RizSilverthorn Posted July 25, 2005 Posted July 25, 2005 I have a registered version of DVBViewer, and the Airstar 2 PCI. I want to scan for Terrestrial DVB channels but I am not given the option to scan for them in the Channel Scan. Am I missing something so obvious I cannot see it? I checked and the Europe.ini file (which seems to contain details of the DVB-T channels) is there, but the list of available settings only contains sattelites. Quote
asliebe Posted September 18, 2005 Posted September 18, 2005 open your channel list select the "Channel Scan" tab right klick somewhere in the window and select terristical close the channel list and open it again now you should have the terristical scan menu Quote
wynton Posted September 18, 2005 Posted September 18, 2005 I have the same trouble. I can't scan terestrial channel. I have only satelits. In the channel list, i select to import channels. The path send to europe transponders, but i always have frequency for dvb-s. I don't understand. I have the last DVBViewer, but it's the demo. I don't want to buy it if the soft don't work at home. Thanks for your help. Quote
ehafner Posted October 5, 2005 Posted October 5, 2005 Yes. I have the same problem. Before installing the new release it worked. But maybe. I installed also DVB-ViewerTE (this works) in a newer release before and nobody knows what two DVB-viewers on the same PC will do with the system. But it worked before installing 3.2.4. Would be great if someone has a fix for this problem that I can work with the fullVersion again. Thanks in adavance. ERNST Quote
eeansa Posted October 7, 2005 Posted October 7, 2005 Yes. I have the same problem. Before installing the new release it worked. But maybe. I installed also DVB-ViewerTE (this works) in a newer release before and nobody knows what two DVB-viewers on the same PC will do with the system. But it worked before installing 3.2.4. Would be great if someone has a fix for this problem that I can work with the fullVersion again. Thanks in adavance. ERNST <{POST_SNAPBACK}> Hi, me too. I've been using DVBViewer full version since 2.3 beta and not had these problems. I downgraded back to 3.23 and updated again to 3.24. Even old saved channellist doesn't work with 3.24. It worked fine after downgrading back to 3.23. Rightclicking on channel scan tab and selecting terrestrial doesn't help. After closing and opening once more it's again in satellite mode. Tried this for several times. Hopefully will be corrected soon. Quote
