406=2:606=eng@4:0:0:6:702:512:1
AD Sports 1;AD:11411:hC34:S7.0W:30000:102=2:202=ara@4:0:0:2:2:2:2
here error code
# log journalctl -u vdr -f
Quote
switching to channel 1 S13.0E-318-7000-708-3 (Al Jazeera)
[1842990] setting watchdog timer to 60 seconds
[1843360] SVDRP server handler thread started (pid=1842990, tid=1843360, prio=low)
[1843360] SVDRP myast.ddns.net opening port 6419/tcp
[1843360] SVDRP myast.ddns.net listening on port 6419/tcp
 [1842990] OSD size changed to 720x480 @ 1
[1842990] ERROR: no OSD provider available - using dummy OSD!
[1842990] max. latency time 2 seconds
[1842997] SATIP-ERROR: Detected invalid status code 454: rtsp://192.168.100.6/ [device 0]
[1842997] SATIP-ERROR: Keep-alive failed - retuning [device 0]
[1842997] SATIP-ERROR: Connection timeout - retuning [device 0]
Quote
[1833659] ERROR: 1 ring buffer overflow (1128 bytes dropped)
[1833734] Streamdev: Accepted new client (HTTP) 192.168.100.5:51795
[1833734] streamdev-server: closing HTTP connection to 192.168.100.5:51795
[1833737] VNSI: Requesting clients to reload channel list
[1833659] ERROR: 1054 ring buffer overflows (1068968 bytes dropped)
[1833660] SATIP-ERROR: Detected invalid status code 454: rtsp://192.168.100.6/ [device 0]
[1833660] SATIP-ERROR: Keep-alive failed - retuning [device 0]
[1833734] Streamdev: Accepted new client (HTTP) 192.168.100.5:54036
[1835734] streamdev-writer thread started (pid=1833651, tid=1835734, prio=high)
[1835735] streamdev-livestreaming thread started (pid=1833651, tid=1835735, prio=high)
[1833734] client (HTTP) 192.168.100.5:51573 has closed connection
[1833734] streamdev-server: closing HTTP connection to 192.168.100.5:51573
[1834377] streamdev-livestreaming thread ended (pid=1833651, tid=1834377)
[1834376] streamdev-writer thread ended (pid=1833651, tid=1834376)
[1833734] buffer stats: 513616 (13%) used
[1833660] SATIP-ERROR: Connection timeout - retuning [device 0]
Quote
$ netstat -s | grep "receive buffer errors"
    69901 receive buffer errors
For your information, all devices are connected via a 1000 Ethernet cable.
Any suggestions?
svcdebug.log
vor 10 Stunden schrieb Nayef:
You can try to switch the protocol from UDP to TCP, as you did in the beginning:
Zitat
-d 12
This is called "Support for RTP over TCP" in the VDR Plugin Readme. It is also supported by the Media Server.
Additionally configure Transport mode = rtp-o-tcp in the VDR setup menu (see plugin Readme). With TCP lost data packets are automatically sent again by the server. This prevents video and audio dropouts.
However, another problems is the "keep alive" handling. It does not work well.
In Sat>IP, the client must send "keep alive" messages to the server every x seconds. The Media Server wants to receive keep alive messages at least every 20 seconds. If a message does not arrive in time, the Media Server closes the Sat>IP session. If the client tries to use a closed session, the Media Server responds with status code 454 (Session Not Found). This happens often, as I can see in your svcdebug.log. But I don't know why.
To find out more about it, we need logging of the arriving "keep alive" messages. I have created such a Media Server version. You have another PM.
TCP
ok, now my setting for force use TCP:
#setup.conf:
Quote
satip.OperatingMode = 2
as here: https://github.com/rofafor/vdr-plugin-satip/blob/master/README
 and
Quote
-d 12 -s 192.168.100.6|DVBS2-12|DVBViewer:0x08
and load channel = no error keep Alive but still bad glitches & performance
Log vdr
Quote
ERROR: 1 ring buffer overflow (940 bytes dropped)
ERROR: streamdev-server: couldn't send data: Bad file descriptor
ERROR: 121 ring buffer overflows (125208 bytes dropped)
ERROR: 989 ring buffer overflows (995084 bytes dropped)
ERROR: 1079 ring buffer overflows (1111644 bytes dropped)
svcdebug.log
how apply channel group (fe=1 -> group A, fe=2 -> group B,....) for minisatip ?
vor 18 Stunden schrieb Nayef:
#setup.conf:
Wrong setting. For forcing TCP you must select the according transport mode, not the operating mode. You are still on UDP, as the svcdebug.log shows.
Minisatip as server or as Media Server client?
2 hours ago, Griga said:
transport mode,
Quote
satip.TransportMode = 2
How do I find out the connection status  tcp or udp in the log?
Media Server client from DMS
The class names appearing in the log are
  • TRTSPUDPClient for UDP
  • TRTSPInterleavedClient for TCP (compatible with new DVBViewer versions, minisatip, tvheadend)
  • TRTSPDVBViewerTCPClient for TCP (compatible with old DVBViewer versions)
vor 2 Stunden schrieb Nayef:
If your Media Server is in "Use Sat>IP frontend parameter as channel group" mode, it should be possible to use the fe parameter in minisatip for channel group selection.
fe can be specified with -s
Zitat
-s --satip-servers [~][*][DELSYS:][FE_ID@][source_ip/]host[:port]
so in your case something like
-s 1@192.168.100.6
for letting minisatip use a tuner at 192.168.100.6 with fe=1 (channel group A). However, I have never tried this. For more information see here.
  • Like 1
@Griga
v
i have issue in transcode!
Quote
03.04.26 14:56:34.740 TFFMPEGLiveTVConverter OnTerminated     3753488571
03.04.26 14:56:36.584 TDVBHTTPClient ($06EDB1D0) SessionClosed    FFmpegConverter released
03.04.26 14:56:36.998 TRTSPWebserver       ClientConnect    06EDB1D0
03.04.26 14:56:36.999 TRTSPWebserver       ClientDisconnect 06EDB1D0
03.04.26 14:56:37.497 Release              Digital Devices DVB-S/S2 Tuner 2 (5)
03.04.26 14:56:37.497 Free                 Digital Devices DVB-S/S2 Tuner 2 (5)
03.04.26 14:56:37.502 Freed                Digital Devices DVB-S/S2 Tuner 2 (5)
03.04.26 14:56:37.502 hamDeleted           Digital Devices DVB-S/S2 Tuner 2 (5)
03.04.26 14:56:38.649 TDVBHTTPClient ($06EDB1D0) CreateTranscodedStream preset=WebM%20Audio%20128%20kbit&track=0&chid=4684871721111519243%7CBahrain%20Radio%20Arabic%20102.3%20FM
03.04.26 14:56:38.649 TDVBHTTPClient ($06EDB1D0) CreateTranscodedStream 127.0.0.1 VLC/3.0.21 LibVLC/3.0.21
03.04.26 14:56:38.649 Converter Start cmd  -analyzeduration 1000k   -i "http://127.0.0.1:7522/upnp/channelstream/transcode/4684871721111519243%7CBahrain%20Radio%20Arabic%20102.3%20FM.ts?target=127.0.0.1" -f webm -map 0:a:0 -acodec libvorbis -ab 128k -ac 2 -y "\\.\pipe\Output{CE19D99C-6D15-4583-B558-26869E3CD7EE}"
03.04.26 14:56:38.703 TStreamManager       GetDocument      Lavf/61.7.100
03.04.26 14:56:38.703 TStreamManager       GetDocument      c:\wwwroot\upnp\channelstream\transcode\4684871721111519243|Bahrain Radio Arabic 102.3 FM.ts
03.04.26 14:56:38.703 TStreamManager       GetDocument      target=127.0.0.1
03.04.26 14:56:38.817 TBDADigitalDevices   OpenDevice       bvDigitalDevices
03.04.26 14:56:38.817 TLiveStream          AllocateHardware Digital Devices DVB-S/S2 Tuner 2 (5)
03.04.26 14:56:38.817 TBDADigitalDevices   SetTuner         TType: 1, Freq: 12226, Symrate: 27500, LOF: 10600, Tone: 1, Pol: 0, DiseqC: 3, FEC: 3, APID: 800, VPID: 0, PMT: 801, SID: 11, TID: 514, NID: 702, SatMod: 1, DiseqCVal: 0, Flags: 16, Group: 0
03.04.26 14:56:38.918 Plugin 0137EDB8      SetTuner SID=11
03.04.26 14:56:38.918 TStreamManager       ClientBgException EAccessViolation: Zugriffsverletzung bei Adresse 776E41F0 in Modul 'ntdll.dll'. Schreiben von Adresse 00000054
03.04.26 14:56:38.919 Add TSCall
03.04.26 14:56:38.919 AddPID               0
03.04.26 14:56:38.919 AddPID               801
03.04.26 14:56:38.919 Plugin 0137EDB8      UnSetTuner SID=11
03.04.26 14:56:38.920 Del TSCall
03.04.26 14:56:38.923 TFFMPEGLiveTVConverter OnTerminated     3753488571
any idea?
Edited by Nayef
Try it without plugins. Same problem?
same issue  on v3.3.1.12 & v3.3.1.14
no issue on v3.3.1.9
i try now v3.3.1.14
Quote
http://192.168.100.6:8089/upnp/channelstream/4684871686844581656%7CJordan%20Radio%20Foreign.ts
this direct http = working fine
but when try transcode hls:
Quote
http://192.168.100.6:8089/upnp/master.m3u8?preset=HLS%20Mid%201200%20kbit&track=0&chid=4684871686844581656%7CJordan%20Radio%20Foreign
= not working
here log
svcdebug.log
Edited by Nayef
I have tried with Kuwait Radio 1 from Hotbird 13e 12399 H
http://192.168.178.28:8089/upnp/master.m3u8?preset=HLS%20Mid%201200%20kbit&track=0&chid=4648314273717617558%7CKuwait%20Radio%201
No issue here.
vor 6 Stunden schrieb Nayef:
There were no changes in the Live Stream Server between 3.3.1.9 and 3.3.1.14.
The issue happens here
Zitat
04.04.26 13:53:48.919 Plugin 0145EDB8      SetTuner SID=1816
04.04.26 13:53:48.920 TStreamManager       ClientBgException EAccessViolation: Zugriffsverletzung bei Adresse 77B841F0 in Modul 'ntdll.dll'. Schreiben von Adresse 00000054
The access violation (forbidden memory access) is reported by the network library used by the Media Server. It actually happens in a Windows DLL (ntdll.dll) outside the Media Server code.
Nevertheless it may be caused by the Media Server or a plugin. But I don't know why, because I cannot reproduce it.
vor 5 Stunden schrieb Nayef:
can i use ffmpeg 8.1 ?
Most likely yes. But it is untested.
Final & Best result for VDR:
Quote
[satip]
-d 13
-s 192.168.100.6:554|DVBS2-1:S260.1E|Badr:0xDF;192.168.100.6:554|DVBS2-4:S70.2W|Nilesat:0xDF;192.168.100.6:554|DVBS2-8:S130.3E|Hotbird:0xDF
bold = fe ...
0xDF = this Magic Code for best picture
and minisatip run 2 tuner as service:
Quote
[Service]
ExecStart=/usr/local/bin/minisatip -f -N -a 2:0:0 -O -s 3@192.168.100.6:554 -O -s 3@192.168.100.6:554  -o 127.0.0.1:11400 -H 5:50 -y 554 --client-send-buffer 4096 -R /home/user/minisatip/html
 2:0:0 = tuners
3@192.168.100.6:554 = fe ...
You are becoming a true "Sat>IP with Linux" expert :)
I have sent you another PM, just for finishing this topic.
  • Like 1
