jepe Posted October 16, 2005 Share Posted October 16, 2005 I have the last version DVBViewer Recording in .ts format works fine. Using ProjectX to demux the file in video,all audios and subtitles,I have as information given by ProjectX : no PMT found ! So that I only get one video file and one audio file. Not the other audio stream nor subtitles. Is there a reason for this? Recorded files with DVBportal in .ts format,and demuxing in the same way gives all PIDs recognized by ProjectX Quote Link to comment
Griga Posted October 16, 2005 Share Posted October 16, 2005 no PMT found ! Just tried - obviously DVBViewer Pro saves TS files without PAT & PMT. You may use the Videorecorder Plugin, that allows to record all the tables and program elementes resp. PIDs you need. Quote Link to comment
Guest Oliver Posted October 16, 2005 Share Posted October 16, 2005 Soweit ich mich erinnere, hat die Pro-Version die PMT nie mit aufgenommen. Allerdings habe ich die auch noch nie gebraucht. Quote Link to comment
Guest Lars_MQ Posted October 16, 2005 Share Posted October 16, 2005 So that I only get one video file and one audio file.Not the other audio stream nor subtitles. Is there a reason for this? Yes. It's not needed. ts recordings is only video + audio. if you want more PIDs use for now the videorec plugin. Quote Link to comment
jepe Posted October 17, 2005 Author Share Posted October 17, 2005 (edited) So that I only get one video file and one audio file.Not the other audio stream nor subtitles. Is there a reason for this? Yes. It's not needed. ts recordings is only video + audio. if you want more PIDs use for now the videorec plugin. <{POST_SNAPBACK}> Thank you. Edited October 17, 2005 by jepe Quote Link to comment
jepe Posted October 17, 2005 Author Share Posted October 17, 2005 Thank you. Now at least I have the txt pid,but not the additional audio recorded. I have ticked all the pids cases in the video plugin rec.,checked that the programme has two languages,but nothing to do : only one audio stream is recorded... Any idea? Jepe P.S. : In the main channel list comes two reference for that channel:one for each audio stream.Maybe,is this affecting the video rec plugin? Quote Link to comment
Griga Posted October 17, 2005 Share Posted October 17, 2005 In the main channel list comes two reference for that channel:one for each audio stream.Maybe,is this affecting the video rec plugin? No, that's ok. What tells you that there is only one audio stream in the file? Are you sure that the PID is correct? Does the channel really broadcast the second audio stream? If there is a PID, but no data coming in, it can't be recorded. I just tried to record EuroNews with 6 different audio tracks resp. languages (DVBV Pro & VRPlugin) - no problem. So I don't know... Quote Link to comment
Guest Lars_MQ Posted October 17, 2005 Share Posted October 17, 2005 I tried the same configuration like griga with Pro 7 + AC3, projectX produced a mpv, mpa and ac3 file so it's working. Quote Link to comment
Derrick Posted October 17, 2005 Share Posted October 17, 2005 ..unbelievable, the incomplete .ts recording of the dvbviewer_pro must have slipped my mind What is the use of that? Quote Link to comment
