OoZooN Posted November 6, 2005 Share Posted November 6, 2005 ProjectX 0.90.02.00 ist online. wie immer HIER hier der changelog: Project X 0.90.02.00 06.11.2005 collects all patches from 0.90.1 fixes: - loading cutpoint file via CLI didn't work - wrong samplerate value in the .wav/.aif header when decode mpa and active (but disabled) resample mode - LPCM demux: output in wrong byte-order - PES parsing: unwanted continued messages - ... changes: - little GUI re-arrangements, window problems - decode and normalize mpa: now restarts after a completed search for peaks, not on every peak change - demux: max. bitrate value entry (dvd) changed to 9Mbps (from 9.8) - pidfilter: simple cut feature added, means a partial 1:1 copy of (also filtered) stream data (pva,ts) - some settings changed to be standard now - ... new: - loading chapterpoint list file via CLI [-chp <file>], format depends on cut mode - simple relook's orig. fileformat splitter into .vpes/.apes (very few tests only) via context menu (blocks while processing), only meant for pre-processing - ... commandline problem: if you can't start the non-gui version without a X server, try to call pjx with the 'headless' option java -Djava.awt.headless=true -jar ProjectX.jar [options] <file> Quote Link to comment
OoZooN Posted November 26, 2005 Author Share Posted November 26, 2005 auf meiner homepage gibt es eine aktualisierte version. es ist jetzt französisch als sprache hinzugekommen. Quote Link to comment
Guest chris-nrw Posted December 3, 2005 Share Posted December 3, 2005 (edited) Hallo, habe mir dieses ProjectX auch mal installiert. Bei der Compilierung des Java-Packets hat er einen "Build" Ordner erstellt. Darf ich den wieder Löschen? Wenn ich das richtig verstanden habe ist das erstellte .JAR File eine gezippte Version dieses Build Ordners. In english: May I safely delete the Build folder after compiling PJX? Chris Edited December 3, 2005 by chris-nrw Quote Link to comment
KGM11 Posted December 3, 2005 Share Posted December 3, 2005 Bei der Compilierung des Java-Packets hat er einen "Build" Ordner erstellt. Darf ich den wieder Löschen? Ja. Quote Link to comment
