musukebba Posted October 19, 2005 Posted October 19, 2005 Does DVBViewer support multiple DVB-T cards, to allow overlapping recordings or watch another channel whilst recording another? Hauppauge have BDA drivers which makes this happen under MCE or (dare I say the name...) Media Portal under XP. I know it's possible if both channels are on the same mux, but is it at least possible to open two instances of DVBViewer, each using a different card? Searched for forum info, but nothing relevant... Quote
musukebba Posted October 27, 2005 Author Posted October 27, 2005 OK I see you've answered the question from someone else in the plugins forum. Quote
Klausing Posted October 27, 2005 Posted October 27, 2005 yes its possible if you use DVBViewerPro for first record and DVBViewerGE for second record and second card. Quote
musukebba Posted October 29, 2005 Author Posted October 29, 2005 (edited) Hi Klausing Thanks for the reply and that's interesting that you can do that. The only problem is that in DVBViewerGE v1.6 there doesn't seem to be a way of selecting either of the DVB-T cards that I have installed. There isn't the dialogue box which appears anywhere on the 'Options' tabs (like the 'DirectX' option in DVBVPro), as far as I can see, and I can't tune into anything. Both cards I have are BDA compliant and work very well independently with DVBViewerPro v3.2.3. Is there something I'm missing? Edit: I have tried with the TransEdit application, as suggested by Christian in reply to another post. However the cards are still not detected. Edited October 29, 2005 by musukebba Quote
musukebba Posted November 3, 2005 Author Posted November 3, 2005 Any advice on how to select a tuner card in the GE version? Quote
Griga Posted November 3, 2005 Posted November 3, 2005 The GE available for download only supports SkyStar2/AirsStar2/CableStar2 cards. A version that addititionally works with BDA devices is already running here pretty well and will be released... well, I don't know. Before christmas. Quote
Klausing Posted November 3, 2005 Posted November 3, 2005 Sorry i thought one of your cards is a B2C2-based card. In this case it should work. But in your situation you have to wait for new release of GE-Version. Quote
musukebba Posted November 5, 2005 Author Posted November 5, 2005 (edited) OK many thanks guys - that explains it. If you need beta testers for a Hauppauge Nova-T, I'd be happy to help out... M Edited November 5, 2005 by musukebba Quote
