hoto44 Posted August 19, 2012 Posted August 19, 2012 (edited) OSD- Skin "reflex - bbw" updated 09th September 2012. Please let me know if you discover anything that still needs fixing (or provide a fix and post the file here in this post). Help is always appreciated. Skin requires Mr.SkinHelper-plugin (BluFuzz by SnoopyDog). You also need the font Aeon_main installed on your system. It is in the fonts folder of the skin. Please then install Aeon_main from there. For installation please see here: http://www.DVBViewer...sd-skin-e-x-bw/ http://www.DVBViewer...kin-experience/ http://www.DVBViewer...in-evolution-x/ http://www.DVBViewer...n-mod-v2-final/ Kind regards hoto44 images1.zip images2.zip reflex - bbw.zip Edited September 9, 2012 by hoto44 Quote
uglyrooster Posted August 20, 2012 Posted August 20, 2012 Very nice. Just an option with additional (EPG-)informations on the Mini-EPG and it is nearly perfect. Quote
hoto44 Posted August 21, 2012 Author Posted August 21, 2012 ...what do you mean by "Just an option with additional (EPG-)informations on the Mini-EPG". If you could please describe it a little more in details so I know whats maybe missing or can be done. Apart from that - many thanks for the compliment. Its good to here after all the "hard" skinning work. Kin regards hoto44 Quote
uglyrooster Posted August 23, 2012 Posted August 23, 2012 Your skins are really my favourite. The only reason I am using them only on PC and not on the mediacenter is the Mini-EPG problem I described: Most of the skins have an option to decide: You want just the EPG-headline(s) or also some more details. During zapping it is really helpful to have the first details and not just the headline of EPG. I changed it some years ago for older skins, but most of the skins have it anyway or a modified Mini-EPG (and I forgot how to change it ;-)). Quote
hoto44 Posted August 23, 2012 Author Posted August 23, 2012 I will have look at it and maybe redesign hoto44 Quote
onkyo607 Posted August 26, 2012 Posted August 26, 2012 Please help me! No understand where to copy images1.zip and imagaes2.zip ? Quote
hoto44 Posted August 26, 2012 Author Posted August 26, 2012 please select the files(not the two folders) of images 1 and 2 and copy them into the images folder of the osd skin hoto44 Quote
hoto44 Posted September 9, 2012 Author Posted September 9, 2012 OSD- Skin "reflex - bbw" updated 09th September 2012. Mainly bugs fix in my myEPG-Search and design adjustments where I felt its needed. Kind regards hoto44 Quote
cundogg Posted March 5, 2013 Posted March 5, 2013 This is one of the best laid out skins I have seen. Thanks and well done. Is there any other colours available for this? Quote
