vini Posted July 13, 2005 Share Posted July 13, 2005 (edited) Hi, Just bought an Airstar2 card. Technisat is providing a version of DVBViewer. However, I thought to buy the pro version. Do you recommend it? is it worth buying it? what advantages will i get regarding the use of a DVB-T card? Cheers Edited July 13, 2005 by vini Quote Link to comment
Guest Oliver Posted July 13, 2005 Share Posted July 13, 2005 http://www.DVBViewer.com/oliver/Einfuehrun...ml#einfuehrung2 As a customer you'll get both the Pro and the GE. The GE is better suited for older systems. Quote Link to comment
antdude Posted December 28, 2005 Share Posted December 28, 2005 Hi, Just bought an Airstar2 card. Technisat is providing a version of DVBViewer. However, I thought to buy the pro version. Do you recommend it? is it worth buying it? what advantages will i get regarding the use of a DVB-T card? Cheers <{POST_SNAPBACK}> vini: I am thinking of the doing the same. What did you think of it the card and software so far? It's alright to me. Quote Link to comment
