crash when closing the application
stax
does happen not always but often, anybody a idea for possible reasons? What things can I try to fix it or is occasional unexpected behavior not unusual? (I'm new to DVBViewer)
Regards,
stax
Link to comment
any logs?
Systemlog or DVBViewer.log?
And what version with which card we are talking about?
Link to comment
DVBViewer.log
02.08.2005 22:20:11 EAccessViolation raised by instance Object8 of class TSkinButton at 00494CD4:Zugriffsverletzung bei Adresse 00494CD4 in Modul 'DVBViewer.exe'. Lesen von Adresse 0000005C
02.08.2005 22:20:13 EAccessViolation raised by instance Object8 of class TSkinButton at 00494CD4:Zugriffsverletzung bei Adresse 00494CD4 in Modul 'DVBViewer.exe'. Lesen von Adresse 0000005C
02.08.2005 22:21:05 EAccessViolation raised by instance Object8 of class TSkinButton at 00494CD4:Zugriffsverletzung bei Adresse 00494CD4 in Modul 'DVBViewer.exe'. Lesen von Adresse 0000005C
02.08.2005 22:24:18 EAccessViolation raised by instance Object8 of class TSkinButton at 00494CD4:Zugriffsverletzung bei Adresse 00494CD4 in Modul 'DVBViewer.exe'. Lesen von Adresse 0000005C
02.08.2005 22:31:16 EAccessViolation raised by instance Object8 of class TSkinButton at 00494CD4:Zugriffsverletzung bei Adresse 00494CD4 in Modul 'DVBViewer.exe'. Lesen von Adresse 0000005C
Thanks for the quick response. I don't know where to find the system log. I have DVBViewer 3.2.1 and a SS2 newest version I think.
Another shutdown problem I have is when I use a skin, there is a OSD message box asking if I really would like to shutdown. Usually I'm quite sure about it so I would like to disable the message box. The shutdown option "Timeout for shutdown warning" set to 0 did not help. I'm wondering why such a message box is related to if a skin is used, if I don't use a skin, no message box.
Edited by stax
Link to comment
