Search the Community
Showing results for tags 'raw data'.
More search options
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 1 result
  1. I am dealing with the epg data (try to convert them to json, try to find out what kind of information is available) and have found this site which provides epg data.(http://xmltv.se) The information they provide are a little different from the xml data I get from the api. I have attached two snippets - one from xmltv one from a Mediaserver api call. - both from the same event. Inspector Banks, 4.6.2017 in the night. The main difference is: actors , writers (credits section) is more detail from xmltv and more text from Media Server. Additional the have ( "new": null, --> maybe an information if this event is first time on this channel) and "category": { "en": [ "series", "Crime" ] }, maybe same als <content>16</content>? My Question; Is the raw information stream more like xmltv or do you both have different sources? Background - when I try to filter the epg stream flat text is not as good as structured text. Oh - I must rename the json file to json.txt because json was not allowed. zdfbanks.xml zdfbanks.json.txt
