Search the Community
Showing results for tags 'strong ci'.
  • Search By Tags
  • Search By Author
Content Type
Forums
  • Deutsch
    • Ankündigungen & Neuigkeiten
    • Vorschläge & Ideen
    • Plugins und AddOns
    • DVBViewer Media Server
    • Verschiedenes
    • DVBViewer Video Editor
  • English
    • News & Announcements
    • Newbies DVBViewer Pro/GE
    • General DVBViewer Pro/GE
    • Suggestions & Ideas
    • Plugins and AddOns
    • Off-Topic
  • Miscellaneous
    • Area HTPC
    • HDTV / UHDTV (de/en)
    • DVB - The technique behind
    • Conversion & Encoding
  • Survey ● Umfragen
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
Found 1 result
  1. Hi all, I wanted to make my current media center able to receive dvb-s. I haven't got the possibility to expand using pci slots so i had to go with an USB solution. I read a couple of forums and came to the conclusion that the terratec s7 (usb tuner + CI) and the Strong (CAM) should work with my provider (Canal Digital). i can't seem to get this to work. DVBViewer seems to find all the channels, but they are all encrypted. I get a message on my screen stating this "No access. If you are subscribing to this chanel wait until the card has been updated. This can take up to 2 hours. Do not change the channel in the meantime". So i waited and waited. Nothing happened. I had it running over night and all the channels is still encrypted this morning. I was wondering if anybody else had the same problem or has a working setup using usb and canal digital? Any help is very much appreciated. -Fantastisk
