DVBViewer 3.2.1 out
Guest Lars_MQ
Guest Lars_MQ
Some of you surely noticed it cause the DVBViewer told you so on startup. Christian released Version 3.2.1.
This version is a bugfix release no new feature in there.
Fixes:
- version number is now correct
- EPG-Window - every channel was named "E4+1 (NAR)"
- OSDskin initialising problem (cures also the scheduler problem)
- Weatherpage Red button only works after a move
- Resume of DVD playback didn't work correctly
- Default for instant recordings set to 23:59 h . Please check in the options.
- Fix for standstill of DVBViewer after serveral tuned channels.
- Fix channellist sometimes wasn't saved.
- Afterrecord action was executed although a second recording was running.
Have fun
Lars
what about the lock effect when timeshift is active and a transponderswitch is scheduled? I've had it twice already. Since it's possible that timeshift gets activated after the DVBV was in slumbermode you'd have to deactivate automatic timeshift as a workaround.
What about Options/ Recorder/ Timeshift/ Display warning on channel change if timeshift is enabled?
Does unticking it solve the problem? It should stop timeshift without a warning, if DVBViewer switches channel due to a scheduled recording. Here it does, without any lock.
the thing is that 3.1 didn't care about this. I like to have the warning in place in case i accidentally try to switch the channel while timeshifting.
Well, I tried it with 3.1. It did care. Stopped timeshift, started recording.
Anyway, thanks for the hint. ;) I wasn't aware of this issue, and didn't handle it in DVBViewer GE up to now. I think I'll simply give scheduled recordings a higher priority than timeshift.
hi, new version doesnt remember Scheduled recordings here, when I exit DVBViewer 53 bytes file timers.xml is always saved.
<?xml version="1.0" encoding="UTF-8"?>
<settings/>
when i run it with my old timers.xml nothing is shown in Record Settings... and above timers.xml is overwrites old .xml when I exit, no matter what i add, remove etc..
any idea where whats wrong? ;)
Edit: It seems it saves timers.xml right (??), but it gets overwritten with next start and exit of DVBViewer.
EDIT2: Hmz fixed... It does only when Airstar (compatible) was selected as current device, with Flexcop based cards selected works fine. goodie ;)
So my question is whats the different between those two devices? I have Airstar 2 PCI. thx
Edited by jakub
Always a pleasure to help you.
Guest Lars_MQ
The (compatible) device is for the new 64 bit drivers. Normally you should stay with the Flexcorp based cards.
One word of warning:
Please do not download the Version 3.2.1 for now.
The seems to be a hard to reproduce error in the new EPG-Parser.Griga and Christian are working on it and there will be a fix today.
Guest Lars_MQ
In fact it only stops timeshift if the recording is on another transponder.
I removed the warning for timeshift in case a scheduled recording tries to switch the transponder. So you get warned if you're timeshifting and try to switch (in case you enabled the warning), but if a recording does start on another transponder the timeshifting will be stopped without warning.
sounds like a very goog solution ;)
Guest Lars_MQ
The updated Version (V 3.2.1.190) is available for download.
BUG ALERT
OK, hit me, i found another bug in 3.2.1.190. ;)
After record action kicks in while other recording is running. With popup and everything. Clicking abort will leave the other recording running. Didn't try not clicking abort though.
Recordings:
P7 15:40-15:50
P7 15:43-16:00
edit:
and another one
I was listening to Jump when th timer for K1 kicked in. Timeshift got activated and on opening the recording file the recording would abort.(happend before with 3.1.2/3.2.0 also)
Edited by aydan
There seems to be a new bug , lastest Transedit not recognized DVDVIEWER!!!!!!!!
Guest Oliver
No problem here. What's the version number of your Transedit, though?
@dj31cool: Can you please check if the file channels.dat is write-protected?
Ups my fault,channels.dat was not present in DVBViewer folder :)
Now it scans perfectly.THX
  • 3 weeks later...
EPG is no longer for me working in DVBViewer 3.2.1 ( I previously had 3.0). It shows no channel names or times.
Is this a known bug. Is there a fix/workaround?
Best regards
Steve.
did you try to delete the EPG.dat?
did you delete the sat-positions in the channel-list that are not required?
maybe that helps :)
