Jukka Posted September 15, 2005 Share Posted September 15, 2005 (edited) When I try to watch OSD-teletext, the screen goes white. setup_txt.txt Win XP Pro SP2 Twinhan VisionDTV MiniCab Edited September 15, 2005 by Jukka Quote Link to comment
Guest Lars_MQ Posted September 16, 2005 Share Posted September 16, 2005 Are you sure the channel has teletext? Indeed there is a minor bug. Normally the Teletext page should not be accessible if a channel doesn't have teletext. but somehow the mechanism for this gets circumvented Quote Link to comment
Jukka Posted September 16, 2005 Author Share Posted September 16, 2005 Are you sure the channel has teletext? Indeed there is a minor bug. Normally the Teletext page should not be accessible if a channel doesn't have teletext. but somehow the mechanism for this gets circumvented <{POST_SNAPBACK}> Yes, the channels I tried have teletext. In one channel (MTV3 Finland), teletext comes but it's not possible to choose page number, only press teletext button again. All other channels white screen comes. I imported channel list from the old version of DVBV. I installed DVBV 3.2.2 in different folder than 3.2.1, but old version still exists on my computer. Could this be the reason? In old version, teletext works normally. Quote Link to comment
absalomi Posted September 16, 2005 Share Posted September 16, 2005 Same problem here, clean new install. Quote Link to comment
Guest Lars_MQ Posted September 16, 2005 Share Posted September 16, 2005 @absalomi do you also use a twinhan? Quote Link to comment
Adam T. Posted September 16, 2005 Share Posted September 16, 2005 Same problem here on SkyStar2. Teletext in window works OK. Quote Link to comment
Adam T. Posted September 16, 2005 Share Posted September 16, 2005 (edited) Same problem here on SkyStar2. Teletext in window works OK. EDIT: Sorry for double post. Edited September 16, 2005 by Adam T. Quote Link to comment
JustCute Posted September 16, 2005 Share Posted September 16, 2005 i had the same problem, but after modifing the osd menu it disapeared ? ! Quote Link to comment
Jukka Posted September 20, 2005 Author Share Posted September 20, 2005 Any new about this? I installed missing files but still OSD-teletext keeps white screen. Quote Link to comment
Klausing Posted September 21, 2005 Share Posted September 21, 2005 for me it works perfect Quote Link to comment
Gioxy Posted September 21, 2005 Share Posted September 21, 2005 (edited) Also for me (SS2 2.3 PCI on XP with DVBViewer 3.2.3 dated 15-9-05 installed on a brand new folder), windowed teletext is OK but OSD-Teletext is a white screen... I tested also trough various filter/output with the same result; all other OSD related function/screens are OK... Edited September 21, 2005 by Gioxy Quote Link to comment
damjang Posted September 21, 2005 Share Posted September 21, 2005 (edited) Hese it's the same: white screen... win XP sp2 & SkyStar2... and DVBViewer v3.2.3 installed over 3.2.1 damjang Edited September 21, 2005 by damjang Quote Link to comment
VSoft Posted September 22, 2005 Share Posted September 22, 2005 (edited) After intalling version 3.2.2 over 3.1.0 I have no OSD (also no recording mark or Volume Control). After calling the EPG skin or option menu the menu bar ist not working. Other problem: I have since some time no EPG-information for VOX. Klaus System: Skystar 2, Windows XP SP2, ATI 9800 Update: --------- After installing to a new directory anything works fine. Setup.xml Edited September 22, 2005 by VSoft Quote Link to comment
IRa Posted September 22, 2005 Share Posted September 22, 2005 Yes, the channels I tried have teletext. In one channel (MTV3 Finland), teletext comes but it's not possible to choose page number, only press teletext button again. All other channels white screen comes. I imported channel list from the old version of DVBV. I installed DVBV 3.2.2 in different folder than 3.2.1, but old version still exists on my computer. Could this be the reason? In old version, teletext works normally. <{POST_SNAPBACK}> Same thing. It works just grazy in 3.2.3, all canells except MTV3 gets the white screen. After visiting on MTV3 also Chanell nelonen works but if I try it after starup it gets white. When you get something on screen the clic on page number in teletext pages works as well as remote page down/up but giving the page number does not work. It worked OK in 3.2.1. I have Airstar 2 card. Quote Link to comment
Jukka Posted September 28, 2005 Author Share Posted September 28, 2005 i had the same problem, but after modifing the osd menu it disapeared ? ! <{POST_SNAPBACK}> Do you remember what you modified? I have still same problem and I'd like to solve it, or else I have to go back version 3.2.1. Quote Link to comment
Jukka Posted October 1, 2005 Author Share Posted October 1, 2005 Same problem with 3.2.4. Quote Link to comment
damjang Posted October 5, 2005 Share Posted October 5, 2005 I have installe dthe 3.2.4 and the teletext work ok. But there is only one type od teletext - there is not transparent ttx (in old DVBViewer there is two options of ttx: normal and with trasparent background!). damjang Quote Link to comment
Gioxy Posted October 5, 2005 Share Posted October 5, 2005 I confirm, also in v. 3.2.4 there is the hated "white OSD-Teletext" bug Quote Link to comment
Jukka Posted October 12, 2005 Author Share Posted October 12, 2005 Any new about this? Still the same problem and I'd like to watch teletext using OSD. Quote Link to comment
Guest Lars_MQ Posted October 12, 2005 Share Posted October 12, 2005 I think the problem is solved. There was a problem with the subpages in teletextpages (only in OSD-Teletext). When Christian returns from his vacation we will test the fix. Quote Link to comment
Jukka Posted November 4, 2005 Author Share Posted November 4, 2005 I think the problem is solved. There was a problem with the subpages in teletextpages (only in OSD-Teletext). When Christian returns from his vacation we will test the fix. <{POST_SNAPBACK}> Works ok with 3.2.5. Thank you. Quote Link to comment
