Lars_MQ Posted May 16, 2007 Posted May 16, 2007 OK, I take down the old Plugin and move the new Plugin from the Beta Section to the Plugin section. So there is no need to download it again. Quote
VanNameless Posted May 18, 2007 Posted May 18, 2007 My TTRemote plugin for DVBViewer ( Technotrend Remote Plugin 1.1.0 ) don't Work with the new - TT-budget / Nova BETA Version 5.0.0.2 (15.05.07) Driver. My TV-Card = TT 3200 S2 My OS = Windows Vista x64 What can i do ? Quote
Lars_MQ Posted May 18, 2007 Posted May 18, 2007 What can i do ? Go back to winXP 32 and use the standard drivers. Quote
CiNcH Posted May 18, 2007 Posted May 18, 2007 Under XP32 the new plugin with new TT API-DLL even works with new beta driver 5.0.0.2. Think we have to wait until TechnoTrend officially releases the 64-bit stuff. Most likely the API-DLL does not work together with the 64-bit driver. Quote
darky Posted May 19, 2007 Posted May 19, 2007 (edited) My TTRemote plugin for DVBViewer ( Technotrend Remote Plugin 1.1.0 ) don't Work with the new - TT-budget / Nova BETA Version 5.0.0.2 (15.05.07) Driver.My TV-Card = TT 3200 S2 My OS = Windows Vista x64 What can i do ? same problem here... --> os: windows vista ultimate 64bit solution? it would be nice if the plugin works also with 64bit! Edited May 19, 2007 by darky Quote
Lars_MQ Posted May 19, 2007 Posted May 19, 2007 The solution was told above. I don't have time or interesst to do anything for vista 64. maybe in 3 or 4 years, if there is a real need to use a 64bit OS for me Either TT corrects this problem or you have to live without remote. Quote
darky Posted May 19, 2007 Posted May 19, 2007 Either TT corrects this problem or you have to live without remote. Which problem exactly? Maybe, I can contact the TT support...? Quote
cescalby Posted May 20, 2007 Posted May 20, 2007 The plugin working perfectly with my S2400 and S2-3600 under xpsp2 thank you Quote
darky Posted May 30, 2007 Posted May 30, 2007 hi, hab mal beim TT-Support angefragt bezügl. der FB mit Vista 64bit und folgendes als Antwort erhalten: Sehr geehrter Herr XXXX, entschuldigen Sie bitte unsere etwas verspätete Antwort. Erstmal vielen Dank für Ihren Hinweis, dieser Fehler ist uns seit neuestem bekannt. Wir versuchen dieses Problem so schnell wie möglich zu beheben und in unserem nächsten Rlease bereit zustellen. Bitte haben Sie noch etwas Geduld. Also kann man ja hoffen, dass das später vllt. funktionieren wird. Quote
karlo Posted June 3, 2007 Posted June 3, 2007 Hmmm.... Hat denn keiner mein Problem mit dem Bildseitenverhältnis? Oder steht darüber etwas in einem anderem Forum was ich übersehen habe? Quote
Lars_MQ Posted June 3, 2007 Posted June 3, 2007 Was hat das bildseitenverhältnis bitte mit einem fernbedienungsplugin zu tun?? Quote
karlo Posted June 3, 2007 Posted June 3, 2007 Grrr...... Natürlich falsches Forum !! Kommt davon, wenn man mehrere Fenster auf hat.... Hab das Problem ja auch in 'BETA' geschrieben..... Tschuldigung Quote
CiNcH Posted June 4, 2007 Posted June 4, 2007 (edited) TT-connect S2-3600 USB2-Box works like a charm too. Edited June 4, 2007 by CiNcH Quote
hagie Posted June 23, 2007 Posted June 23, 2007 Hi, I have a WinTV Nova-HD-S2. It was bundled with a Remote and a small receiver which is attached to the Card. The RC works in Power Cinema with the help of a small programm called ir.exe / irremote.dll which was installed in the WinTV Directory. How can I get this remote to work with DVBViewer? The TT Input Plugin don't show any device to choose from neither does the ttrendtest aplicatopn. Any advice ? Thanks Hagie Quote
Moses Posted June 23, 2007 Posted June 23, 2007 try the ir.exe? What does it do? Send Keyboard-strokes? Then it may work in DVBViewer, too... Quote
hagie Posted June 23, 2007 Posted June 23, 2007 the ir.exe is mandatory for powercinema. It looks like it is bundes with the WInTV software and acts as an interface between Hardware and Software. The programm itself does nothing - the only option is to close the pgrammm. this is the programm called ir32 http://www.hauppauge.de/files/ir32/ir32_2_51_24342.exe Thanks Hagie Quote
Lars_MQ Posted June 23, 2007 Posted June 23, 2007 guys take it to an own thread, this has nothing to do with the technotrend stuff. Quote
Lars_MQ Posted September 4, 2007 Posted September 4, 2007 I updated the Plugin to version 1.1.1. Please check your remote settings. Quote
Lars_MQ Posted September 5, 2007 Posted September 5, 2007 There has been a bug in the last release 1.1.1 . A corrected version 1.1.1a is in the membersarea. Quote
darky Posted September 16, 2007 Posted September 16, 2007 with 64bit (vista), this plugin still doesn't work?! Quote
Mugga Posted September 18, 2007 Posted September 18, 2007 I think you could use Girder 5 beta which is running under Vista and the Girder plugin for DVBViewer. Or when the Plugin doesn't work with the new beta, you can set in Grider the remote buttons to keyboard keys and then use it with DVBViewer. I think i will give it a try when i'm back home, because the remote from my TT-3200 isn't working either under Vista x64 and that sucks! Quote
CiNcH Posted September 18, 2007 Posted September 18, 2007 (edited) Yes, you will need an infrared receiver for the serial port for example which works like a charm. I am using latest Girder freeware version 3.2.9 which also works under Vista together with IgorPlug for serial port infrared receiver control and access. Edited September 18, 2007 by CiNcH Quote
Mugga Posted September 18, 2007 Posted September 18, 2007 do i really need an infared receiver for the serial port? i thougt i could use the receiver from my tv card. But the infared receiver shouldn't be the problem, i have and old one for serial at home. And the 3.2.9 is working unter Vista x64? And is the IgorPlug for DVBViewer or what is this? Quote
CiNcH Posted September 18, 2007 Posted September 18, 2007 (edited) i thougt i could use the receiver from my tv card. You can't unless you write a Girder input plugin implementing the TT-API... And the 3.2.9 is working unter Vista x64? Don't remember whether I have verified that under Vista 32 or Vista 64. Went back to XP anyway... And is the IgorPlug for DVBViewer or what is this? IgorPlug is an input plugin for Girder. It catches the demodulated infrared signals from the serial port receiver and decodes them. Girder then mapps the decoded codes to DVBViewer actions via the DVBViewer output plugin. http://www.cesko.host.sk/girderplugin.htm Edited September 18, 2007 by CiNcH Quote
Mugga Posted September 18, 2007 Posted September 18, 2007 Ok then i will give it a try. Hope this works! Quote
JPL Posted September 20, 2007 Posted September 20, 2007 I looked fews hours in the forum and I could not get a solution to my problem. I have a Skystar 2 with a tts35ai serial remote. I always use it with DVBViewer pro and winlirc, but now with the 3.8.0.0 version, I don't arrive to make the configuration. Before I just had to choose the winlirc plugin in the input plugin, but now it ask for a port etc... If I don't find a solution I will try Girder and igorplus, but if somebody can help me, I will prefer to stay win winlirc Thanks Quote
CiNcH Posted September 20, 2007 Posted September 20, 2007 WinLIRC is for receiving and decoding the incoming infrared signals. It then creates a command and sends it via TCP/IP protocol to all its clients. DVBViewer is a client and connects to the WinLIRC server on a specific port, typically 8765 for LIRC (IP is most likely 127.0.0.1 since the server runs locally). I have never used the WinLIRC plugin within DVBViewer... Quote
JPL Posted September 20, 2007 Posted September 20, 2007 Thank you very much for the quick answer. It´s funny but I gave this information manually again (it was already written), click "apply" and it just work !!! THANKS AGAIN Quote
marosy Posted October 7, 2007 Posted October 7, 2007 (edited) There has been a bug in the last release 1.1.1 . A corrected version 1.1.1a is in the membersarea. Lars, can you add support for Technisat Skystar USB PLUS? The hardware is identical with Technotrend S-2400, maybe the device ID is different. Here is the log of the test application: ttremote.log Thanks. Edited October 7, 2007 by marosy Quote
robby2 Posted October 22, 2007 Posted October 22, 2007 Hi whats up with the S2-3650 USB Box. Is there a possibility for remote controll with the original remote controller?? Thanks Best regards Robert Quote
mark100 Posted October 26, 2007 Posted October 26, 2007 OSD ok deletes recordings on OSD My recordings... Quote
Lars_MQ Posted October 26, 2007 Posted October 26, 2007 mosdt likely it only deletes the database entry cause the recording files are not present. please check. Quote
mark100 Posted October 31, 2007 Posted October 31, 2007 "mosdt likely it only deletes the database entry cause the recording files are not present. please check." You were right. Windows couldn`t see my external hard drive for some reason. After restarting the harddrive, OSD ok plays again. Quote
Tjod Posted November 4, 2007 Posted November 4, 2007 Go in the Members Section > Input plugins there is the Technotrend Remote Plugin 1.1.1a. Quote
KARABAYA Posted November 5, 2007 Posted November 5, 2007 I can`t download probably it some bug . Can you sent that file on my e-mail? Thank you Quote
hackbart Posted November 5, 2007 Posted November 5, 2007 Usually we dont do this, but drop me an email Christian Quote
