HASAN ACAR Posted July 18 Posted July 18 (edited) Dear DVBViewer Geliştirici Team, First of all, thank you for providing such a powerful and stable media center application. I am a registered and licensed user of DVBViewer Pro (Registered Email: [removed]). I am currently running DVBViewer Pro on a Windows 11 Pro system equipped with a TBS6904SE DVB-S2X Quad Tuner PCIe Card. While the overall software performance is excellent, I am experiencing a specific UI/hardware status bug regarding the signal indicators: 1. In the DVBViewer status bar, the "Signal Strength" bar works perfectly and shows the correct values. 2. However, the "Signal Quality" bar is completely missing or not rendering at all in the interface. 3. To isolate the root cause, I tested the exact same hardware configuration and official TBS BDA drivers on the same PC using alternative software (DVB Dream). In the alternative software, the signal quality bar functions flawlessly and updates in real-time. This technical cross-check confirms that the TBS6904SE BDA driver successfully exposes the signal quality metrics via standard Windows BDA architecture (IBDA_SignalStatistics), but DVBViewer Pro is currently unable to parse or visually render this specific data from this tuner model. As a loyal licensed customer, I kindly request your development team to investigate the BDA status command handling for the TBS6904SE card in an upcoming update so that the missing signal quality indicator can be restored. Thank you very much for your time, support, and continuous development. Best regards, Hasan Acar Email: [removed] OS: Windows 11 Pro Hardware: TBS6904SE DVB-S2X Tuner PCIe Card Edited July 18 by HaraldL Email address removed to protect your privacy and not needed for answering Quote
Griga Posted July 19 Posted July 19 vor 18 Stunden schrieb HASAN ACAR: I am experiencing a specific UI/hardware status bug regarding the signal indicators: (...) the "Signal Quality" bar is completely missing or not rendering at all in the interface. It's no bug, but rather a design decision. In the past we found that many devices or their BDA drivers don't report meaningful values either for the signal strength or the quality. In some cases even both were almost unusable. So the decision was to pick the "better" value for displaying it in the status bar and drop the other one, in order to avoid that users get confused by junk data. Anyway, a solution might be to make the display switchable between signal strength and quality in future, so experienced users can select what they want. Will be considered... 3 Quote
HASAN ACAR Posted July 22 Author Posted July 22 Thank you very much for your prompt reply. I also appreciate your help. I wish you continued success 1 Quote
Frankobert Posted July 23 Posted July 23 On 7/19/2026 at 7:32 AM, Griga said: Anyway, a solution might be to make the display switchable between signal strength and quality in future, so experienced users can select what they want. Will be considered... Das fände ich auch gut! Quote
Griga Posted July 24 Posted July 24 @Frankobert If you want to post something in the English section of the forum, please write in English! If you can't, use a Google translation. 1 Quote
