Cablestar 2 - Lags in XP
Da_Phreak
i bought the Cablestar 2. I have a strange problem with it. From the time is install the driver for the card, my system has every 5-10 sec a Lag for 0.5 Sec. I think that is the problem with the lags on Media Portal too, and it is nerving me in normal working.
I tried the driver from the CD and the newest from the Technisat HP. But both have the same problem. I tried 2 different mouses, one PS2 and the other USB. But similar here the same problem.
I did a new XP Install, but if i install the driver for the card, the problem is going on. If i deactive the card in the device manager, the lags are away.
I bought it on dvbshop.net and there i searched help first, the owner had no idea anymore and said, that i should try my luck now here.
Here is the threat from that forum:
http://www.dvbshop.net/forum/viewtopic.php?p=10266#10266
It is no networking problem, i deactivated Firewalls, Antivirus programm etc. and pulled all Networking cables out of the pc.
Can someone help me? Thx Or i must send sadly the card back.
The support from Technisat directly was not good, and the meaned only old drivers. And gave no second response, but the drivers was all the newest versions.
My System:
Betriebssystem Microsoft Windows XP
OS Service Pack Service Pack 2
DirectX 4.09.00.0904 (DirectX 9.0c)
Motherboard:
CPU Typ AMD Athlon XP, 2079 MHz (12.5 x 166) 2600+
Motherboard Name Shuttle FN41 v3 (1 PCI, 1 AGP, 2 DDR DIMM, Audio, Video, LAN, IEEE-1394)
Motherboard Chipsatz nVIDIA nForce2 IGP
Arbeitsspeicher 992 MB (DDR SDRAM)
BIOS Typ Award (12/05/03)
Anschlüsse (COM und LPT) Kommunikationsanschluss (COM1)
Anschlüsse (COM und LPT) Druckeranschluss (LPT1)
Anzeige:
Grafikkarte NVIDIA GeForce4 MX Integrated GPU (32 MB)
3D-Beschleuniger nVIDIA nForce2
Monitor Samsung SyncMaster 907p(T)/950p(T)/957p(T)/MagicSyncMaster CM197A [19" CRT] (HVAT410035)
Multimedia:
Soundkarte nVIDIA MCP2 - Audio Codec Interface
Soundkarte nVIDIA MCP2 - Audio Processing Unit (Dolby Digital)
Datenträger:
IDE Controller NVIDIA nForce2 ATA Controller
Festplatte USB Flash Memory USB Device (486 MB, USB)
Festplatte SAMSUNG SP1614N (160 GB, 7200 RPM, Ultra-ATA/133)
Optisches Laufwerk _NEC DVD_RW ND-1300A (DVD+RW:4x/2.4x, DVD-RW:4x/2x, DVD-ROM:12x, CD:16x/10x/40x DVD+RW/DVD-RW)
S.M.A.R.T. Festplatten-Status OK
Eingabegeräte:
Tastatur Standardtastatur (101/102 Tasten) oder Microsoft Natural Keyboard (PS/2)
Maus Microsoft IntelliMouse Explorer 3.0 (USB)
Maus PS/2-kompatible Maus
Netzwerk:
Netzwerkkarte ADMtek ADM8513 USB To Fast Ethernet Adapter (192.168.2.102)
Netzwerkkarte NVIDIA nForce MCP Networking Controller (192.168.1.1)
Netzwerkkarte TechniSat DVB-PC TV Star PCI (169.254.178.3)
Peripheriegeräte:
USB1 Controller nVIDIA MCP2 - OHCI USB Controller
USB2 Controller nVIDIA MCP2 - EHCI USB 2.0 Controller
USB-Geräte ADMtek ADM8513 USB To Fast Ethernet Adapter
USB-Geräte Microsoft IntelliMouse Explorer 3.0 (USB)
USB-Geräte USB-Massenspeichergerät
My brother has a cablestar that also makes lags in windows. But if he starts DVBViewer and then closes it again it stops until he reboots of course.
Doesn´t work so at my PC and it would be no final solution. I don´t want to use the DVBViewer later, i take Media Portal. I only want that the card works correctly and without lags. The drivers for the card are from the same people that develops DVBViewer the owner of dvbshop said.
We develop no drivers here. They are from BBTI.
Did you already disable all network protocols for you card? They are not necessary for watching TV.
Yes i deactivated for the card the 4 standard network protocols in the network devices preferences.
Looks like i must try the last way at BBTI. Thx
With enabling a fake data service with Setup4PC, the lag problem is gone.
Hope this may help others with the same problem.
