Is it possible to program this frequency?
الهاوي
Use TransEdit to add the frequency and other parameters to an existing transponder list. Or if you have no transponder list for the satellite position, use TransEdit to create a new one.
After the frequency has been added, you can scan it in TransEdit (or DVBViewer, after the changed list has been saved) and search for channels.
