biffa Posted September 9, 2005 Posted September 9, 2005 I am searching for a channel listing for Astra 28 (ie. all the UK sky channels, bbc etc); After installing the latest dvb, I only see astra19 and hotbird listed. Is there any easy way of finding/getting/adding all the Astra 28 listings in a readable fashion. I couldn't see a ROOT satellite in the edit channels/scan channels that corresponded to Astra28, so maybe some kind person out there already has one with a readme...? Quote
FEFX Posted September 11, 2005 Posted September 11, 2005 (edited) Hi, I have a channel list for you 28.2.zip Edited September 11, 2005 by FEFX Quote
biffa Posted September 12, 2005 Author Posted September 12, 2005 Hi, I have a channel list for you <{POST_SNAPBACK}> that is so very cool. thanks very much. was that easy to generate? I tried scanning the whole spectrum again, but it screwed up my other listings then DVBViewer simply 'hung' when I tried to exit. Anyhow, great job in time for the cricket... Quote
FEFX Posted September 13, 2005 Posted September 13, 2005 Hi, I had no problems to generate the list, I just scanned the satellite and sorted the list. Quote
FEFX Posted September 13, 2005 Posted September 13, 2005 Hi, I just made a new scan because the list was some weeks old. In the zip you'll find an unsorted list, like it was after the scan and the list you already have with some channels updated (mostly bbc...) 28.2_13.09.05.zip Quote
biffa Posted September 15, 2005 Author Posted September 15, 2005 Great stuff, thanks again. Now I just need to stop DVBViewer hanging everytime I import lists and try to exit (thereby losing the imported list every time). Keeps me active at the weekend if nothing else... Quote
FEFX Posted September 15, 2005 Posted September 15, 2005 (edited) You can try to import the channels from the attached channels.dat by using the Channel list editor. So you don't have to start the viewer to import the channels. You can get the editor in the members area. good luck Felix channelsdat.zip Edited September 15, 2005 by FEFX Quote
biffa Posted September 16, 2005 Author Posted September 16, 2005 that worked! That gives me some more time to sort out the hang problem. Cool. Quote
