Search the Community
Showing results for tags 'black screen'.
Black screen on encrypted channels, worked fine before
Specy posted a topic in General DVBViewer Pro/GE
Hi, I've been using DVBViewer Pro for a long time now (I think since around 2008) without any issues. But as of recently I'm unable to view or record any encrypted channels. I have a CAM module in my SkyStar USB 2 HD CI receiver. DVBViewer sees the CAM and can talk to the card that's in it (it reports the card number among others). This affects both HD and SD channels, and if I record to a file I get a very small (nearly empty) file. Signal strength looks good, EPG is decoded properly. I do not see any decryption errors. Some important background: My provider (Canal Digitaal, NL) has recently rolled out a firmware update to their receivers which among others blocks the SmartWi that I was using until recently. When this happened, I couldn't receive any channels in my living room anymore (the decoder refuses to work even on non-encrypted channels without a card). So I took the card out of my SmartWi and put it in the receiver. Today I wanted to put it in my PC CAM module again to check if everything is still working (in that case I'm going to order an extra card), but so far it doesn't. I was still running a very old version of DVBViewer, updated and rescanned all the channels, but that didn't change anything. support.zip is attached, in case that helps... support.zip -
Hallo, nach erfolgreichem Sendersuchlauf und erstmalig funktionierendem DVB-T Empfang, geht Audio und Video nicht mehr nach dem zweiten Start des DVBViewer. Mein PC ist Lenovo Convertible mit Windows 10 und LVA codecs. Graphik ist Intel 4000 und DVB-T stick ist avermedia A867. Vielen Dank im voraus Gerrit support.zip
