Search the Community
Showing results for tags 'web interface'.
First, thanks for some good products which I have used since 2011. I have just upgraded to - Mediaserver 2.0.4.0 - DVBViewer 6.0.4.0 ... and ... an old problem came back. My list of recordings in the Web inteface now only includes 114 of 145 recordings. What has happened so far moved recording folder to a new NAS (using a UNC-path for access) Upgraded DVBViewer and Media Server Moved a few recordings from the PC to the NAS (the wrong location was caused by Media Server installation which did modify the windows service login info) Then I noticed that the list of recordings in the Web-Interface was mising some recordings. I have reported this problem in 2014 see http://www.DVBViewer.tv/forum/topic/55334-workaround-fixing-incomplete-recordinglist-in-webinterface/?tab=comments#comment-414931 What is NOT working Update Database (and also with variation of Clean Up Database and Clear Recording History) Stop server, delete SvcDatabase.db3 and restart server Trying 2. did in fact loose another 6 recordings What is working Rename the .ts, .log and .txt file followed by an "Update Database". I just add an "xxx" in front of the file extension. This works exactly as reported in 2014 and the only difference seen from the Media Server is the changed filenames. My conclusion is the same as in 2014 that the filename is cached somewhere preventing correct detection. A workaround I can easily send a script through and rename all the files - but would rather learn what is wrong, so I will wait a few days before I do this. Question/Way Forward I could not find any debuging of the "Update Database" task. It would be nice to see why some recordings are rejected. What should I do next? Will a suppot ZIP include debug info from "Update Database"?
- 13 replies
- mediaserver
- web interface
(and 1 more)
Tagged with:
Hallo, Ich habe mich mal am Web Interface versucht um von Extern auf mein DVB-Server 2.0.0.4 Zugriff zu erlangen. Port freigaben in einer 7490 erst mal keine Probleme sowie Dynamic DNS Adresse. Zugriff Lokal klappt sowohl PC als auch Handy im Brower Extern sieht die Sache aber ganz anders aus. Da geht komischerweise nur der Zugriff per PC Browser ohne Probleme. Aber auf ein Andriot Handy oder Tablett geht da nix da kommt immer Time out Fehler. Ich hatte schon versucht die Ports zu ändern, aber daran liegt es nicht in Firewall habe ich nachgeschaut, da sind zum Server alle Ports sowohl UDP als auch TCP freigegeben. Kann mir da einer weiterhelfen ? weiß nicht wo ich noch suchen soll. Per VPN Verbindung habe ich noch abgesehen da ich noch ein Verschlüsselung Dienst laufen habe der die Verbindung sichert.von PC aus. Die Freigaben auf den Externen Zugriff laufen aber alle über den Router. Hatte auch schon Versucht alles abzuschalten aber auch ohne erfolg. Mfg. Night-Lord
Web service nur über localhost erreichbar (nicht über IP)
asdfasdf2 posted a topic in Einsteigerfragen DVBViewer Pro/GE
Hallo, ich kann meinen lokalen Recording Service im Browser über http://localhost oder http://127.0.0.1 gut erreichen, aber nicht über http://192.168.178.63 (was meine lokale IP ist). Port ist 80. Da kommt nur eine weiße Seite (der Browser sagt 404)... Dieses 404 kommt dann natürlich auch im LAN... Was kann der Grund sein? Danke und schönen Gruß a.- 6 replies
- localhost
- ip address
(and 3 more)
Tagged with:
Ich habe den alten Recording Service deinstalliert und nun den neuen Media Server installiert. Wenn ich den neuen DVBViewer öffne kann ich auch auf die Fernsehsender zugreifen und Bild und Ton funktioniert. Im Menü Server konfigurieren habe ich unter Web Einstellungen ein Benutztername und Passwort angegeben. Egal ob ich nun versuche über das Kontextmenü das Web Interface aufzurufen oder auch direkt im Browser die IP Adresse gefolgt vom Port eingebe ich werde zwar nach dem User und dem Passwort gefragt, sobald ich dies eingegeben habe kommt jedoch nur 404 not found the requested url / index.html was not found on this server. Was mache ich da falsch bzw. wie lässt sich denn das Problem beheben das ich auch auf das Webinterface zugreifen kann? Unter dem DVBViewer Verzeichnis liegt zumindest ein Unterordner SVCweb und da ist auch eine Datei index.html enthalten. Daher weis ich nicht so ganz was die Ursache ist bzw. wo den die index.html gesucht bzw. erwartet wird.
