Automatic Commercial Removal script
majstang
Features:
- Removes commercials automatically from recordings and launched right after Recording Service finish the recording. Done via a so-called "after recording task". Works only with Recording Service.
- Supports automatic commercial removal on as many simultaneously recorded shows RS allows.
- Removes commercials from both SD (MPEG-2) and HD (H.264) recordings.
- Drag and drop support. Finished recordings can be dropped on script for removal of commercials.
- Automatic Commercial Removal script can be combined with intelligent hibernation.
- Hidden mode. All parts of the tools used for commercial removal in script can be hidden entirely if preferred.
Required OS:
Windows 7 32-bit. This is the only OS I tested the script with so far. It may work with XP and Vista. No support for 64-bit Windows though.
Required tools:
- Autohotkey_L Unicode 32-bit. Can be downloaded here: http://www.autohotkey.com/download/
- Comskip v.0.80.039 or later. (Comskip is freeware, but only the MPEG-2 version. Getting Comskip H.264 version requires a donation)
- VideoReDo TVSuite H.264. Trial can be downloaded, but without registering for the trial key, it's limited to 15 minutes output. Once you register your trial, you're unlimited size for 15 days. (shareware $95.99)
Important things to know about more limitations and other conditions before setup:
- ALWAYS use .ts output format on your recordings. Script will NOT work with .mpg recordings.
- Installing of Autohotkey_L Unicode 32-bit is a must. If having Autohotkey_Basic uninstall it and intstall Autohotkey_L and make sure to choose Unicode. If you have old Autohotkey_Basic scripts on HTPC it is not certain they will work with Autohotkey_L Unicode. For example the old Intelligent Hibernationscript won't work. I will post a new one in here which is adapted to work with both Autohotkey_L Unicode and the Automatic Commercial Removal script.
- No support with DVBViewer (if using DVBViewer as a standalone recorder and no support for commercial removal on Live-TV ).
- Drag and dropping recordings on script which is still in recording progress will not work. Use this feature for finished recordings only. I don't think there's a limit on how many recordings can be dropped on script at once for commercial removing. Tried 10 at once and all went good.
- Script will have processing of H.264 recordings disabled as default. If buying Comskip H.264 enable this feature by activate this function in the PATH CONFIGURATION section. Unfortunately Comskip H.264 is very slow finding commercials in H.264 recordings. So slow I prefer to disable the H.264 feature in script and only remove commercials from MPEG-2 recordings. Fortunately for me my HD channels have no in-show commercials and I can live with the announcements in start and end. Later Comskip versions supports detetction with all four CPU cores simultaneously, which speeds up the process 100%.
- I do recommend using my comskip.ini which works very well on both MPEG-2 and H.264 recordings. I will post it in here. Try to see to it that when comskip runs it only creates the .incommercial and .Vprj files. These are the only ones that will be removed after commercials has been removed and script finishes. If having .txt and .logo files still there tweak comskip.ini. Note: If Comskip often fails to detect in-show commercials you might need to tweak the comskip.ini. Visit Comskip forum for more info about this.
- Multiple comskip.inis can be used.
- No original recordings will be deleted when the commercial free one has been created. The commercial free recordings shall have it's own folder. There is an option for you to delete the original recording and move the commercial free one over to RS recording folder, but it is disabled. Use at own risk!
- There is no way to run same recording through the Automatic Commercial Removal script twice. Script will alert you if trying this. Recording must be deleted or moved from the commercial free recording folder before you can run it through the script a second time.
- It might be a good idea not using the Hidden Mode right away, at least until you are sure everything works as it should. When it's time to enable Hidden Mode just remove the semicolon in front of the line "Hide_commandline_userinterface" in the "PATHS AND CONFIGURATION" section, which activates it.
- Intelligent Hibernation will not work if two recordings with same starttime finishes at the exact same time, due to a shortcoming in RS API. Tried to make RS developer listen to my plea to change this, but he haven't met the plea so far. Intelligent hibernation works fine in all other cases.
- Lastly, I recommend this script to be used by people with moderate to advanced Windows knowledge/preferably also some coding knowledge and experienced DVBViewer users only. To newbies it might seem to be hard to setup and understand. I'll do my best to make the instructions on how to as easy as possible. I will not have much support for this script and have no plans on develop it further. Feel free to let me know if you find any bugs however, provided you are using Windows 7 32-bit. Well, that should cover it, now to setup.
Basic Setup:
- Install Autohotkey_L and choose Unicode during installation.
- Install VideoRedo TVSuite H.264 in Program Files folder (located in same partition as OS).
- Place Comskip in Program Files folder (Comskip does not have any installer). Copy the original comskip.ini and save it somewhere if you need it later. Copy all lines in my comskip.ini and replace all original lines in comskip.ini located in Comskip folder.
- Copy the code in the Commercial Removal script below and paste it into an emty notepad sheet. Choose "save as" and name it CommercialRemover.ahk. Look for a box where the label says "Coding", choose UTF-8 and then press save button. Never choose "Unicode" as encoding. Rightclick the saved .ahk in explorer and choose "Compile script". This compiles the script to an executable (.exe).
- Create the output folder where your commercial free recordings will end up.
- IMPORTANT NOTE: the CommercialRemover.exe shall always be located in the output folder where your commercial free recordings will end up. So place your CommercialRemover.exe in there. Where ever the script is located it is here your commercial free recordings will end up. DO NOT place it in RS recording folder though!
- For drag and drop use, create a shortcut of the CommercialRemover.exe and place it on the Desktop. From the explorer window you can now drag and drop recordings onto the shortcut on desktop. Commercials will then be removed from all recordings dropped on shortcut.
Automatic Commercial Removal setup:
NOTE: The script can be launched as an "After recording Task" from Recording Service. This makes commercial removal entirely automatic. After Recording service finishes the recording the Automatic Commercial Removal script will be executed. Using this kind of after recording task makes it hard to combine with Recording Service own Post record actions, such as standby, hibernation and shutdown. We do not want the HTPC to close down in the middle of an automatic commercial removal session. I therefor decided to combine automatic commercial removal with my intelligent hibernation script and intercept shutdown script. In this way standby, hibernation and shutdown gets put on hold until automatic commercial removal is done and then closes down HTPC. This is also the only way, I know, to be abled to execute more than one after recording task in Recording Service i.e. automatic commercial removal and hibernation. If you wanna know more about Intelligent hibernation you'll find it here:
http://www.DVBViewer.tv/forum/topic/41387-another-intelligent-hibernationscript/
The reciever script:
- Copy the code right below and paste it into an emty notepad sheet. Change the path to what path you choose for the InterceptReceiver.exe on the last line in the script. Choose "save as" and name it CommercialRemover.ahk. Look for a box where the label says "Coding", choose UTF-8 and then press save button. Rightclick the saved .ahk in explorer and choose "Compile script". This compiles the script to an executable (.exe).
- Now, from the explorer make a shortcut of the .exe and drag it to the autostart folder on the start-menu. Start it manually if you dont wanna restart Windows at this point. Have in mind this script MUST be started before running the CommercialSender script from RS. The autostart takes care of the script is always running after startup.
#NoTrayIcon
While !DllCall("WaitNamedPipe","Str","\\.\pipe\InterceptShutdown","UInt",0xffffffff)
Sleep, 500
Run % """" A_AhkPath """ \\.\pipe\InterceptShutdown"
Sleep, 500
Run, InterceptReceiver.exe, D:\ScriptsForWindows7
The CommercialSender script:
NOTE: The sender script launches the CommercialRemover.exe. It also specifies the rules of intelligent hibernation and retieves all needed information about RS status. This is the script that must be setup as the "After recording task" in Recording Service.
- Locate "The Sender script" down below and copy it and paste it into an empty notepad sheet. Now comes an important bit. You now need to fill in some vital data. Without them script will fail:
1. In PATH, URL AND CONDITIONS CONFIGURATION section fill in which folder you choose to be your output folder where the commecialfree recordings will end up. Only edit the path between the quotes and make sure not to remove any of the quotes.
Edited_Video_Folder := "C:\Your CommercialFreeOutPutfolder"
2. In the same section also fill in your username, password IP-number and portnumber to RS.
- Choose "save as" and name it CommercialSender.ahk. Look for a box where the label says "Coding", choose UTF-8 and then press save button. Rightclick the saved .ahk in explorer and choose "Compile script". This compiles the script to an executable (.exe). This script can be placed where ever you want.
- Rightclick the RS systrayicon and choose Configuration. Go to Tasks and create a new task. Name it CommercialSender and also type in the path for the CommercialSender.exe file (e.g. C:\CommercialSender.exe) in the Filenamebox or click the 3 dot button to the right and navigate to the CommercialSender.exe. Close the Task Editor and the Configuration window.
- Open up RS webinterface. Click on Configuration-->Recorder. Under "Default recording actions" and "Default task after recording:" select the process task you created "CommercialSender". "Post record action" should be set to "Nothing". Save your new settings. Remember if you have search presets created before this step, they all have the old default task after recording inherited, so the change you just did wont have any effect on recordingtimers created with these old search presets. Simply bring up your searchpresets in the SearchEPG and manually edit them one by one until all old presets have the "CommercialSender" as the default task after recording. In SearchEPG this box is named "Task" only. Do not confuse this with "post record action", this box must use "Nothing".
NOTE: This script can be tested by enabling the IniWrite lines (remove the semicolon in front of a line enables a codeline). Then you can check if script retrieves all needed values to make intelligent hibernation work. Script then creates an .ini file with this information in a folder of your choice. Intelligent hibernation feature can also be disabled if you for some reason don't want it. To do so add semicolons in front of all four:
Allow_hibernate_....._..... lines in the PATH, URL AND CONDITIONS CONFIGURATION section. Then your after recording task will only perform automatic commercial removal. If disabling the intelligent hibernation feature you don't need this next script.
The Intercept Shutdown script:
NOTE: When the automatic commercial removal process is done this is the script that recieves if closedown of HTPC shall be executed according to the hibernation rules you have specified in the CommercialSender script. The default task for the Intercept shutdown script is hibernation. You can alter this by changing BDefault (ButtonDefault) to what closedown method you like to use. After 20 seconds of countdown this default closedown method will be executed per automatic. In the messagebox appearing you can also cancel the closedown within 20 seconds if you choose to.
- Locate "The Intercept Shutdown script" down below and copy it and paste it into an empty notepad sheet. Choose "save as" and name it Intercept Shutdown.ahk. Look for a box where the label says "Coding", choose ANSI and then press save button. This script does not need to be saved in UTF-8 encoding, it works very well with ANSI. I do recommend you to choose ANSI here, cuz I haven't tested if everything works if saved as UTF-8 yet. Rightclick the saved .ahk in explorer and choose "Compile script". This compiles the script to an executable (.exe). Place this script where ever you want.
Well, that should be it. Enjoy!
#SingleInstance ignore
;Activate/inactivate codelines by removing/adding the semicolon ";" infront of a line.
;-PATHS AND CONFIGURATION----------------------------------------------------------------------------------
RS_Recording_folder := "D:\TV\Recording Service" ;Fill in path to RS Recording Folder
PropCopy_location := "D:\AVI_VOB_BLU-RAY_AC3-tools\TV-tools\DVBViewer\PropCopy_1_2_2\PropCopy.exe" ;Fill in path to PropCopy
Comskip_location := "C:\Program\Comskip\comskip.exe" ;Fill in path to Comskip
VideoredoBatchLocation := "C:\Program\VideoReDoTVSuite4\vp.vbs" ;Fill in path to vp.vbs
;Use_H264_commercialdetetction := "H.264" ;H.264 commercial detetction only works with Comskip donators version. Free version MPEG-2 only.
;Hide_commandline_userinterface := "Hide" ;If activated hides commandline windows used by the script.
;-CONDITIONING OF THE HIDE VARIABLE------------------------------------------------------------------------
 If Hide_commandline_userinterface
    Hide_commandline_userinterface := Hide_commandline_userinterface
 Else
    Hide_commandline_userinterface := %ErrorLevel%
;-DRAG AND DROP FUNCTIONALITY------------------------------------------------------------------------------
Loop %0%  ; For each parameter (or file dropped onto a script):
 GivenPath := %A_Index%  ; Fetch the contents of the variable whose name is contained in A_Index.
 Loop %GivenPath%, 1
 latest_file_drop = %A_LoopFileLongPath%
 SplitPath, latest_file_drop, OutFileNameDrop, OutDirDrop,, OutNameNoExtDrop
 latest_file_drop = %OutDirDrop%\%OutFileNameDrop%
;-RETRIEVE MEDIAFILE FORMAT - MPEG-2 OR H.264------------------------------------------------------------
 File_properties := GetDetailsOf(latest_file_drop)
 RegExMatch(File_properties, "MPEG2", MPEG2)
 RegExMatch(File_properties, "H.264", H264)
 RegExMatch(File_properties, "TV3", TV3)
 RegExMatch(File_properties, "Sjuan", Sjuan)
;-CONDITIONING OF THE H.264 VARIABLE---------------------------------------------------------------------
 If Use_H264_commercialdetetction = H.264
 Else
    Use_H264_commercialdetetction := ErrorLevel
;-COMSKIP FILE PROCESSING----------------------------------------------------------------------------------
 Loop, %A_ScriptDir%\%OutNameNoExtDrop%.ts, , 0
 latest_file_exist := A_LoopFileFullPath
 If latest_file_exist
   MsgBox, 64, INTERRUPTION MESSAGE, %latest_file_exist%`nalready exists in output folder.`nScript will terminate in 15 seconds., 15
   ExitApp
 Else
    If MPEG2
If TV3 or Sjuan
          Loop, %A_programfiles%\TV3.ini, , 1  ; Recurse into subfolders.
          TV3ini := A_LoopFileShortPath
          RunWait, %comspec% /c %Comskip_location% -t --videoredo --ini="%TV3ini%" "%latest_file_drop%",, %Hide_commandline_userinterface%
	If TV3=
         If Sjuan=
  RunWait, %comspec% /c %Comskip_location% -t --videoredo "%latest_file_drop%",, %Hide_commandline_userinterface%
    Else
;-VIDEOREDO FILE PROCESSING--------------------------------------------------------------------------------
  Sleep, 3000
  If MPEG2
    RunWait, %comspec% /c cscript.exe //nologo "%VideoredoBatchLocation%" "%OutDirDrop%\%OutNameNoExtDrop%.VPrj" "%A_ScriptDir%\%OutNameNoExtDrop%.ts" /p:"MPEG2 Transport Stream" /q, ,  %Hide_commandline_userinterface%
  If H264
     RunWait, %comspec% /c cscript.exe //nologo "%VideoredoBatchLocation%" "%OutDirDrop%\%OutNameNoExtDrop%.VPrj" "%A_ScriptDir%\%OutNameNoExtDrop%.ts" /p:"H.264 Transport Stream" /q, ,  %Hide_commandline_userinterface%
;-PROPCOPY AND CLEANUP AFTER PROCESSING--------------------------------------------------------------------
      RunWait, %PropCopy_location% "%OutDirDrop%\%OutNameNoExtDrop%.ts" "%A_ScriptDir%\%OutNameNoExtDrop%.ts" ;Metadata/Fileinfo copy
      FileRecycle, %OutDirDrop%\%OutNameNoExtDrop%.VPrj
      FileRecycle, %OutDirDrop%\%OutNameNoExtDrop%.incommercial
      ;Filemove, %A_ScriptDir%\%OutFileNameDrop%, %OutDirDrop%\%OutFileNameDrop%, 1 ;Moves edited recording and overwrites original recording.
;-RS AFTER RECORDING TASK - COMMERCIAL PROCESSING WHEN RECORDINGS FINISHES-----------------------------------
If latest_file_drop =
right_Now := a_now
timelimit := right_Now
EnvAdd, timelimit, -90, seconds
FileList =
b_index=0
Loop, %RS_Recording_folder%\*.ts
  if A_LoopFileTimeModified between %timelimit% and %right_Now%
    b_index++
    file%b_index% := A_LoopFileFullPath
 ;FileList = %FileList%%A_LoopFileTimeModified%`t%b_index%`t%A_LoopFileName%`n ;Enable this line to debug with msgbox Please hit
;msgbox, 4, , Please hit ^c (while this is displayed) to copy to clipboard `n`n%FileList%`n`n%A_Now%, 10
Loop %b_index%
 SplitPath, file%a_index%, OutFileName, OutDir,, OutNameNoExt
 latest_file = %OutDir%\%OutFileName%
;-RETRIEVE MEDIAFILE FORMAT - MPEG-2 OR H.264--------------------------------------------------------------
 File_properties := GetDetailsOf(latest_file)
 Else
Loop, %A_ScriptDir%\%OutNameNoExt%.ts, , 0
 ExitApp
Else
   If MPEG2
     If TV3 or Sjuan
         RunWait, %comspec% /c %Comskip_location% -t --videoredo --ini="%TV3ini%" "%latest_file%",, %Hide_commandline_userinterface%
     If TV3=
        If Sjuan=
        RunWait, %comspec% /c %Comskip_location% -t --videoredo "%latest_file%",, %Hide_commandline_userinterface%
   Else
  Sleep, 3000
  If MPEG2
     RunWait, %comspec% /c cscript.exe //nologo "%VideoredoBatchLocation%" "%OutDir%\%OutNameNoExt%.VPrj" "%A_ScriptDir%\%OutNameNoExt%.ts" /p:"MPEG2 Transport Stream" /q, , %Hide_commandline_userinterface%
  If H264
      RunWait, %comspec% /c cscript.exe //nologo "%VideoredoBatchLocation%" "%OutDir%\%OutNameNoExt%.VPrj" "%A_ScriptDir%\%OutNameNoExt%.ts" /p:"H.264 Transport Stream" /q, , %Hide_commandline_userinterface%
      RunWait, %PropCopy_location% "%RS_recording_folder%\%OutNameNoExt%.ts" "%A_ScriptDir%\%OutNameNoExt%.ts" ;Metadata/Fileinfo copy
      FileRecycle, %OutDir%\%OutNameNoExt%.VPrj
      FileRecycle, %OutDir%\%OutNameNoExt%.incommercial
      ;Filemove, %A_ScriptDir%\%OutFileName%, %OutDir%\%OutFileName%, 1 ;Moves edited recording and overwrites original recording.
;-FUNCTIONS------------------------------------------------------------------------------------------------
GetDetailsOf(inFileName) {
  SplitPath,inFileName,sFileName,sFileDir
  objFolder := ComObjCreate("Shell.Application").Namespace(sFileDir . "\")
  objFile := objFolder.Parsename(sFileName)
  Loop
     iAttribute := objFolder.GetDetailsOf(objFolder, A_Index)
     if not iAttribute
        break
     if (iValue := objFolder.GetDetailsOf(objFile, A_Index)) ;only add attribs with values
        details .= A_Index . " : " . iAttribute . " = " . iValue . "`n"
  return details, objFolder := "", objFile := ""
Comskip.ini
detect_method=111
verbose=0
max_brightness=60
maxbright=5
test_brightness=40
max_avg_brightness=25
max_commercialbreak=600
min_commercialbreak=25
max_commercial_size=125
min_commercial_size=4
min_show_segment_length=125
max_volume=500
non_uniformity=500
[Detailed Settings]
min_silence=8
noise_level=5
brightness_jump=200
fps=25
validate_silence=1
validate_uniform=1
validate_scenechange=1
global_threshold=1.05
disable_heuristics=0
[CPU Load Reduction]
play_nice_start=-1
play_nice_end=-1
play_nice_sleep=10
[input Correction]
max_repair_size=200
ms_audio_delay=5
volume_slip=20
variable_bitrate=1
[Aspect Ratio]
ar_delta=0.08
cut_on_ar_change=1
[Global Removes]
padding=0
remove_before=0
remove_after=0
delete_show_after_last_commercial=1
delete_show_before_first_commercial=1
delete_show_before_or_after_current=1
delete_block_after_commercial=0
min_commercial_break_at_start_or_end=5
[uSA Specific]
intelligent_brightness=0
black_percentile=0.0073
uniform_percentile=0.005
score_percentile=0.71
[Main Scoring]
length_strict_modifier=3
length_nonstrict_modifier=1.5
combined_length_strict_modifier=2
combined_length_nonstrict_modifier=1.25
ar_wrong_modifier=2
excessive_length_modifier=0.01
dark_block_modifier=0.3
min_schange_modifier=0.5
max_schange_modifier=2
logo_present_modifier=0.5
punish_no_logo=1
[Detailed Scoring]
punish=0
reward=0
punish_threshold=1.3
punish_modifier=2
reward_modifier=0.5
[Logo Finding]
border=10
give_up_logo_search=2000
logo_max_percentage_of_screen=0.1
ticker_tape=0
ignore_side=0
subtitles=0
logo_at_bottom=0
logo_threshold=0.75
logo_filter=5
aggressive_logo_rejection=0
edge_level_threshold=5
edge_radius=2
edge_weight=10
edge_step=1
num_logo_buffers=50
use_existing_logo_file=1
two_pass_logo=1
[Logo Interpretation]
connect_blocks_with_logo=1
logo_percentile=0.92
logo_fraction=0.4
shrink_logo=5
before_logo=0
after_logo=0
where_logo=0
min_black_frames_for_break=1
[Closed Captioning]
ccCheck=0
cc_commercial_type_modifier=4
cc_wrong_type_modifier=2
cc_correct_type_modifier=0.75
[Live TV]
live_tv=1
live_tv_retries=4
dvrms_live_tv_retries=300
standoff=0
dvrmsstandoff=120000
require_div5=0
div5_tolerance=-1
[Output Control]
output_default=0
output_plist_cutlist=0
output_zoomplayer_cutlist=0
output_zoomplayer_chapter=0
output_vcf=0
output_vdr=0
output_projectx=0
output_avisynth=0
output_videoredo=0
videoredo_offset=2
output_btv=0
output_edl=0
output_edlp=0
output_bsplayer=0
output_edlx=0
output_cuttermaran=0
output_mpeg2schnitt=0
output_womble=0
output_mls=0
output_mpgtx=0
output_dvrmstb=0
output_dvrcut=0
output_framearray=0
output_debugwindow=0
output_tuning=0
output_training=0
output_aspect=0
output_demux=0
output_timing=0
delete_logo_file=1
cutscene_frame=0
cutscene_dumpfile=""
cutscene_threshold=10
cutscenefile1=""
cutscenefile2=""
cutscenefile3=""
cutscenefile4=""
cutscenefile5=""
cutscenefile6=""
cutscenefile7=""
cutscenefile8=""
windowtitle="Comskip - %s"
cuttermaran_options="cut=\"true\" unattended=\"true\" muxResult=\"false\" snapToCutPoints=\"true\" closeApp=\"true\""
mpeg2schnitt_options="mpeg2schnitt.exe /S /E /R25 /Z %2 %1"
avisynth_options="LoadPlugin(\"MPEG2Dec3.dll\") \nMPEG2Source(\"%s\")\n"
dvrcut_options="dvrcut \"%s.dvr-ms\" \"%s_clean.dvr-ms\" "
[sage Workarounds]
sage_framenumber_bug=0
sage_minute_bug=0
enable_mencoder_pts=0
Sender script (AKA Intelligent Hibernationscript)
#NoTrayIcon
;Activate codelines by removing the semicolon ";" infront of a line if you wanna use this feature
;If using Clientcount as a variable to cancel hibernation instead of the default TimeVar activate this line in CONDITIONING OF VARIABLES on two locations.
;Using script in default version just fill in user details, IP and port number to Recording Service API in next section.
;PATH, URL AND CONDITIONS CONFIGURATION
Recording_Service_API_URL := "http://username:password@127.0.0.1:8089" ;Fill in username and password to RS
;RS_recording_folder := "D:\TV\Recording Service" ;Activate if wanting recordings database backup. Fill in path to your RS recording folder.
;EPG_files_location := "D:\TV\Recording Service\EPG Info-Log Files" ;Activate if wanting recordings database backup. OBSERVE! Must be a subfolder to RS recording folder
;PropCopy_location := "D:\AVI_VOB_BLU-RAY_AC3-tools\TV-tools\DVBViewer\PropCopy_1_2_2\PropCopy.exe" ;Activate if wanting recordings database backup. Fill in path to PropCopy
;Recording_database_backup_location_1 := "D:\AVI_VOB_BLU-RAY_AC3-tools\TV-tools\EPG Info-Log Files Backup" ;Activate if wanting recordings database backup on other location.
;Recording_database_backup_location_2 := "E:\EPG Info-Log Files Backup"
Edited_Video_Folder := "D:\Edited Recordings" ;Activate if wanting comskip/videoredo commercial removal. Fill in path to CommercialRemover.exe. More info on setup read next section.
Allow_hibernate_starttime_weekdays := "01:00:00" ;Configurate starttime from when hibernation should be allowed for weekdays. Change time value to your own preference.
Allow_hibernate_stoptime_weekdays := "15:00:00"  ;Configurate stoptime up to when hibernation should be allowed for weekdays. Change time value to your own preference.
Allow_hibernate_starttime_weekend := "02:00:00"  ;Configurate starttime from when hibernation should be allowed for weekends. Change time value to your own preference.
Allow_hibernate_stoptime_weekend := "09:00:00"   ;Configurate stoptime up to when hibernation should be allowed for weekends. Change time value to your own preference.
;Use_clientcount_status_as_Hibernationblock := "ErrorLevel"
This last configuration line above disables time as main hibernation blocker and enables hibernation block as long as the local DVBViewer
client on RS server is running. Default inactivated. Don't change value...to activate remove semicolon in front of the
"Use_clientcount_status_as_Hibernationblock" line. To make it work for local client on server enable:
RS Configure/DVBServer tab/"Block Standby/Hibernate if a DVBViewer client is connected on the same computer" option.
If not this option is checked, the local client will not be counted when doing the RS API check and this feature will fail.
;COMSKIP/VIDEOREDO COMMERCIAL REMOVAL ;This feature Requires additional software.
;For setup go to: http://www.DVBViewer.tv/forum/topic/44842-automatic-commercial-removal-script/page__view__findpost__p__330318
;DELETE OLD RECORDINGS CONFIGURATION ;Activate to use. Fill in number of days to keep files and path to them
;OldConfigCleanup("2","D:\TV\Inspelat","*.ts") ;Recordings older than 2 days will be deleted from Inspelat folder.
;OldConfigCleanup("2","D:\TV\Seen Recordings","*.ts") ;Recordings older than 2 days will be deleted from Seen Recordings folder.
;OldConfigCleanup("1","D:\TV\Timeshift","*.ts") ;Timeshifted Recordings older than 1 day will be deleted.
;CODE BODY
;---CURRENT TIME AND DAY RETRIEVAL--------------------------------------------------------------------------------
FormatTime, TimeVar,, HH:mm:ss ;Current local time.
FormatTime, DateVar,, WDay ; 1=Sunday, 2=Monday etc.
;---RECORDING SERVICE STATUS RETRIEVAL----------------------------------------------------------------------------
UrlDownloadToVar(Recording_Service_API_URL . "/api/status.html", OutputVar)
FoundPos := RegExMatch(OutputVar, "(?<=recordcount>)(.)", SubPat)
RS_StatusVar:=SubPat ;status of the recording service
;---TIME TO NEXT RECORDING RETRIEVAL------------------------------------------------------------------------------
UrlDownloadToVar(Recording_Service_API_URL . "/api/timerlist.html[?utf8=]", OutputVar2)
x1 := loadXML(OutputVar2)
MyList := A_Now A_Tab "<now>"
for timer in x1.selectNodes("/Timers/Timer") ;Loop
  timer_status := timer.selectSingleNode("@Enabled").text ;Retrieves if timer is enabled or not. Activated=-1 Deactivated=0
  date := timer.selectSingleNode("@Date").text ;Date of timer
  start_time := timer.selectSingleNode("@Start").text ;Start time of timer
  date_starttime_orig_format = %date%`n%start_time% ;Original date and start time format
  date_starttime := ReFormatTime( date_starttime_orig_format, "DD MM YYYY HH MI SS", ".`n:" ) ;ReFormat date and start time of timer
  MyList .= "`n" . date_starttime . "|" . timer_status
Sort, MyList, N
NewString := RegexReplace( MyList, "\v*\d{14}\|0" ) ;Removes all deactivated timers
set=0
Loop, Parse, NewString, `n
  If set=1
    datetime := A_LoopField
    break
  IfInString, A_Loopfield, <now>
    set=1
StringSplit, datetime, datetime, %A_Tab%
EnvSub, datetime1, A_Now, min
If datetime1 = 0
  RS_TimeToNextRecordingVar := 31
Else
  RS_TimeToNextRecordingVar := datetime1 ;time in minutes to next recording
;---RECORDING SERVICE CLIENTCOUNT STATUS RETRIEVAL-----------------------------------------------------------------
FoundPos := RegExMatch(OutputVar, "(?<=clientcount>)(.)", SubPat2)
RS_ClientCountStatus:=SubPat2 ;Number of clients connected to the recording service
;---CONDITIONING OF CLIENTCOUNT VARIABLE---------------------------------------------------------------------------
If Use_clientcount_status_as_Hibernationblock =
  Use_clientcount_status_as_Hibernationblock := ErrorLevel
Else
  Use_clientcount_status_as_Hibernationblock := RS_ClientCountStatus
;---CONDITIONING OF EDITED_VIDEO_FOLDER VARIABLE-------------------------------------------------------------------
If Edited_Video_Folder
  Edited_Video_Folder := Edited_Video_Folder
Else
  Edited_Video_Folder := %ErrorLevel%
;---DEBUG IF THE VARIABLES GETS VALUES-----------------------------------------------------------------------------
;IniWrite, %DateVar%, C:\ScriptsForWindows7\DVBViewer RecService Status.ini, Day_of_Week, Key
;IniWrite, %TimeVar%, C:\ScriptsForWindows7\DVBViewer RecService Status.ini, CurrentTime, Key
;IniWrite, %RS_StatusVar%, C:\ScriptsForWindows7\DVBViewer RecService Status.ini, RS_Status, Key
;IniWrite, %RS_TimeToNextRecordingVar%, C:\ScriptsForWindows7\DVBViewer RecService Status.ini, RS_TimeToNextRecording, Key
;IniWrite, %RS_ClientCountStatus%, C:\ScriptsForWindows7\DVBViewer RecService Status.ini, RS_ClientCountStatus, Key
;---TEST VARIABLES-------------------------------------------------------------------------------------------------
;DateVar = 7
;TimeVar = 16:00:00
;RS_StatusVar = 2
;RS_TimeToNextRecordingVar = 30
;Use_clientcount_status_as_Hibernationblock = 1
;---RECORDINGS DATABASE BACKUP AND METADATA COPY-------------------------------------------------------------------
right_Now := a_now
EnvAdd, timelimit, -60, seconds
FileList =
b_index=0
Loop, %RS_recording_folder%\*.log
       b_index++
;msgbox Please hit ^c (while this is displayed) to copy to clipboard `n`n%FileList%
Loop %b_index%
FileCopy, %OutDir%\%OutFileName%, %EPG_files_location%\ ;RS log file will be copied to backupfolder
FileMove, %OutDir%\%OutNameNoExt%.txt, %EPG_files_location%\ ;EPG information file will be moved to a subfolder
   Filemove, %OutDir%\%OutFileName%, %EPG_files_location%\%OutNameNoExt%.ts ;RS Log file will be moved and renamed to .ts extension
   RunWait, %PropCopy_location% "%RS_recording_folder%\%OutNameNoExt%.ts" "%EPG_files_location%\%OutNameNoExt%.ts" ;Metadata/Fileinfo copy
   FileCopy, %EPG_files_location%\*.*, %Recording_database_backup_location_1%\, 0 ;Backup of database
FileCopy, %EPG_files_location%\*.*, %Recording_database_backup_location_2%\, 0 ;Backup of database
UrlDownloadToVar(Recording_Service_API_URL . "/tasks.html?task=RefreshDB&aktion=tasks", OutputVar) ;Refresh Recording Service Database
;---CONDITIONING OF VARIABLES--------------------------------------------------------------------------------------
If DateVar between 2 and 6 ;Specifies hibernation rules between Monday=2 and Friday=6. Always use LowerBound and UpperBound format, like my example.
  If TimeVar not between %Allow_hibernate_starttime_weekdays% and %Allow_hibernate_stoptime_weekdays% ;Between 01:00-15:00 hibernation will be allowed.
      Gosub, Label1 ;One or more conditions above is NOT met...hibernation will be cancelled but automatic commercial removal will commence.
  Else
    If RS_StatusVar <= 1 ;If Recording Service status is idle hibernation will be allowed. DO NOT alter this value!
     If Use_clientcount_status_as_Hibernationblock = 0 ;Hibernation will be allowed only if no clients are connected to RS.
       If RS_TimeToNextRecordingVar >= 30 ;If more than 30 minutes to next recording, HTPC will hibernate. Set to the value you prefer!
        If Edited_Video_Folder = %ErrorLevel% ;Edited video folder is inactivated
	   Sleep, 4000 ;Just wait a little before creating pipe
          #NoEnv
          ptr := A_PtrSize ? "Ptr" : "UInt"
          char_size := A_IsUnicode ? 2 : 1
          Script=
          SetTitleMatchMode, 2
          DetectHiddenWindows, On
          SendMessage, 0x5555, 0, 0,,InterceptShutdown.exe ; InterceptShutdown.exe is in my case the interceptionscript
          DetectHiddenWindows, Off
          ; To prevent "collision", pipe_name could be something mostly "unique", like:
          ;   pipe_name := A_TickCount
          pipe_name := "InterceptShutdown"
          ; Before reading the file, AutoHotkey calls GetFileAttributes(). This causes
          ; the pipe to close, so we must create a second pipe for the actual file contents.
          ; Open them both before starting AutoHotkey, or the second attempt to open the
          ; "file" will be very likely to fail. The first created instance of the pipe
          ; seems to reliably be "opened" first. Otherwise, WriteFile would fail.
          pipe_ga := CreateNamedPipe0(pipe_name, 2)
          pipe    := CreateNamedPipe0(pipe_name, 2)
          if (pipe=-1 or pipe_ga=-1)
             MsgBox CreateNamedPipe failed.
             ExitApp
          ; Wait for AutoHotkey to connect to pipe_ga via GetFileAttributes().
          DllCall("ConnectNamedPipe", ptr, pipe_ga, ptr, 0)
          ; This pipe is not needed, so close it now. (The pipe instance will not be fully
          ; destroyed until AutoHotkey also closes its handle.)
          DllCall("CloseHandle", ptr, pipe_ga)
          ; Wait for AutoHotkey to connect to open the "file".
          DllCall("ConnectNamedPipe", ptr, pipe, ptr, 0)
          ; Standard AHK needs a UTF-8 BOM to work via pipe.  If we're running on
          ; Unicode AHK_L, 'Script' contains a UTF-16 string so add that BOM instead:
          Script := (A_IsUnicode ? chr(0xfeff) : chr(239) chr(187) chr(191)) . Script
          char_size := (A_IsUnicode ? 2:1)
          if !DllCall("WriteFile", ptr, pipe, "str", Script, "uint", (StrLen(Script)+1)*char_size, "uint*", 0, ptr, 0)
          MsgBox WriteFile failed: `%ErrorLevel`%/`%A_LastError`%
          DllCall("CloseHandle", ptr, pipe)
          CreateNamedPipe0(Name, OpenMode=3, PipeMode=0, MaxInstances=255)
             global ptr
             return DllCall("CreateNamedPipe","str","\\.\pipe\" Name,"uint",OpenMode
             ,"uint",PipeMode,"uint",MaxInstances,"uint",0,"uint",0,"uint",0,ptr,0,ptr)
          ExitApp
	 Else if Edited_Video_Folder
           #NoEnv
           Script=
           RunWait, CommercialRemover.exe, %Edited_Video_Folder%
           pipe_ga := CreateNamedPipe1(pipe_name, 2)
           pipe    := CreateNamedPipe1(pipe_name, 2)
              ExitApp
           CreateNamedPipe1(Name, OpenMode=3, PipeMode=0, MaxInstances=255)
              global ptr
           ExitApp
        Else if RS_TimeToNextRecordingVar <= 29
	      GoSub, Label1 ;One or more conditions above is NOT met...hibernation will be cancelled but automatic commercial removal will commence.
        Else if Use_clientcount_status_as_Hibernationblock >= 1
        Else if RS_StatusVar >= 2
;---CONDITIONING OF VARIABLES WEEKENDS-----------------------------------------------------------------------------
If DateVar not between 2 and 6 ;Specifies hibernation rules between Saturday=7 and Sunday=1. Always use LowerBound and UpperBound format, like my example.
  If TimeVar not between %Allow_hibernate_starttime_weekend% and %Allow_hibernate_stoptime_weekend% ;Between 02:00-09:00 hibernation will be allowed.
      Gosub, Label1 ; One or more conditions above is NOT met...hibernation will be cancelled but automatic commercial removal will commence.
  Else
          #NoEnv
          Script=
          pipe_ga := CreateNamedPipe2(pipe_name, 2)
          pipe    := CreateNamedPipe2(pipe_name, 2)
             ExitApp
          CreateNamedPipe2(Name, OpenMode=3, PipeMode=0, MaxInstances=255)
             global ptr
          ExitApp
           #NoEnv
           Script=
           pipe_ga := CreateNamedPipe3(pipe_name, 2)
           pipe    := CreateNamedPipe3(pipe_name, 2)
              ExitApp
           CreateNamedPipe3(Name, OpenMode=3, PipeMode=0, MaxInstances=255)
              global ptr
           ExitApp
;---SUBROUTINES----------------------------------------------------------------------------------------------------
Label1:
If Edited_Video_Folder ;Edited video folder is activated
  #NoEnv
  Script=Run, CommercialRemover.exe, %Edited_Video_Folder%
  pipe_ga := CreateNamedPipe4(pipe_name, 2)
  pipe    := CreateNamedPipe4(pipe_name, 2)
    ExitApp
  CreateNamedPipe4(Name, OpenMode=3, PipeMode=0, MaxInstances=255)
    global ptr
  ExitApp
Else If Edited_Video_Folder = %ErrorLevel% ;Edited Video folder does not exist
  ExitApp
;FUNCTIONS
UrlDownloadToVar(URL, ByRef Result, UserAgent = "", Proxy = "", ProxyBypass = "") {
   ; Requires Windows Vista, Windows XP, Windows 2000 Professional, Windows NT Workstation 4.0,
   ; Windows Me, Windows 98, or Windows 95.
   ; Requires Internet Explorer 3.0 or later.
   pFix:=a_isunicode ? "W" : "A"
   hModule := DllCall("LoadLibrary", "Str", "wininet.dll")
   AccessType := Proxy != "" ? 3 : 1
   ;INTERNET_OPEN_TYPE_PRECONFIG                    0   // use registry configuration
   ;INTERNET_OPEN_TYPE_DIRECT                       1   // direct to net
   ;INTERNET_OPEN_TYPE_PROXY                        3   // via named proxy
   ;INTERNET_OPEN_TYPE_PRECONFIG_WITH_NO_AUTOPROXY  4   // prevent using java/script/INS
   io := DllCall("wininet\InternetOpen" . pFix
   , "Str", UserAgent ;lpszAgent
   , "UInt", AccessType
   , "Str", Proxy
   , "Str", ProxyBypass
   , "UInt", 0) ;dwFlags
   iou := DllCall("wininet\InternetOpenUrl" . pFix
   , "UInt", io
   , "Str", url
   , "Str", "" ;lpszHeaders
   , "UInt", 0 ;dwHeadersLength
   , "UInt", 0x80000000 ;dwFlags: INTERNET_FLAG_RELOAD = 0x80000000 // retrieve the original item
   , "UInt", 0) ;dwContext
   If (ErrorLevel != 0 or iou = 0) {
       DllCall("FreeLibrary", "UInt", hModule)
       return 0
   VarSetCapacity(buffer, 10240, 0)
   VarSetCapacity(BytesRead, 4, 0)
   Loop
       ;http://msdn.microsoft.com/library/en-us/wininet/wininet/internetreadfile.asp
       irf := DllCall("wininet\InternetReadFile", "UInt", iou, "UInt", &buffer, "UInt", 10240, "UInt", &BytesRead)
       VarSetCapacity(buffer, -1) ;to update the variable's internally-stored length
       BytesRead_ = 0 ; reset
       Loop, 4  ; Build the integer by adding up its bytes. (From ExtractInteger-function)
           BytesRead_ += *(&BytesRead + A_Index-1) << 8*(A_Index-1) ;Bytes read in this very DllCall
       ; To ensure all data is retrieved, an application must continue to call the
       ; InternetReadFile function until the function returns TRUE and the lpdwNumberOfBytesRead parameter equals zero.
       If (irf = 1 and BytesRead_ = 0)
           break
       Else ; append the buffer's contents
           a_isunicode ? buffer:=StrGet(&buffer, "CP0")
           Result .= SubStr(buffer, 1, BytesRead_ * (a_isunicode ? 2 : 1))
       /* optional: retrieve only a part of the file
       BytesReadTotal += BytesRead_
       If (BytesReadTotal >= 30000) ; only read the first x bytes
       break                      ; (will be a multiple of the buffer size, if the file is not smaller; trim if neccessary)
   DllCall("wininet\InternetCloseHandle",  "UInt", iou)
   DllCall("wininet\InternetCloseHandle",  "UInt", io)
OldConfigCleanup(Daystokeep,Pathtoconfigs,exttodelete)
 difdays = %Daystokeep%
 Source = %Pathtoconfigs%\%exttodelete%
 Time := A_Now
 Loop, %Source%, 0, 0
  TimeStamp := Time
  EnvSub, TimeStamp, %A_LoopFileTimeModified%, Days
  If ( TimeStamp >= difdays )
   ;MsgBox, file to delete: %A_LoopFileLongPath%
   ;FileDelete, %A_LoopFileLongPath% ;Files gets deleted instantly and permanent.
   FileRecycle, %A_LoopFileLongPath% ;Files gets moved to the Recycle Bin
  continue
 ;ExitApp
loadXML(ByRef data)
  o := ComObjCreate("MSXML2.DOMDocument.6.0")
  o.async := false
  o.preserveWhiteSpace := true
  o.loadXML(data)
  return o
ReFormatTime( Time, Format, Delimiters  ) {
StringSplit F,Format, %A_Space%
Loop, Parse, Time, %Delimiters%
  Var := F%A_Index%,  %Var% := A_LoopField
Return YYYY MM DD HH MI SS
#NoTrayIcon
#Persistent
;While !DllCall("WaitNamedPipe","Str","\\.\pipe\InterceptShutdown","UInt",0xffffffff)
;Sleep, 100
;Run % """" A_AhkPath """ \\.\pipe\InterceptShutdown"
SetTimer, RunBeforeShutdown, Off
SetTimer, RunBeforeShutdown2, Off
Gui,+LastFound
hwnd:=WinExist()
DllCall("ShutdownBlockReasonCreate","Uint",hwnd,"Str",A_ScriptFullPath "is still running")
DllCall("kernel32.dll\SetProcessShutdownParameters", UInt, 0x4FF, UInt, 0)
OnMessage(0x11, "WM_QUERYENDSESSION")
OnMessage(0x5555, "RunBeforeShutdown2")
Return
WM_QUERYENDSESSION(wParam, lParam)
   static sdtry = 0
   ENDSESSION_Logoff = 0x80000000
   If (lParam & ENDSESSION_Logoff) ; User is logging off.
     EventType = Logoff
   Else     ; System is either shutting down or restarting. and
     EventType = Shutdown
   If (EventType = "Shutdown" and sdtry = 0)
      SetTimer, RunBeforeShutdown, On
      Return false ; Tell the OS to Abort the Shutdown/Logoff.
   Else If (EventType = "Shutdown" and sdtry = 1)
     Return true
RunBeforeShutdown2(wParam, lParam, msg)
   SetTimer, RunBeforeShutdown2, On
   Return true
RunBeforeShutdown:
SendInput, {ENTER}
Sleep, 1000
#SingleInstance, Force
SetWorkingDir %A_ScriptDir%
FileDelete, demo.htm
FileAppend,
<html>
<body style="overflow:hidden">
<body bgcolor="#0033FF" leftmargin="1" topmargin="1">
<div align="Center"><p>
<font color="#FFFB02" face="Segoe Print" size="4"><br><b>
Your HTPC is about to be Closed Down.
<br>
You now have a chance to choose closedown method
<br>
or wait until default method gets choosen for you</b>
</p>
<font face="Segoe Print" size="5"><b>
<script type="text/javascript">
var countDownInterval=20;
var countDownTime=countDownInterval+1;
function countDown(){
countDownTime--;
if (countDownTime <=0){
countDownTime=countDownInterval;
clearTimeout(counter);
//window.location="";
return
if (document.getElementById) //else if NS6+
document.getElementById("countDownText").innerHTML=countDownTime+" ";
else if (document.layers){ //CHANGE TEXT BELOW TO YOUR OWN
document.c_reload.document.c_reload2.document.write('<b id="countDownText">'+countDownTime+' </b> seconds')
document.c_reload.document.c_reload2.document.close()
counter=setTimeout("countDown()", 1000);
function startit(){
if (document.getElementById) //CHANGE TEXT BELOW TO YOUR OWN
countDown()
startit()
else
window.onload=startit
clearTimeout ( countDownTime );
</script>
</font></b>
</div>
</body>
</html>
, demo.htm
URL=file:///%A_ScriptDir%\demo.htm
Options := "Buttons=Hibernate/Standby/Shutdown/Restart/Cancel, HtmW=580, HtmH=200, BDefault=1, DlgBgColor=0xEE0000, DlgTopmost=1, TimeOut=20, Title=System Closedown in 20 seconds, DlgStyle=NoFrame"
Sel := HtmDlg( URL, "", Options )
if (Sel = 1)
  ;Run, InterceptShutdown.exe, D:\ScriptsForWindows7
  DllCall("PowrProf\SetSuspendState", "int", 1, "int", 0, "int", 0)
  Return
else if (Sel = 2)
  DllCall("PowrProf\SetSuspendState", "int", 0, "int", 0, "int", 0)
  Return
else if (Sel = 3)
  SetWorkingDir, C:\Program\HomeSeer HS2
  RunWait, destroy_homeseer_speaker_client.vbs, E:\Extremt Bra Programvara\Scripts\VBS Code project\gopal_code_demo
  RunWait, Jon00ShutdownHS.exe, C:\Program\HomeSeer HS2
  IniRead, HomeSeerPID, HomeSeerPID.ini, IExplorerPID, key
  WinClose, ahk_pid %HomeSeerPID%
  Process, Close, DVBViewer.exe
  Shutdown, 1
  ExitApp
  Return
else if (Sel = 4)
  Shutdown, 2
  ExitApp
  Return
else if (Sel = 5)
  hibernate = 0
  Return
DllCall("ShutdownBlockReasonDestroy","Uint",hwnd)
Return                                                 ; // end of auto-execute section //
RunBeforeShutdown2:
FileAppend,
<html>
<br>
<br>
</p>
countDownTime--;
return
function startit(){
countDown()
startit()
else
</script>
</font></b>
</div>
</body>
</html>
, demo.htm
if (Sel = 1)
  Return
else if (Sel = 2)
  Return
else if (Sel = 3)
  Shutdown, 1
  ExitApp
  Return
else if (Sel = 4)
  Shutdown, 2
  ExitApp
  Return
else if (Sel = 5)
  hibernate = 0
  Return
;#Include HtmDlg.ahk ; You may copy/Paste HtmDlg() Instead
HtmDlg( _URL="", _Owner=0, _Options="", _ODL="," ) {     ; HTML DialogBox v0.57 -- by SKAN
; Topic: www.autohotkey.com/forum/viewtopic.php?t=60215    CD:09-Jul-2010 | LM:05-Aug-2010
; Credit: WebControl Demo by Sean - www.autohotkey.com/forum/viewtopic.php?p=103987#103987
Static _hInst,_hDLG,_DlgP,_B$,_B$L,_pIWEB,_pV,_DlgT,CliC, HtmF=0,_Brush=0,   BDef=1,BEsc=0
If ( A_EventInfo = 0xCBF ) {                                   ; nested Callback Function
  hWnd := _URL,  uMsg := _Owner,  wP := _Options,  lP := _ODL
  If ( uMsg=0x112 && wP=0xF060 )                               ; WM_SYSCOMMAND & SC_ClOSE
    Return DllCall( "DestroyWindow", UInt,_hDLG ) | ( BDEf:=BEsc )
  If ( uMsg=0x111 && (wP>>16)=0 )                              ; WM_COMMAND & BN_CLICKED
    Return DllCall( "DestroyWindow", UInt,_hDLG ) | ( BDef := (wP=2) ? BEsc : wP-100  )
  If ( uMsg=0x007 && HtmF=0 )                                  ; WM_SETFOCUS
    Return DllCall( "SetFocus", UInt,DllCall( "GetDlgItem", UInt,_hDLG, UInt,100+BDEF ) )
  If ( uMsg=0x201 && CliC )                                    ; WM_LBUTTONDOWN
    Return DllCall( "DestroyWindow", UInt,_hDLG ) |  ( BDEf := 1 )
  If ( uMsg=0x136 && _Brush<>0 )                               ; WM_CTLCOLORDLG
    Return _Brush
  if ( uMsg=0x002 && hWnd=_hDLG )                              ; WM_DESTROY
    Return _Brush := DllCall( "DeleteObject", UInt,_Brush, UInt ) >> 32
Return False
If ! ( _hInst ) {
_hInst := DllCall( "GetModuleHandle", Str,A_IsCompiled ? A_ScriptFullpath : A_AhkPath )
_DT := "61160CD3AFCDD0118A3EGC04FC9E26EZQ1GFFFFUCHC88GAZO9G9G1I4DG53G2H53G68G65G6CG6CG2H"
. "44G6CG67ZL5V64K41G74G6CG41G78G57G69G6EK7BG38G38G35G36G46G39G36G31G2DG33G34G3H41G2DG31"
. "G31G44G3H2DG41G39G36G42G2DG3H3H43G3H34G46G44G37G3H35G41G32G7DZS14V65KFFFF8ZP14V66KFFF"
. "F8ZP14V67KFFFF8ZP14V68KFFFF8ZP14V69KFFFF8ZP14V6AKFFFF8ZP14V6BKFFFF8ZP14V6CKFFFF8ZP14V"
. "6DKFFFF8P"
Loop 20   ;  Decompressing Nulls : www.autohotkey.com/forum/viewtopic.php?p=198560#198560
 StringReplace,_DT,_DT,% Chr(70+21-A_Index),% SubStr("000000000000000000000",A_Index),All
Loop % _B$L := VarSetCapacity( _B$, ( _DTLEN := StrLen(_DT) // 2 ), 0 )
 NumPut( "0x" . SubStr(_DT, 2*A_Index-1,2),_B$,A_Index-1,"Char" )  ; Creating Structure
_pIWEB := &_B$, _pV := &_B$+16, _DlgT := &_B$+32   ; Relevant pointers to Structure
DllCall( "GetModuleHandle", Str,"atl.dll" ) ? 0 : DllCall( "LoadLibrary", Str,"atl.dll" )
DllCall( "atl\AtlAxWinInit" ),          _DlgP := RegisterCallback( A_ThisFunc,0,4,0xCBF )
VarSetCapacity( _W$,_B$L,0 ), DllCall( "RtlMoveMemory", UInt,&_W$, UInt,&_B$, UInt,_B$L )
_pIWEB := &_W$, _pV := &_W$+16, _DlgT := &_W$+32         ; Relevant pointers to Structure
Butt:="OK", BWid:=75, BHei:=23, BSpH:=5, BSpV:=8, BAli:=1, Slee:=-1, HtmC:=0, CliC:=0
HtmD:=0, DlgT:=0, DlgN:=0, DlgX:="", DlgY:="", HtmW:=240, HtmH:=140, Left:=0, TopM:=0
Loop, Parse, _Options, =%_ODL%, %A_Space%        ; Override Variables with user 'Options'
  A_Index & 1  ? (  __  := (SubStr(A_LoopField,1,1)="_") ? "_" : SubStr(A_LoopField,1,4))
               : ( %__% := A_LoopField )
Cap  := DllCall( "GetSystemMetrics", UInt,4  ) ; SM_CYCAPTION    = Window Caption
Frm  := DllCall( "GetSystemMetrics", UInt,7  ) ; SM_CXFIXEDFRAME = Window Frame
NumPut( HtmC<>0 ? 0x200 : 0x0, _W$, 32+68 ), DlgD := DlgD ? 0x8000000 : 0x0
FonS ? NumPut( FonS < 8 ? 8 : ( FonS > 14 ? 14 : FonS ), _W$, 64, "UShort" ) : 0
If (  ( DlgS := SubStr( DlgS,1,1 ) ) <> ""  )
 _ := ( DlgS = "F" ) ? NumPut( 0x800000C0 | DlgD, _W$, 44 ) | ( Cap := 0 )
   :  ( DlgS = "N" ) ? NumPut( 0x80000040 | DlgD, _W$, 44 ) | ( Frm := Cap := 0 )
   :  ( DlgS = "B" ) ? NumPut( 0x80800040 | DlgD, _W$, 44 ) | ( Cap := 0 ) | ( Frm := 1 )
   :                   NumPut( 0x80C800C0 | DlgD, _W$, 44 )
IfNotEqual,DlgB,, SetEnv,_Brush,% DllCall( "CreateSolidBrush", UInt,DlgB )
_hDLG  := DllCall( "CreateDialogIndirectParam", UInt,_hInst, UInt,_DlgT, UInt
,_Owner := ( _Owner <> "" ) ? _Owner : DllCall( "GetShellWindow" ), UInt,_DlgP, UInt,0 )
VarSetCapacity( _WU, StrLen(_URL) * ( A_IsUnicode ? 1 : 2 ) + 2, 0 )
A_IsUnicode ? _WU := _URL : DllCall( "MultiByteToWideChar", UInt,0, UInt,0, UInt,&_URL
                                    , Int,-1, UInt,&_WU, Int,StrLen(_URL)+1 )
_hHTM := DllCall( "GetDlgItem", UInt,_hDLG, UInt,100 )
DllCall( "atl\AtlAxGetControl", UInt,_hHTM, UIntP,_ppunk )
DllCall( NumGet( NumGet( _ppunk+0 )+4*0 ), UInt,_ppunk, UInt,_pIWEB, UIntP,_ppwb )
DllCall( NumGet( NumGet( _ppunk+0 )+4*2 ), UInt,_ppunk ),_pwb := NumGet( _ppwb+0 )
DllCall( NumGet(_pwb+4*11),UInt,_ppwb, UInt,&_WU, UInt,_pV,UInt,_pV,UInt,_pV,UInt,_pV )
DllCall( NumGet(_pwb+4*2), UInt,_ppwb )
DllCall( "SetWindowPos", UInt,_hHTM,Int,0,Int,Left,Int,TopM,Int,HtmW,Int,HtmH,UInt,0x14 )
IfNotEqual,HtmD,0, Control,Disable,,,ahk_id %_hHTM%
DlgW := Frm + Left + HtmW + Frm + Left,       ClAW := DlgW - Frm - Frm ; ClientArea Width
DlgH := Frm + Cap + TopM + HtmH + BSpV + BHei + BSpV + Frm
DlgX := ( DlgX <> "" ) ? DlgX : ( A_ScreenWidth - DlgW ) // 2
DlgY := ( DlgY <> "" ) ? DlgY : ( A_ScreenHeight - DlgH ) // 2
StringReplace, Butt,Butt, /,/, UseErrorLevel
bCount := ErrorLevel+1
BY := TopM + HtmH + BSpV
BX := ( Bali=1 ? ( ( ClAW - (BSpH*(bCount-1)) - (BWid*bCount) ) / 2 )
   :  ( Bali=0 ? ( ( BSpH * 2 ) + ( HtmD ? 0 : Left ) )
   :  ( ClAW - (BSpH*(bCount+1)) - (BWid*bCount) - ( HtmD ? 0 : Left ) ) ) )
Loop, Parse, Butt, /   ;  SetWindowPos flags = SWP_SHOWWINDOW|SWP_NOACTIVATE|SWP_NOZORDER
  DllCall( "SetWindowPos", UInt,BH:=DllCall( "GetDlgItem", UInt,_hDLG, UInt,100+A_Index )
                       , UInt,0, Int,BX, Int,BY, Int,BWid, Int,BHei, UInt,0x40|0x10|0x4 )
, DllCall( "SetWindowText", UInt,BH, Str,A_LoopField ),   BX := BX + BSpH + BWid
, _ := ( BNoT<>"" ) ? DllCall( "uxtheme\SetWindowTheme", UInt,BH, UInt,0, UIntP,0 ) : 0
, _ := ( BSFl<>"" ) ? DllCall( "SetWindowLong", UInt,BH, Int,-16, UInt,0x50018000 ) : 0
BDef := ( BDef < 1 || BDef > bCount ) ? 1 : BDef ; Force Default Button
DllCall( "SendMessage", UInt,_hDLG, UInt,0x401, UInt,100+BDef, UInt,0 )    ;  DM_SETDEFID
DllCall( "SetWindowText", UInt,_hDLG, Str,Titl ? Titl : A_ScriptName ) ; Set Dialog Title
DllCall( "SetWindowPos", UInt,_hDLG, Int,DlgT ? -1 : 1, Int,DlgX, Int,DlgY, Int,DlgW, Int
                       , DlgH, UInt,0x10 )         ; DlgTopmost ? HWND_TOPMOST : HWND_TOP
While ( nReady <> 4 && DlgW<>"" )  ;  wait until webpage-load adapted from Seans's IE.ahk
  Sleep % 1 + ( DllCall( NumGet(NumGet(1*_ppwb)+224 ), UInt,_ppwb, UIntP,nReady ) >> 32 )
Sleep, %Slee%
DllCall( "ShowWindow", UInt,_hDLG, Int,DlgN ? 8 : 5 ) ; DlgNA ? SW_SHOWNA : SW_SHOW
IfNotEqual,HtmF,0, ControlFocus,, ahk_ID %_hDLG%
WinWaitClose, ahk_id %_hDLG%,, %Time%
TimedOut := Errorlevel  ? DllCall( "EndDialog", UInt,_hDLG, UInt,0 ) : 0
IfNotEqual,AltR,, IfGreater,BDef,0, StringSplit,B,Butt,/
DllCall( "SetLastError", UInt,TimedOut ? 1 : 0 )
Return AltR ? B%BDef% : BDef
>-  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  -  O P T I O N S  -  -<
Usage: HtmDlg( URL, hwndOwner, Options, OptionsDelimiter )
Parameters :
URL              - A valid URL supported by Internet Explorer including Res:// and File://
hWndOwner        - Handle to the parent window. If invalid handle or 0 ( zero ) is passed,
                  the dialog will have a taskbar button. Passing "" as a parameter will
                  set 'Progman' the owner, thereby supressing the 'Taskbar Button'.
Options          - A series of 'variable overrides' delimited with character specified in
                  'Optionsdelimiter'. Please refer 'VARIABLE OVERRIDES' below.
OptionsDelimiter - The delimiter used in seperating 'variable overrides'
;  * * *   V A R I A B L E   O V E R R I D E S   * * *
Important Note: leading 4 characters of a variable will be sufficient.
               for eg.: Instead of 'AltReturn=1' you may use 'AltR=1'
DlgXpos         = X coordinate in pixels, relative to screen
                 Dialog is horizontally centered by default
DlgYpos         = Y coordinate in pixels, relative to screen
                 Dialog is vertically centered by default
DlgTopmost      = 1 will set the Dialog 'Always-on-Top'
                 0 is default
DlgDisable      = 1 will disable the Dialog window
                 No default value
                 Caution:
                 Since there is no way to interact, you may opt to TimeOut the Dialog
DlgStyle        = Frame or NoFrame or Border. Leading character is sufficient, like: F-N-B
                 Default is Caption
                 Note on Styles used:
                 Frame   = WS_POPUP | DS_MODALFRAME
                 NoFrame = WS_POPUP | DS_SETFONT
                 Border  = WS_POPUP | DS_SETFONT | WS_BORDER
                 Caption = WS_POPUP | DS_MODALFRAME | WS_CAPTION | WS_SYSMENU
                 WS_DISABLED is additionally set when DlgDisable=1
DlgNoActivate   = 1 will Show the Dialog without activating it
                 0 is default
DlgBgColor      = ColorRef.  eg: 0x0000FF is Red / Invalid ColorRef will result in Black.
DlgWait         = 1 will delay Dialog from being shown - until HTM is fully loaded
Sleep           = MilliSeconds ( Will be used just before Dialog is shown )
                 Default value is -1, 'No sleep'
Title           = Captionbar Text
                 Default is A_ScriptName
AltReturn       = 1 will return Button-text
                 0 is default and Button-instance will be returned
TimeOut         = Seconds
                 No default value
                 Note: A_LastError will be true when a TimeOut occurs
ClickClose      = 1
                 Default value is 0
                 Note:
                 Mouse L-Click on window's unoccupied clientarea' will close the dialog
                 Tip: Use following to simulate a unobtrusive message ( like TrayTip )
                 DlgTopmost=1, HtmD=1, DlgNA=1, DlgStyle=Border, BHei=0, BSpV=0, Clic=1
LeftMargin      = Spacing in Pixels ( on the left/right sides of WebControl )
                 Default value is 0
TopMargin       = Spacing in Pixels ( above the WebControl )
                 Default value is 0
FonName           ( Not implemented yet )
                 Default is 'MS Shell Dlg' and equivalent
FonSize         = Pointsize ( text size of Button-labels - restricted to 8,10,12,14 )
                 Default value is 8
HtmClientEdge   = 1 to set WS_EX_CLIENTEDGE
                 Default value is 0
HtmDisable      = 1 to disable
                 Default value is 0
HtmWidth        = Width of WebControl in Pixels
                 Default value is 240
HtmHeight       = Height of WebControl in pixels
                 Default value is 140
HtmFocus        = 1 will activate the dialog and WebControl will have input focus
                 Default value is 0
                 Note: DlgNoActivate option will lose effect.
                       For best result, use this option along with DlgWait=1
Buttons         = Button labels seperated with "/"  eg: Buttons=Yes/No/Cancel
                 Default Button is "OK"
BDefault        = Instance of Default Button. eg: To make 3rd Button default, use BDef=3
                 Default forced value is 1
BEscape         = Instance of Button to return when dialog is closed or {Esc} is pressed
                 Default is 0
BWidth          = Button Width in Pixels
                 Default Value is 75
BHeight         = Button Height in Pixels
                 Default value is 23
BSpHorizontal   = Pixels ( affects the spacing on the sides of a button )
BSpVertical     = Pixels ( affects the spacing above/below a button )
BAlign          = 0 or 1 or 2  ( for Left, Center, Right alignment of buttons )
                 Default is 1
BNoTheme        = 1 will remove theme from buttons ( XP & greater )
                 No default value
BSFlat          = 1 will flatten the button by removing the 3D edge - requires BNoTheme=1
                 No default value
Edited by majstang
add spoiler
  • Like 2
  • 3 weeks later...
Great stuff maj.
Im on x64 so cant test but this is a great step forward!
This requirement really should be implemented directly in DVBViewer though.
Thanks subvertbeats!
Well, actually I don't know with certainty if the script does work on 64-bit systems or not, cuz I have no 64-bit system installed...ergo haven't tested it yet. It may work.
With a little luck we don't have to wait long before similar functions will be DVBViewer compatible. Hackbart promised to look over the old Comskip-DVBViewer plugin code. Hopefully he will held up this promise sometime soon :)
http://www.DVBViewer.tv/forum/topic/37350-zoom-player-cut-list-to-DVBViewer/page__view__findpost__p__330481
  • 5 weeks later...
Thats great news maj! Keeping my fingers crossed :)
  • 3 months later...
Made some improvements on the CommercialRemoval script:
- If script gets triggered from the Intelligent hibernationscript after recording task it has no longer
any limitation on how many recordings to remove commercials from. For example if having 10 tuners and
all finishing their recordings simultaneously all will be processed. If one tuner finish the recording
before the others only the finished recording will be processed.
- Added property/metadata copy from input to output file with Grigas PropCopy. Use the recordings
properties for Windows Explorer to better see the result (choose this option on one of the first
splash screens when installing RS)
- Improved the error management handling a bit
- Added a PATH CONFIGURATION section. Your path information is needed to get the script going.
For other options like Comskip H.264, transparency and drag 'n drop batchprocessing follow
the instructions in the first post of this thread.
Remaining issues
- During heavy CPU/RAM load at the same time doing commercial removing, a VideoReDo error message can
appear telling you "Server is busy". I'm still not exactly sure on why it shows, but if it does either
let it be (script will try to redo this step one time). Tried newer versions of VideoReDo, but they were worse.
Best working version is still VideoReDo TVSuite v.4.20.5.600.
- Sometimes Comskip confuses audio PID with Teletext PID on the .ts recording and when passed to VideoReDo it
tries to recode audio. VideoReDo crashes when this happens and it won't work removing commercials from this .ts ever.
The problem occurs if having Teletext or DVB Subtitle activated in Recording Service Output Format Options.
It is recommended to disable those, cuz VideoReDo wont keep this kind of subtitles on edited .ts anyway.
Edited by majstang
  • 4 months later...
New CommercialRemoval script
Changes: To get rid of the very annoying "Server is busy" message error I found a way to make the VideoReDo commercial editing entirely commandline based. The script no longer starts any visible Videoredo batch manager GUI, everything now takes place in a command prompt, which can be hidden if so preferably. That also fixes the issue with the script being sensitive to mouseclicks and keystrokes.
Changes: More and more channels tend to use their logo even on the commercials...making Comskip unabled to detect it. Some other detecting methods can then be used. You will then end up with different comskip.inis for different channels. The script can detect which channel the recording is made on and assign a special comskip.ini for it. In my case for example TV3.ini which works very well detecting all commercials (where the original comskip.ini fails). Setup for this can be done in the "RETRIEVE MEDIAFILE FORMAT - MPEG-2 OR H.264" and "COMSKIP FILE PROCESSING" section.
Notes: The latest VideoReDo version 629d, indtroduced support for multiple audiostreams. Default is enabled. The CommercialRemoval script fails with the default, cuz Comskip is not yet adapted to the changes introduced in the new Videoredo version. To disable it:
- Start VideoRedo-->Hold down "Shift"-->Click "Tools"-->Click "Options"
- In the list that follows scroll down to "70. Support for multiple audiostreams" and change 1 to 0.
- Press OK and restart VideoReDo. Support for multiple audiostreams is now disabled
Notes: Recent Comskip versions can be configured using all 4 CPU cores at once making commercial detection 100% faster for H.264 material.
Remaining issues: Sometimes Comskip confuses audio PID with Teletext PID on the .ts recording and when passed to VideoReDo it
Edited by majstang
The audio/subtitle PID confusion issue has been fixed. Comskip v.81.022 (donators version) now also supports detecting of the subtitle PID which enables keeping subtitles when Videoredo is done cutting out the commercials. Comskip creates project files, the VPrj. When opening a .ts without a project (Vprj) in Videoredo, it automatically searches and detects video, audio and subtitle PIDs, but once a project file is used (like with this script), Videoredo grabs all the PIDs from the VPrj file and bypasses the ordinary search. Earlier Comskip versions only retrieved Video and Audio PIDs and skipped the subtitle PID, hence the subtitles got lost in the Videoredo editing process. Now that is changed. The only thing needed is the new Comskip version and to activate Teletext and/or DVB Subtitle in Recording Service Output Format Options. No changes has been made on the Automatic Commercial Removal script.
Changes/fixes:
- Looping folders to find the location for Comskip.exe and VideoReDo Vp.vbs script took too much time. So long the commercial removal script after recording task somtimes missed detecting when a recording finished (grace period of 90 seconds). Often happened during heavy HTPC load (many recordings going at once, downloading etc).
Replaced the looping with absolute paths, which speeds up the script considerably and it never misses detecting any finished recordings. See the PATH CONFIGURATION section.
- Removed some errorhandling and instead added a variable for configuring if having the Comskip H.264 donators version or not. Earlier if not having the Comskip H.264 version the script did exit/stop entirely if detecting a H.264 file, despite MPEG-2 recordings was queued up for commercial removal right after it. If "Use_H264_commercialdetetction" is disabled the script wont halt and exit if a H.264 file is detetcted and process will continue if there's queued up MPEG-2 files after it.
Updated the first post of this thread and placed all scripts there.
Last changes of this script:
- Hidden mode now gets activated/inactivated in the "PATHS AND CONFIGURATION" section only.
Happy new year!
Regards
majstang
  • 2 months later...
DVBViewer Recording Properties now can be installed on 64 bit system. Does that mean this script can work ?
Hi utku!
In theory yes! I will get back to you on that when finding some time to test it out the coming next days :)
regards
majstang
Yes, the Automatic Commercial Removal script now works beautiful on 64-bit Windows with the new DVBViewer Recording Properties v.2.0. Many thanks for that Lars :biggrin:
No problem to get it to work at all. I just installed the DVBViewer Recording Properties v.2.0 and changed the "VideoredoBatchLocation" path to the vp.vbs (VideoRedo batch script) in the PATHS AND CONFIGURATION section in the Automatic Commercial Removal script. Usually when installing VideoRedo on a 64-bit system it gets located to the "C:\Program Files (x86)\VideoReDoTVSuite4\vp.vbs" folder.
Recommend to launch the commercial removal script through the Intelligent Hibernationscript, which delays the standby/hibernation until the commercial removal task is done. http://www.DVBViewer.tv/forum/topic/41387-another-intelligent-hibernationscript/
Regards
majstang
thats great news :) finally, i been waiting so long for this.
I am trying to get code working, but i have a problem.
i choose dvbRecProp_Beta_setup.exe but it doesnt work, then i tried DVBVPropertyHandler.dll it doesnt work neither.
Yes, these fileinfo/propety/metadata tools can be confusing at first not knowing what they really are doing and good for. DVBViewer Recording Properties v.2.0 (dvbRecProp_Beta_setup.exe) and the PropCopy are two separate tools.
- RS uses the DVBViewer Recording Properties tool to enable the Vista/Windows 7 explorer to show the detailed fileinfo for DVBViewer recordings. This tool should only be installed on your system and applying paths to this tool isn't needed in the script.
- Unfortunately when editing the original recording with VideoRedo this detailed fileinfo (often stored somewhere in the beginning of the original recording) simply gets wiped out in the edited copy/output. The PropCopy tool is then used to copy the fileinfo from the original recording over to the commercial-free recording. PropCopy is a tool which can be downloaded from: www.DVBViewer.tv/members/
Using the script without this tool requires some minor code changes on several places and I therefor think the easiest way to make it work for you would be to download it and apply the path to it in the PATHS AND CONFIGURATION section in the script.
Regards
majstang :bye:
Edited by majstang
hi again, sorry for taking your time, also thank you for all the answers.
RS_Recording_folder := "C:\Users\utku\Desktop\kayitlar" ;Fill in path to RS Recording Folder
PropCopy_location := "C:\Users\utku\Desktop\basla\PropCopy.exe" ;Fill in path to PropCopy
Comskip_location := "C:\Users\utku\Desktop\yeni son kom\comskip.exe" ;Fill in path to Comskip
VideoredoBatchLocation := "C:\Program Files (x86)\VideoReDoTVSuite4\vp.vbs" ;Fill in path to vp.vbs
here is my paths and configuration section. Im sure all the paths are correct.
Also i deleted ; from Use_H264_commercialdetetction to use H264 detection.
When i drag and drop a ts file to CommercialRemover.exe Shortcut, program starts in taskbar and then after certian time(5 to 10 seconds) there is one command line window opened and closed in one second, then CommercialRemover.exe taskbar icon dissapers.
How can i debug this code ? i have visual studio 2010 installed on pc.
i also have i7-2600k like you, which overclocked to 4.6ghz and using comskip 81_034_donators also thread_count=8,
i am seeing 170fps to 220 fps on h264 and computer doesnt exceeds %20-30 percent.
what do you fps see on h264?
Thanks a lot, again.
Utku
Seems it's the comskip step failing for you. You will have to check if all variables has correct values in the script, which are then fed to comskip. First of all make sure setting up RS Webinterface-->Configuration-->Recorder-->Output Format-->Video/Audio TS (*.ts). Trying to make comskip detect commercials on mpg files won't work because of the -t parameter (which stands for ts files) when the script calls comskip.
Also make sure your comskip.ini is present in the comskip folder.
A little tip when testing and trying to make the script work. It's easier to dragndrop the files onto the ahk script itself instead of the exe shortcut. Then you wont have to compile it each and every time when doing changes in the ahk.
Debugging Autohotkey scripts doesn't require any tool else other than a texteditor, preferably Notepad++. You then add messageboxes for the variables to check their input values. For example like this:
 Else
 Loop %GivenPath%, 1
 msgbox % latest_file_drop ; File dropped on script
 msgbox, %MPEG2%`n`n%H264% ; Checks if dropped file is MPEG2 or H.264
 Else
   ExitApp
 Else
  If MPEG2
     If TV3 or Sjuan
		 If TV3=
          If Sjuan=
  Else
      Sleep, 3000
   If MPEG2
      If H264
right_Now := a_now
FileList =
b_index=0
    b_index++
Loop %b_index%
 Else
 ExitApp
Else
If MPEG2
     If TV3 or Sjuan
        If TV3=
          If Sjuan=
Else
      Sleep, 3000
   If MPEG2
      If H264
  Loop
     if not iAttribute
        break
First msgbox checks the file dropped onto the script. The second checks if the dropped files are a MPEG2 or H.264. If the latter msgbox are empty there is something wrong with the DVBViewer Recording Properties values, which will make the comskip step failing and script exits without any error message. Let me know what you see here.
I have the h264 function inactivated, cuz my HD channels has no commercials. Have no HD recordings saved at the moment, but will record some and check later.
EDIT: My comskip fps rate on h264 is about 1100 fps with thread_count=8. No overclocking.
Edited by majstang
Man you are genius :)))
Yes you were right, comskip step was failing. After i moved the CommercialRemover.ahk to Comskip folder it ran succesfully but than Videoredo step was failing and Second msgbox saved me. As you can see on printscreen "RETRIEVE MEDIAFILE FORMAT" section does not get the format and second message box is empty.
Than i remove the if statments for MPEG2 and H264 now the code works. :))))
      Sleep, 3000
I did now understand why DVBViewer Recording Properties does not work. Isnt Recorded Tv section available means that my Recording Properties work ?
Also thank you for all your tips, it helped a lot, i have at least working code. I am using Notepad++ now. :)
Last, Are you sure that you see 1100 fps on h264 material ? because i see 1100 fps only on MPEG2, also comskip has a bug that it cant use all the i7's power, example on mine, it does not exceeds %30 percentage. Are tested on 32 bit or 64 bit?
Thanks again.
Utku.
Yes you were right, comskip step was failing. After i moved the CommercialRemover.ahk to Comskip folder it ran succesfully but than Videoredo step was failing and Second msgbox saved me. As you can see on printscreen "RETRIEVE MEDIAFILE FORMAT" section does not get the format and second message box is empty. I did now understand why DVBViewer Recording Properties does not work. Isnt Recorded Tv section available means that my Recording Properties work ?
Hi Utku!
Actually your Recording Properties details looks fine to me. The script searches for the "Video compression" value and as marked in the second properties picture of yours, the value are valid. Now the reason for the script fails finding the videocompression value could be permissions/security related. In other words it could be problematic to locate executable files and other files the script has to access in the C:/users directory. I have stumbled on this very thing before when scripts are being denied access (or partly denied) to files in the users folders. Even the Windows partition and more particular the program files folder can be problematic for scripts to access and it can therefor be a good idea to move the RS recording folder, comskip and the script to some other partition or folder.
Well, if not using the If statements videoredo wont work alright when it tries to edit a H.264 which is in fact a MPEG2 and vice versa. Could be problematic.
Yes, the 1100 fps for H.264 was tested on my 64-bit system with 8GB RAM and for MPEG2 it was 2300 fps. Haven't checked the CPU load though.
Best regards
majstang
Edited by majstang
Hi Utku!
Just tested comskip on a H.264 with both 32- and 64-bit and it's the same 1100 fps, but for me i have a CPU load of 80-85%. All 8 threads are used (two per core). I remember reading somewhere in the comskip forum people had problems getting it to work. Didn't take much notice of it though cuz it worked the first try for me.
regards
majstang
