MySeries - TV Series info OSD Plugin
amontillado
I've got a small problem with the manager. When I try to add a "season"(cover) manually and click "apply changes", "nothing saved" appears. Also I don't understand why it did not add it automatically because correct graphics are in seasons folder.
Thanks
  • 4 weeks later...
Everytime when I click on "download selected" (step 2) my myseries_manager stop working with no response.
Is this normal? should I wait? Or is this tool outdated at the moment?
I use version 0.02.25
Thanks for your help :-)
EDIT:
Ok its working but it takes some time.
No my next problem is, that my "mySeries" osd menu is empty.
How can I fix that?
Edited by Crypto90
  • 1 year later...
Is the download Server not available anymore. I can't get mySeries nor myMovies.
Maybe someone could upload it somewhere else?
can someone put new link here? cause this links is dead:
Download: myseries_0.02.24.zip [DVBViewer 4.5 and higher]
Download: myseries_0.02.25.zip [DVBViewer 4.5 and higher]
Thnx!
Same Problem here... i would appreciate if someone could uload the files to another server. Also the mymovies Link is broken.
Thank you :)
  • 3 months later...
Problem with the MySeries Manager.
I become a http/1.1 502 Error Message, when i search for a new series.
Example:
The Manager dont find the series with the name "Homeland".
Now i will search for it. When i press the button search i get the http 1.1 502 error message.
Something wrong with the query-String to http://www.thetvdb.com/ ? Does it change it ?
Regards
SkyDl
  • 4 weeks later...
I'm using DVBViewer 5.0 with MySeries 0.02.25 under Windows8 and everything is working fine - exept:
When I'm closing DVBViewer I get two errors and the DVBViewer Task does not close.
Application Error
Exception EAccessViolation in module MySeries.dll at 00006056.
Access violation at address 06846056 in module 'MySeries.dll. Read of
address 0A2E8458.
Problemsignatur:
  Problemereignisname:	APPCRASH
  Anwendungsname:	DVBViewer.exe
  Anwendungsversion:	5.0.0.0
  Anwendungszeitstempel:	2a425e19
  Fehlermodulname:	MySeries.dll
  Fehlermodulversion:	0.0.2.25
  Fehlermodulzeitstempel:	2a425e19
  Ausnahmecode:	c0000005
  Ausnahmeoffset:	00006056
  Betriebsystemversion:	6.2.9200.2.0.0.256.48
  Gebietsschema-ID:	1031
  Zusatzinformation 1:	6390
  Zusatzinformation 2:	63905d7798ed549caa838f360494a1b6
  Zusatzinformation 3:	cd7f
  Zusatzinformation 4:	cd7f8a266d8515c3fdefe49e01ce21c8
If some additional information can help solving the problem, just ask ;-)
  • 4 months later...
My OSD Menu is empty after downloading all stuff... whats going on here ?
Edited by FairyCosmo
Sorry i cant edit my post anymore so I write additional infos here:
DVBViewer 5.2
newest myseries version..
Skin: BluFuzz
  • 8 months later...
Hello,
today i used myseries for the first time. Now i have a few problems:
1. If i want to apply a changed season Picture i get the following message:
but when i click on episodes or series i can´t apply and the old season picture is back.
2. if ichange the episode picture the image can´t be applied.
3. is it possible to change information manually?
i use myseries_0.02.25.
thanks for help
