Benarty Posted August 18, 2008 Posted August 18, 2008 If i understand it wight this should help you.Replace the existing dialogYesNo.xml with this one. dialogYesNo.zip no...I repeated the situation. So started a recording by pressing the record button on the remote control. I verify this with the channel list: rec filter is active. Then I exit DVBViewer and the warning appears that a recording is busy. I keep pressing on the right button and the exit icon is selected but then the confirmation icon and then again the exit icon and so on an on. The ultimate goal is: no matter how long the key is pressed,: If the confirmation icon is avtive and press the right button on the remote, ok, it has to switch to the exit icon. But then stay there even if the 'user' presses the right key on the remote too long. Same for the other direction. From exit to confirmation, it should stay at confirmation . After copying the dialogYesNo over the existing one: still a run-over situation. Quote
MarkusK Posted August 18, 2008 Author Posted August 18, 2008 (edited) Try this. I hope, this solves your "problem". edit: Download removed, because the file now integrated in the skin. Edited September 30, 2008 by MarkusK Quote
Benarty Posted August 18, 2008 Posted August 18, 2008 YES, problem solved. Thanks alot MarkusK. Quote
zeflash Posted September 18, 2008 Posted September 18, 2008 (edited) Hi MarkusK, I really enjoy the fresh look of your skin! I have a question though, I feel 4 lines for the timeline view is just not enough, how do I change that to 5 or 6? Thanks for your work Edited September 18, 2008 by zeflash Quote
MarkusK Posted September 18, 2008 Author Posted September 18, 2008 I will do this today as an alternative screen for other users too. I'll post the file when it's ready. Quote
zeflash Posted September 18, 2008 Posted September 18, 2008 I will do this today as an alternative screen for other users too. I'll post the file when it's ready. Awesome, thank you so much for the fast answer Quote
MarkusK Posted September 18, 2008 Author Posted September 18, 2008 (edited) OK, here we go.... Copy "mytvguide.xml" to "...\DVBViewer\OSDSkins\concinnity 3D" and "timeline_slider.png" to "...\DVBViewer\OSDSkins\concinnity 3D\Images". That's it. Download removed, because it is integrated in main skin now. Edited September 29, 2008 by MarkusK Quote
zeflash Posted September 20, 2008 Posted September 20, 2008 OK, here we go.... Copy "mytvguide.xml" to "...\DVBViewer\OSDSkins\concinnity 3D" and "timeline_slider.png" to "...\DVBViewer\OSDSkins\concinnity 3D\Images". That's it. Excellent! thanks a lot! Now I know I'm being pushy, but would it be possible to display the channel number in from of each channel in the guide and the "now" screen? Something like this: (15) - CNN I tried to look at the xml files but I can't figure out how it works, I don't see any kind of #channelname in mytvguide, which is puzzling (I must be missing something). Quote
MarkusK Posted September 20, 2008 Author Posted September 20, 2008 No, as far as I know, this isn't possible. Sorry! Quote
MarkusK Posted September 29, 2008 Author Posted September 29, 2008 Updated english version is available now Quote
boulder2 Posted October 3, 2008 Posted October 3, 2008 Updated english version is available now This is probably the neatest looking skin. I have tooled around a bit to change the "één HD" (Belgian Flemish TV) logo from the VRT website to make it transparent. I 'll post it later, if anyone is interested. Does anyone have new logos for TVE internacional ? 2 Quote
MarkusK Posted October 3, 2008 Author Posted October 3, 2008 Yes, I have the logo. It will be integrated in the next update. In future, please post in the Logo Topic Quote
entrecour Posted October 4, 2008 Posted October 4, 2008 (edited) Markus, Thanks for the skin update. It's getting better and better! I noticed a couple of issues... There is German text in the HTPC carousel (htpcHome) - when you move the carousel around to Alarm you the other items on the screen are in German. In the main EPG view (spacebar) it is no longet possible to see the program description. I guess you took this away because of lack of room, however I found it to be a very good feature on this overview screen. Is there any chance you could sqeeze it back in (perhaps by removing the current time)? Edited October 4, 2008 by entrecour Quote
MarkusK Posted October 4, 2008 Author Posted October 4, 2008 OK, I will check this. Which EPG window do you mean? The Timeline window? Quote
entrecour Posted October 5, 2008 Posted October 5, 2008 Which EPG window do you mean? The Timeline window? Yes, it's called Timeline. Quote
MarkusK Posted October 6, 2008 Author Posted October 6, 2008 (edited) OK, I will integrate the old timeline window as an optional component in next update (tonight). Found the bug with german text and I will fix it. Edited October 6, 2008 by MarkusK Quote
MarkusK Posted October 6, 2008 Author Posted October 6, 2008 (edited) Uodated version is available now. I think, this is the final version until there are new features in the engine or something like that. See screenshots for changes. Edited October 6, 2008 by MarkusK Quote
entrecour Posted October 7, 2008 Posted October 7, 2008 (edited) Thanks for the update Markus. In the MiniEPG options (I have used #3) how can edit the myMiniEPG.xml to change the progress bar colour to be blue as in your MiniEPG preview screenshots? The colour for the progress bar at the moment is grey. Thanks. Edited October 7, 2008 by entrecour Quote
MarkusK Posted October 7, 2008 Author Posted October 7, 2008 (edited) Grr...my mistake. Open the myMiniEPG.xml with editor and search for "button_selected_left.png". Change the word "left" into "right" and save your changes. That's it. Edited October 7, 2008 by MarkusK Quote
entrecour Posted October 7, 2008 Posted October 7, 2008 Open the myMiniEPG.xml with editor and search for "button_selected_left.png". Change the word "left" into "right" and save your changes. Great - the fix works perfectly. Thanks! Quote
alvox Posted October 11, 2008 Posted October 11, 2008 The skin didn't work for me until i copied windowdef.xml file in the DVBViewer programmfolder (not a configuration as mentioned by author). Quote
MarkusK Posted October 11, 2008 Author Posted October 11, 2008 (edited) In usermode=0, your program folder is your configuration folder! In other usermodes, the configuration folder isn't located in the program folder. The installation instructions are correct. Edited October 11, 2008 by MarkusK Quote
entrecour Posted October 15, 2008 Posted October 15, 2008 Markus, A couple of additional requests... Is it possible to move the on screen icons (e.g. Mute, Recording) further up into the right hand corner? Also any chance of a version of the on screen icons without the text as currently they take up a lot of screen room? Thanks! Quote
MarkusK Posted October 15, 2008 Author Posted October 15, 2008 (edited) You can do this yourself. Open videoinfo.xml with editor and edit x and y (horizontal and vertical) position. If there are interested users in smaller status icons, I will create them... <description>Speed image</description> <type>Image</type> <id>17</id> <x>1110</x> <y>136</y> <width>200</width> <height>48</height> <texture>Dialog-Info.png</texture> </item> <item> <description>rec logo</description> <type>Image</type> <id>4</id> <x>1110</x> <y>194</y> <width>200</width> <height>48</height> <visible>false</visible> <texture>Recording-Info.png</texture> </item> <item> <description>default image</description> <type>Image</type> <id>23</id> <x>1110</x> <y>252</y> <width>200</width> <height>48</height> <texture>Mute-Info.png</texture> </item> <item> <description>pause image</description> <type>Image</type> <id>16</id> <x>1110</x> <y>78</y> <width>200</width> <height>48</height> <visible>false</visible> <texture>Pause-Info.png</texture> </item> Edited October 15, 2008 by MarkusK Quote
entrecour Posted October 16, 2008 Posted October 16, 2008 (edited) Great, I played around with the coordinates and it's just fine now. Put me down for the smaller on screen information logos - hopefully others will chime in also. Thanks again for your great support. Edited October 16, 2008 by entrecour Quote
MarkusK Posted October 16, 2008 Author Posted October 16, 2008 Try the Skineditor, it is easier than handle this things with editor. Quote
MarkusK Posted November 11, 2008 Author Posted November 11, 2008 (edited) A new version of the skin is available. Changes: There is now a DVD case as background for Video covers. Resolution of the covers should be 238x334 pixel rather aspect ratio 1,4:1 The MyPrograms Plugin is skinned too Bugfixes for control issues Aspect ratio patch for Mini TV in OSD for users, which have it set to "Auto" Edited November 11, 2008 by MarkusK Quote
remlap Posted November 27, 2008 Posted November 27, 2008 Hi, I have a weird one if I try to listen to BBC Radio Wales it shows BBC One Wales logo, can this be fixed in anyway? Cheers Quote
MarkusK Posted November 27, 2008 Author Posted November 27, 2008 This ist the wrong thread. Please post your logo problems here in future. Logoname has to be the same as the channelname in your channellist. Then it will be shown correctly in your OSD. Quote
avoidz Posted December 17, 2008 Posted December 17, 2008 I read about this skin in another thread. I'll have to check it out Quote
Zero7 Posted December 17, 2008 Posted December 17, 2008 (edited) I read about this skin in another thread. I'll have to check it out You've missed lot of fun You will love this skin and this skin has to be the default skin in DVBViewer. Thanks MarkusK for your efforts. Edited December 17, 2008 by Zero7 Quote
avoidz Posted December 18, 2008 Posted December 18, 2008 It's very nice, and a lot of effort has gone into it. I'm not a real fan of black with just about every UI (that "Vista" look); would be nice to have some variations. When you press Enter to bring up the channel info, the clock digits are a bit untidy as the seconds count along, too. Other than that, it's very good. But I would still keep the current OSD skin as the default and this one as an optional download. Quote
ZERS Posted December 29, 2008 Posted December 29, 2008 Hi, first of all this is a fantastic skins. Anyway, as I'm a newbie in DVBViewer I've got some questions : 1- Where do I put CDs and DVDs JPEGs so that the thumbnails are displayed in the OSD->HtpcMode->Videos (or music)? Today I've just got blaocks boxes without ny preview. 2- Is it possible to select more than one video files (music files as well) to be played in a row? It' very useful for kids toons... I want to select 5 or 6 toons and they will be played sequentialy. 3- I want to change the color of the record icon in the timeline that is displayed on the right bottom corner when a record is programmed. This icon is grey I want it to be red. What is the name of this bmp, png or jpeg file to amend ? Regards Quote
MarkusK Posted January 6, 2009 Author Posted January 6, 2009 (edited) @ZERS 1. You have to put the files in the same folder as your video/music are located. For videos, the filename has to be the same as the videofile. For music, use folder.jpg 2. Very easy: Select your file, then press the red button on your remote control (or F5 on your keyboard). This action adds the files to your playlist, then press the green button or F6 to jump to the list 3. The file is named "Record_epg.png" @avoidz It seems, that you haven't read the installation instructions. Here is explainded, how to solve this "problem"... Edited January 6, 2009 by MarkusK Quote
mlehtola Posted January 7, 2009 Posted January 7, 2009 Nice looking skin! Markus...how about writing a short manual about "OSD-skin editing/creating"? I tried OSD skin editor but for example I couldn't figure out how to make button work ...and I can write some Visual Basic :-/ DVBV should look more like Meedio(s)/XBMC, but I know that the developers have other things to do as well, so I could try myself... Quote
brutus Posted January 8, 2009 Posted January 8, 2009 Hi Great Skin, a few requests ? Is it possible to add also a blue-glow on dvd_case-S.png (same for music and pictures), it will be easier to find which folder is selected ? Is it also possible to zoom a little bit more on the selected folder ? Is it possible to add more icons on the video/music/picture overview (less space between icons, 3 rows, 10 icons/row) ? Regards Quote
ZERS Posted January 9, 2009 Posted January 9, 2009 @ZERS 1. You have to put the files in the same folder as your video/music are located. For videos, the filename has to be the same as the videofile. For music, use folder.jpg 2. Very easy: Select your file, then press the red button on your remote control (or F5 on your keyboard). This action adds the files to your playlist, then press the green button or F6 to jump to the list 3. The file is named "Record_epg.png" @avoidz It seems, that you haven't read the installation instructions. Here is explainded, how to solve this "problem"... Hi markus, tks for your reply. With regards to the playlist, I've noticed that I've to press FFDW to jump to the next video be played. Otherwise, nothing os played. Are there any options to avoid thos? Regards Quote
MarkusK Posted January 9, 2009 Author Posted January 9, 2009 @brutus 1. I will see, waht I can do with the glow... 2. AFAIK, more zoom isn't possible 3. This is possible, but then you haven't enough space for filename, title and so on. Therefore are the differnet views list, small icons and big icons. @ZERS Then, there's something wrong with your DVBV. On my machine, I haven't to do this, all files (music and video) are played automatically. Quote
byfly Posted January 9, 2009 Posted January 9, 2009 Hi and thanks for a exfellent skin! I'd like to make the Timeline more simpler. I don't want the genre labels on the programs. Like in the preview pictures in the first post in this thread. ProSieben & Kabel eins don't have any genres on them like Vox & RTL2 have. I tried to edit mytvguide.xml, but didn't know what to excatly delete. Is this possible anyway? Thanks! Quote
