OSD-Sleeptimer
Guest Lars_MQ
As always found in the membersarea.
OSD Sleeptimer Plugin 1.0 for DVBViewer 3.2.2+
Installation:
extract the contens of the zip file with folders into the DVBViewer folder.
Use:
The osd-sleeptimer can be found in the OSD-Mainmenu.
Start : Starts the sleeptimer with the selected time and endaction. Once startet the time and endaction can not be changed.
Stop : Stops the sleeptimer
Back : Goes to the previos OSD-Page
Timesettings : you can use the up-down arrows to change the value or you can simple use the Channel 0 - Channel 9 control buttons to enter the countdown time in minutes (max 120 minutes).
Endaction : here you can select the action to be perfomed when the alarmtimer fires.
have fun
Deutsche Version
  • 1 month later...
Guest Lars_MQ
I've uploaded a little update for the sleeptimer Plugin.
Now a Button called "Use EPG-Time" puts the remaining time of the current running program (if there is epg) + 1 minute into the "time to run", so you don't have to calculate how long the program will run :wacko:
One thing: the Plugin puts the countdown when running into the Datatag #SleepTimer.Current and updates it every second, so you can use it elsewhere in the skin.
have fun.
lars
  • 1 year later...
An update for the Sleeptimer can be found in the membersarea.
Changes in 1.1.0
- Fixed not saving of lastused values.
- Reworked the skin file.
- Added support for colorbuttons.
- Added basic translations capabilities.
- Changed the max. minutes to 360.
  • 2 years later...
OSD Sleeptimer don't work if I use Default Widescreen Skin (NewDefWide skin Version 1.3)..
How I can to OSD Sleptimer show when use Osd Default widescreen skin, any idea?
Problem resolved. I copy mysleeptimer.xml to NewDefWide osd skin folder..
  • 6 months later...
Hello , can someone help mi with a minor problem, please?
I use DVBViewer BETA 4.3.1.160 , installed Concinnity OSD skin and sleeptimer.dll to plugin ( folder ).
Functionality is ok but when I open Main Menu I can not see image of sleeptimer ( even home_sleeptimer.png is in image folder )
Also , I can not set/unset sleeptimer in OSD Menu ( Options )
what should I do? ( configure? change? )
Thanks in advanced.
Peter
  • 13 years later...
Hello!
Is it possible that Sleeptimer plugin 1.1 is not compatible with the new version 7.3.0.0?
I got an error message: Exeption EConvertError in module mysleeptimer.dll at 0000658A
Am 25.6.2024 um 23:17 schrieb Géza Színes:
You are right. I can reproduce the error. It happens due to a module that was removed in 7.3.0 because it was assumed to be useless.
If you want, you can have a test version where the Sleeptimer works again.
  • 1 month later...
vor einer Stunde schrieb Géza Színes:
Should I try the 7.3.0.1 beta?
No. Rather use the 7.3.0.3 test version that I have attached to a personal message. You just have been invited to the PM conversation.
Thank you!
I apologize. I do not use this interface. So I didn't notice.
It works with 7.3.0.3
Thanks again.
