gibman Posted November 14, 2005 Share Posted November 14, 2005 (edited) I just bought DVBViewer and to my great surprise it wont run on my server PC. It runs fine on my laptop and on my other workstation. I have the exact same problem as this person here - same crash adresses etc. http://www.DVBViewer.com/forum/index.php?s...ic=9258&hl=asus As you can see on the attached images my error is the exact same - although it is in danish, I think you know what they mean hehe. I can run TransEdit 2.3.4 [edit 20 nov.2005] I can run DVBViewer 3.0.x I can run DVBViewer GE 1.7 I can run progDVB I can run mytheatre I can NOT run TransEdit 2.3.3 I can NOT run DVBViewer 3.2.5 I can NOT run DVBViewer 3.2.1 on a sidenote ; DVBserver.exe works on all builds, although latest 3.2.5 crashes when client connects with unicast -as someone already pointed out here on the forum. Where do I download older builds like. 3.2.4 ? They are not in the customer area ? Since I would like to start dvbserver.exe on my server, instead of having to wait for a fix that wont see the daylight anytime soon ? My Server's hardware/software config is; Asus K8V deluxe SE motherboard - via k8t800 / vt8237 win xp sp2 + latest windows update. amd 64 @ 1800mhz 1 GB RAM, pc2700 skystar2 PCI + driver 4.3.2 cirrus logic PCI gfx card, native XP drivers very old card - but I dont use overlay etc. on server. So having a low power GFX card is prefered. A usually remote desktop my server, and here I can start vers. 3.0 of DVBViewer and the video part is being sent to the remote desktop client just fint, along with the sound. This worked with progdvb also. I want to run DVBViewer on my server so I can record stuff locally, instead of doing it on the clients. DVBserver.exe has no recording facilities yet ? onboard audio is disabled. I have gathered all the interesting XML files - although I could not find; OSD.log OSDerror.log DVBViewer.log SystemInfo.txt windowdef.xml Perhaps DVBViewer doesn't get to the point where it writes these files. UPDATE: I just did some testing. I tried to remove one file at a time until I only had the DVBViewer.exe present in "C:\Programmer\DVBViewer". The exact same error happens. This might help debugging ? Regards Elo Rasmussen. Denmark. Software programmer. support.zip Edited November 20, 2005 by gibman Quote Link to comment
Guest Lars_MQ Posted November 14, 2005 Share Posted November 14, 2005 Please use the tool on this page (at the bottom) to gather the data. Unzip it into the DVBViewer folder and run it, it will create a zipfile with all needed data, which you can inspect (to see no personal information is send) and then upload it into the forum. Quote Link to comment
gibman Posted November 14, 2005 Author Share Posted November 14, 2005 Ok, here you go. /Elo support.zip Quote Link to comment
gibman Posted November 20, 2005 Author Share Posted November 20, 2005 Update: I tried the new version 2.3.4 of transedit and it works - it doesn't crash like the previous version did. /Elo Quote Link to comment
