Zazza Posted April 29, 2009 Posted April 29, 2009 Re download guys I have repaired it. It does work now I have tested it. I'm starting to think I'm missing something. I can't see any channel in the channel list... Here's the log: 29/04/2009 19.26.56 : Welcome to "OpenEPG to DVBViewer converter" 29/04/2009 19.26.56 : ====================================== 29/04/2009 19.26.56 : Compiled by DJBlu 29/04/2009 19.26.56 : 29/04/2009 19.26.56 : Loading ... Please Wait 29/04/2009 19.26.56 : No Channels.xml file located. 29/04/2009 19.27.08 : Woke up, beginning Channel and EPG grab, set to grab 8 days of information 29/04/2009 19.27.08 : Removing unwanted Events 29/04/2009 19.27.08 : Deleted 0 events 29/04/2009 19.27.08 : Connected to Transport Stream 29/04/2009 19.27.08 : Searching Network Information 29/04/2009 19.27.17 : Got Network Infomation 65 transponders found 29/04/2009 19.27.17 : OpenEPG version is Sky Italia, Loading huffman tree 29/04/2009 19.27.17 : Hufman tree loaded 29/04/2009 19.27.17 : Searching for channels .. please wait 29/04/2009 19.27.50 : Channel grab complete, found 444 channels, this count will reduce as not all are used. 29/04/2009 19.27.50 : Starting EPG grab 29/04/2009 19.28.00 : Found 41652 new EPG Entries 29/04/2009 19.28.00 : Data Grab Complete 29/04/2009 19.28.00 : Inspecting Channels .. Please wait 29/04/2009 19.28.00 : Channel's scanned and loaded. 29/04/2009 19.28.00 : Adding channels to list 29/04/2009 19.28.00 : Add to list complete 29/04/2009 19.28.00 : Decoding Huffman encoded summaries .. please wait 29/04/2009 19.28.04 : Huffman Decode complete 29/04/2009 19.28.04 : Saving EPG and Channels ... please wait 29/04/2009 19.28.05 : Channels and EPG Saved 29/04/2009 19.28.05 : Exporting EPG Data to DVBViewer 29/04/2009 19.28.06 : Send to DVBViewer complete 29/04/2009 19.28.06 : Export to DVBViewer complete 29/04/2009 19.28.06 : All tasks complete, going to sleep Where am I doing wrong? Quote
DJBlu Posted April 29, 2009 Posted April 29, 2009 Right click and save as (your browser cache will have the old file) http://www.borntoshare.co.uk/downloads/click.php?id=3 Then extract to a folder. Make sure you delete the Channels.xml and EPG.xml files Then run the program. It will work m8. Quote
Zazza Posted April 29, 2009 Posted April 29, 2009 (edited) Right click and save as (your browser cache will have the old file) http://www.borntoshare.co.uk/downloads/click.php?id=3 Then extract to a folder. Make sure you delete the Channels.xml and EPG.xml files Then run the program. It will work m8. Hmm... I've alraedy done those steps more and more. I really dunno what to think and can't understand why the channel list is not created. Are there some kind of requirements for DVBViewer (aside from tuning to the right EPG channel)? I mean, could my DVBViewer channel list be the culprit? Edited April 29, 2009 by Zazza Quote
DJBlu Posted April 29, 2009 Posted April 29, 2009 Hmm... I've alraedy done those steps more and more. I really dunno what to think and can't understand why the channel list is not created.Are there some kind of requirements for DVBViewer (aside from tuning to the right EPG channel)? I mean, could my DVBViewer channel list be the culprit? It shouldn't matter. Have you set the region to "No Region"? Quote
Zazza Posted April 29, 2009 Posted April 29, 2009 It shouldn't matter. Have you set the region to "No Region"? Yep. I've always set "No Region". Quote
pietro.tiberi Posted April 30, 2009 Posted April 30, 2009 Yep. I've always set "No Region". It doesn't work...channels.xml is still empty!! what am i missing? do i need to specitfy DVBViewer folder location? (there is no place for this in the GUI!!!!) Are you shure you tested it? the staus bar say: 444 channels found.....but there are no channels !!! Please could you provide a working release? Thanks Quote
Tjod Posted April 30, 2009 Posted April 30, 2009 Which DVBViewer Version do you use? May be Open EPG to DVBViewer ues some functions which only exists in newer versions of the DVBViewer. Quote
DJBlu Posted April 30, 2009 Posted April 30, 2009 It doesn't work...channels.xml is still empty!! what am i missing? do i need to specitfy DVBViewer folder location? (there is no place for this in the GUI!!!!) Are you shure you tested it? the staus bar say: 444 channels found.....but there are no channels !!! Please could you provide a working release? Thanks Stop with the !!! I will help but u getting angry isn't going to speed me up. What Language do you use in the settings? German, Italian, French or English? What version of DVBViewer are you using? There is no need to specify the Folder as I took that out in the RC. Is the EPG.xml file empty too? Are you using Vista or XP? If vista do you have User Access Control enabled? Quote
dvbrewer Posted April 30, 2009 Posted April 30, 2009 Everyone who does not have this working, I take you have installed and correctly configured the Netstreaming plugin as Open EPG to DVBViewer will not work without this? This will work for me but I have to disable Kaspersky virus to download, unzip and run this programme- can anyone advise how I can stop Kaspersky trying to delete it? Quote
DJBlu Posted April 30, 2009 Posted April 30, 2009 Everyone who does not have this working, I take you have installed and correctly configured the Netstreaming plugin as Open EPG to DVBViewer will not work without this? This will work for me but I have to disable Kaspersky virus to download, unzip and run this programme- can anyone advise how I can stop Kaspersky trying to delete it? I will upload a version that will not get deleted. Quote
DJBlu Posted April 30, 2009 Posted April 30, 2009 I will upload a version that will not get deleted. Re-download the file, it should work. Quote
dvbrewer Posted April 30, 2009 Posted April 30, 2009 (edited) Re-download the file, it should work. Unfortunately Kaspersky still kills it . I tried to add the prog to the trusted zone but as soon as I even open the folder it will delete it as PE Patch virus? I can still workaround as long as I pause protection when I want to run it- only problem is when I do a full scan I will have to delete and redownload . Edited April 30, 2009 by dvbrewer Quote
Zazza Posted May 1, 2009 Posted May 1, 2009 (edited) Well DJ... Seems everything's working right now... I'll check it in the weekend and keep you informed if I'll encounter any problems. Meanwhile, thanks. Edited May 1, 2009 by Zazza Quote
deggesim Posted May 1, 2009 Posted May 1, 2009 I'm using DVBViewer 4.0 but I don't see any voice "netstream" in my plugin list. Moreover I don't see it in member section. So I cannot use this software to set up EPG. What am I missing? Quote
dvbrewer Posted May 1, 2009 Posted May 1, 2009 I'm using DVBViewer 4.0 but I don't see any voice "netstream" in my plugin list. Moreover I don't see it in member section. So I cannot use this software to set up EPG. What am I missing? I think it is an option when you install, so you need to run the installer again and tick netstream plugin. Quote
deggesim Posted May 2, 2009 Posted May 2, 2009 Ok, relaunched setup, installed netstream plugin, now everything works flawlessly! Congratulations to the author! Quote
pietro.tiberi Posted May 7, 2009 Posted May 7, 2009 Ok, relaunched setup, installed netstream plugin, now everything works flawlessly!Congratulations to the author! Now it works!!! Fantastic software tanks a lot!! Bye Quote
deggesim Posted May 10, 2009 Posted May 10, 2009 Mmmh, I have a problem: Huffman deconding does not end Here it is the log 10/05/2009 22.03.35 : Welcome to "OpenEPG to DVBViewer converter"10/05/2009 22.03.35 : ====================================== 10/05/2009 22.03.35 : Compiled by DJBlu 10/05/2009 22.03.35 : 10/05/2009 22.03.35 : Loading ... Please Wait 10/05/2009 22.03.35 : Found Channel file, Loading 10/05/2009 22.03.36 : Loaded 399 Channels 10/05/2009 22.03.36 : Found EPG File - Loading please wait .. This can take a few seconds 10/05/2009 22.03.37 : EPG File Loaded 10/05/2009 22.03.41 : Woke up, beginning Channel and EPG grab, set to grab 8 days of information 10/05/2009 22.03.41 : Removing unwanted Events 10/05/2009 22.03.41 : Deleted 187 events 10/05/2009 22.03.41 : Connected to Transport Stream 10/05/2009 22.03.41 : Searching Network Information 10/05/2009 22.03.51 : Got Network Infomation 65 transponders found 10/05/2009 22.03.51 : OpenEPG version is Sky Italia, Loading huffman tree 10/05/2009 22.03.51 : Hufman tree loaded 10/05/2009 22.03.51 : Searching for channels .. please wait 10/05/2009 22.04.24 : Channel grab complete, found 445 channels, this count will reduce as not all are used. 10/05/2009 22.04.24 : Starting EPG grab 10/05/2009 22.04.29 : Found 0 new EPG Entries 10/05/2009 22.04.29 : Data Grab Complete 10/05/2009 22.04.29 : Inspecting Channels .. Please wait 10/05/2009 22.04.29 : Channel's scanned and loaded. 10/05/2009 22.04.29 : Adding channels to list 10/05/2009 22.04.29 : Add to list complete 10/05/2009 22.04.29 : Decoding Huffman encoded summaries .. please wait Last week it worked well. I wanted to update my epg for upcoming week but it seems there is some issue. Any advice? Quote
DJBlu Posted May 11, 2009 Posted May 11, 2009 Mmmh, I have a problem: Huffman deconding does not endHere it is the log Last week it worked well. I wanted to update my epg for upcoming week but it seems there is some issue. Any advice? The easy fix for this is to delete the EPG.xml and then run the program. I think I have identified the problem so I will when I have time upload a fix. Quote
deggesim Posted May 11, 2009 Posted May 11, 2009 I had to delete also channel.xml to let it work again Quote
dvbrewer Posted June 7, 2009 Posted June 7, 2009 (edited) Here's a logopack I just put together for all UK FTA (Freesat, Freesatfromsky, Freeview) TV & radio channels- hope someone finds it useful . EDIT: just to add, if you have satellite, for BBC 1/One, BBC 2/Two and ITV1 you may need to change the filename of the logo to match your region, if you want more regions just make duplicates (copy & paste). The size of the UK logopack is 3.2MB. Edited June 7, 2009 by dvbrewer Quote
remlap Posted June 12, 2009 Posted June 12, 2009 Hi DJBlu, having problems currently saving my channels in OpenEPGtoDVBViewer right now I have to select them when I do my weekly grab. Cheers Quote
Rob100 Posted June 22, 2009 Posted June 22, 2009 Lars / DJBlu - has any progress been made on getting this to work through the recording service. I'm guessing that this was possibly a solution? http://www.DVBViewer.info/forum/index.php?...st&p=237094 Quote
themaster1 Posted December 11, 2009 Posted December 11, 2009 (edited) I'm in trouble with this plugin OpenEPgDVBViewer.exe I have set the netstream plugin like this: Active (Unicast) address ip: 127.0.0.1 (localhost) port: 2345 Stream control: stream whole transponder I tuned in to the channel IEPG data 1 and i can hear the audio (nothing on the other though: EPG Background Audio.) Then, when i run OpenEPgDVBViewer.exe , enter the ip 127.0.0.1 (localhost) port 2345 and try a 'Run Update" i get the following message: Error - DVBViewer NetStream IP and or Port not set, please correct Here is the log: 11/12/2009 17:42:52 : Loading ... Please Wait11/12/2009 17:42:53 : No IP Addresses found on this Machine, Is there a network card installed? 11/12/2009 17:42:53 : Language set to English 11/12/2009 17:43:03 : Woke up, beginning Channel and EPG grab, set to grab 8 days of information 11/12/2009 17:43:03 : Removing unwanted Events 11/12/2009 17:43:03 : Deleted 0 events 11/12/2009 17:43:03 : Error - DVBViewer NetStream IP and or Port not set, please correct 11/12/2009 17:43:03 : Will try again in 2 minutes 11/12/2009 17:43:08 : Removing unwanted Events 11/12/2009 17:43:09 : Deleted 0 events 11/12/2009 17:43:09 : Error - DVBViewer NetStream IP and or Port not set, please correct 11/12/2009 17:43:09 : Will try again in 2 minutes 11/12/2009 17:43:14 : Removing unwanted Events 11/12/2009 17:43:14 : Deleted 0 events 11/12/2009 17:43:14 : Error - DVBViewer NetStream IP and or Port not set, please correct 11/12/2009 17:43:14 : Will try again in 2 minutes Help required ! Edited December 11, 2009 by themaster1 Quote
uglyned Posted December 11, 2009 Author Posted December 11, 2009 (edited) Don't know if this is of any use to you but I could never get this working while recording service was running. Try stopping recording service if you have it installed. But then you have to change your hardware settings in DVBViewer. Then change them back after the update. Then start the recording service. Was all too much for me, especially as 99% of the channels I watch are on the Freesat EPG anyway. Has anyone got this working properly with the recording service? PS But it does look like you're tuning the wrong channel. You need the EPG Background Audio channel. Edited December 11, 2009 by uglyned Quote
themaster1 Posted December 11, 2009 Posted December 11, 2009 Don't know if this is of any use to you but I could never get this working while recording service was running. May i ask what is "recording service" ?? I don't see such option Quote
Tjod Posted December 11, 2009 Posted December 11, 2009 http://en.DVBViewer.tv/wiki/Category:DVBVi...cording_Service Quote
themaster1 Posted December 12, 2009 Posted December 12, 2009 (edited) My problem seems related to the NetStream plugin and not the "recording service" Which address do you use personnally ? Localhost (127.0.0.1)....or WHAT ? 12/12/2009 04:40:57 : Loading ... Please Wait 12/12/2009 04:40:58 : No IP Addresses found on this Machine, Is there a network card installed? Edited December 12, 2009 by themaster1 Quote
dvbrewer Posted December 12, 2009 Posted December 12, 2009 My problem seems related to the NetStream plugin and not the "recording service"Which address do you use personnally ? Localhost (127.0.0.1)....or WHAT ? 12/12/2009 04:40:57 : Loading ... Please Wait 12/12/2009 04:40:58 : No IP Addresses found on this Machine, Is there a network card installed? Did you select stream whole transponder in netstream > stream control? Make sure you make it active, then tune to EPG Background Audio on 11778V. In OpenEPG to DVBViewer in settings make sure 127.0.0.1 is in DVB Netstream IP Address, then click EPGViewer tab, click Run EPG Update . Quote
themaster1 Posted December 12, 2009 Posted December 12, 2009 That's exactly what i did but it won't work Quote
dvbrewer Posted December 13, 2009 Posted December 13, 2009 That's exactly what i did but it won't work Are you still tuning into IEPG data 1, if so that won't work. If you have settings input in both DVBViewer and OpenEPG and you make sure netstream is set to active (it won't work if you just configure), then maybe it could be your firewall interfering. I had my own problems running this on Windows 7, it seems it won't update unless I delete Channels.xml and EPG.xml each time. Quote
themaster1 Posted December 15, 2009 Posted December 15, 2009 I tune to the right channel & my firewall is disabled. Where is located epg.xml ? Quote
dvbrewer Posted December 15, 2009 Posted December 15, 2009 I tune to the right channel & my firewall is disabled.Where is located epg.xml ? In the folder where OpenEPGtoDVBViewer is located. Quote
buttonsNI. Posted December 15, 2009 Posted December 15, 2009 (edited) i found i too could not get this app to connect using the 127.0.0.1 unicast way my workaround is first stop the recording service then open the cmuv/DVBViewer folder and delete epg.dat also open the cmuv/DVBViewer/config folder and delete epg.dat there aswel then open DVBViewer and configure the tuner back to manual tune in EPG Background Audio. start Open EPG to DVBViewer configure with your ip address and port make sure netstream is configured the same then run Open EPG to DVBViewer updater when finished reconfigure your tuner back to unicast close the viewer go to cmuv/DVBViewer folder and copy the New epg.dat file into cmuv/DVBViewer/config folder restart your pc this will update the recording service web interface epg page but only for the channels that are your DVBViewer channel list this works but remember before each time you run Open EPG to DVBViewer you need to delete the Channels.xml and EPG.xml inside the Open EPG to DVBViewer directory good luck Edited December 15, 2009 by buttonsNI. Quote
themaster1 Posted December 15, 2009 Posted December 15, 2009 I found a better way to get the epg infos for Freesat chans see here This tutorial is in french though You need mc2xml and Xepg (also known as AutoImportXml) First you get the infos with mc2xml then you import them with Xepg I have uploaded the two apps [link removed, it is not allowed to distribute Xepg on other pages, set a link to the page from the author] Quote
packetstormer Posted January 6, 2010 Posted January 6, 2010 I am having trouble getting this to work. I turn on the NetStream plugin, set it to stream whole transponder, start the Update and the following appears in the log: 06/01/2010 20:13:43 : Welcome to "OpenEPG to DVBViewer converter" 06/01/2010 20:13:43 : ====================================== 06/01/2010 20:13:43 : Compiled by DJBlu 06/01/2010 20:13:43 : 06/01/2010 20:13:43 : Loading ... Please Wait 06/01/2010 20:13:43 : No Channels.xml file located. 06/01/2010 20:13:58 : Woke up, beginning Channel and EPG grab, set to grab 8 days of information 06/01/2010 20:13:59 : Removing unwanted Events 06/01/2010 20:13:59 : Deleted 0 events 06/01/2010 20:13:59 : Connected to Transport Stream 06/01/2010 20:13:59 : Searching Network Information It sits at this for hours, literally and nothing happens. Can anyone advise? Quote
packetstormer Posted January 7, 2010 Posted January 7, 2010 No, I should have said. I don't have the recording service enabled. Quote
dvbrewer Posted January 7, 2010 Posted January 7, 2010 It sits at this for hours, literally and nothing happens. Can anyone advise? You have to be tuned into the audio channel 'EPG Background Audio', also make sure net stream is set to active and you have set a network interface and port address which must also be input into OpenEPGtoDVBViewer. Also you must use the main DVBViewer, not the BETA. Quote
packetstormer Posted January 8, 2010 Posted January 8, 2010 You have to be tuned into the audio channel 'EPG Background Audio', also make sure net stream is set to active and you have set a network interface and port address which must also be input into OpenEPGtoDVBViewer. Also you must use the main DVBViewer, not the BETA. I have done all this, I should have mentioned this too. A connection won't even be made unless the background audio channel is open. From the log you can see it gets a connection but nothing more. Everything suggested in this whole thread I have tried . Is there any debug options? Quote
