DVBViewer 3.2.5 -> Aspect Ratio
CX23882-19
In 3.2.5 I have a problem with aspect ratios where they will be correct for the channel that the graph is initialised on, but do not change if I tune to a channel that uses a different aspect ratio. The problem only occurs when changing channels via the Now/Next OSD panel and when Fast Channel Switching is on.
Example:
1) Start DVBViewer with it tuned to TMF (4:3 full screen)
2) Press I
3) Tune to BBC ONE (16:9 anamorphic) using Up/Down
BBC ONE will be stretched vertically to full screen.
This also goes the other way - i.e. if you start in an anamorphic channel and go to full screen, the full screen channel will be letterboxed.
Choice of decoders doesn't appear to make any difference - I'm currently using Sonic decoders but also tried InterVideo and Cyberlink. I have to use Overlay because my laptop doesn't fully support VMR7 or VMR9. I can select VMR7, but it still has the same problem (but I think that it uses an Overlay connection anyway).
System Config:
- SiS 630 chipset (VGA/Sound)
- BDA enabled USB 2.0 DVB-t card
- Windows XP SP2 Home with latest updates (quartz.dll is 6.5.2600.2749)
If I revert back to DVBViewer 3.2.4 I have no problems.
Edited by CX23882-19
Link to comment
