Search the Community
Showing results for tags 'wintv-solohd'.
Hauppauge WinTV-soloHD - only some channels found
BZD posted a topic in DVB Hardware (Digital TV cards)
For years I have been using the Terratec Cinergy HTC Stick on Windows 7/8 computer and using DVBViewer Pro without issues, however moving to a new computer with Windows 10 I could not get the Cinergy HTC Stick drivers to work so I acquired the Hauppauge WinTV-soloHD. Unfortunately the WinTV-soloHD / DVBViewer combination is giving me grief. Through the forum I learned that there was a Hauppauge service which I needed top stop running as it blocked DVBViewer from using the WinTV-soloHD, however having solved that I now find that the only a fraction of the TV channels available are found and no radio channels at all(list is included). What to do? I'm located in Denmark and using cable with Yousee as the cable provider. If I run the WinTV V10 software that came with WinTV-soloHD there is no problem accessing all the usual channels, same ones I also had with the Cinergy HTC/DVBViewer combination on my old computer. A list of those channels as they shown with the WinTV is attached. Needless to say, apart from finding all the channels WinTV is a program that is severely lacking. support.zip- 11 replies
- wintv-solohd
- hauppauge
(and 3 more)
Tagged with:
