Minimal Installation
ardee
I've been trying to install GE onto a new drive using only the files essential for it to work.
I have ended up with no sound or picture, but the EPG is OK. Also, it will play back an MPEG file, so the codecs are working.
Can anyone suggest what is missing?
Is there a list of which Technisat files are actually needed for GE to work?
Thanks.
...only the SS2 card driver, of course!
But if EPG is fine it mean the driver is OK...
Maybe in your PC is missing the Directx 9.0c and/or MS Mediaplayer>7.0?
Edited by Gioxy
Thanks for the reply.
I've now discovered that enabling the "Auto Update Channel" function solves the problem.
I asked about which files are necessary because I remember having problems with DVBViewer if the server/setup4PC files were removed.
