emilot Posted September 17, 2005 Share Posted September 17, 2005 Hello, With the new version 3.2.3, when i choose ChannelList... from the Menu, i get nothing, no window, no nothing... I made upgrade, i made clean install, nothing. Quote Link to comment
bdurren Posted September 18, 2005 Share Posted September 18, 2005 Hello, With the new version 3.2.3, when i choose ChannelList... from the Menu, i get nothing, no window, no nothing... I made upgrade, i made clean install, nothing. <{POST_SNAPBACK}> Same behaviour here but I have found the solution. The fact is that the windows is "out of range". Open the channel window, then alt+space. Use up and left in order to move the window in the upper left corner, enter to validate. Quote Link to comment
emilot Posted September 18, 2005 Author Share Posted September 18, 2005 Hello, With the new version 3.2.3, when i choose ChannelList... from the Menu, i get nothing, no window, no nothing... I made upgrade, i made clean install, nothing. <{POST_SNAPBACK}> Same behaviour here but I have found the solution. The fact is that the windows is "out of range". Open the channel window, then alt+space. Use up and left in order to move the window in the upper left corner, enter to validate. <{POST_SNAPBACK}> Thank you, problrm solved!! Quote Link to comment
