Guest Oliver Posted September 17, 2005 Posted September 17, 2005 It didn't function in the 3.2.1, too. A modification of the VRP is necessary. Quote
mitsu Posted September 17, 2005 Posted September 17, 2005 I had no problems with VRPlugin with 3.2.1. I have to go back to 3.2.1 because I really need VRPlugin. That is unfortunate because 3.2.3 seems to be far more stable with my Twinhan card. Griga: would be so nice if you had time to fix this problem. Please Quote
Griga Posted September 18, 2005 Author Posted September 18, 2005 It didn't function in the 3.2.1, too. A modification of the VRP is necessary Id did work with 3.2.1. I've checked it: DVBViewer Pro 3.2.3 does something chaotic on startup. First the VRP is enabled , then disabled again, for whatever reason not so easy to circumvent without killing the well-working communication with DVBViewer GE. Work-around for the moment: After having launched DVBViewer Pro 3.2.3, perform "Rebuild Graph", which enables the VRPlugin again. Yet another chapter of the long DVBViewer Pro/VRPlugin story, and I'm really fed up with it. Quote
mitsu Posted September 19, 2005 Posted September 19, 2005 Actually I need to rebuild graph after each channel change to enable VRP. This makes the timed recording challenging. A separate Pro version perhaps? Quote
Griga Posted September 19, 2005 Author Posted September 19, 2005 Actually I need to rebuild graph after each channel change DVBV 3.2.3 unnessecarily disables the VRPlugin on each transponder change. It can be enabled by tuning the same channel again, or another channel from the same transponder. However, I've found a work-around that seems to work (at least until the next DVBV Pro release ). Before uploading it I'll let the beta testers check it. Quote
mitsu Posted September 20, 2005 Posted September 20, 2005 Sounds good, thanks. Looking forward for getting the update. Quote
TNT Posted November 3, 2005 Posted November 3, 2005 Hi guys, I have a minor problem and even I tried I did not manage to fix it myself - I use DVBV GE on AS2 and record (both DVBV Recorder and VR Plugin) into ts format. I can work with the recordings (demux etc.) but can't play them in TSPlayer - it was working for me up till some two three weeks ago but lately it only starts playing the audio and gives me the "MPEG TS/PS Player & Converter has encountered an error and needs to close..." message. I suspect there is some problem in decoders but I am very careful with these (basically I do not install anything I would not test on a backup system) and lately I only installed the CyberLink PowerDVD 5 player and Womble MPEG Video Wizard - which I used to have also in my previous installation (and have on the backup system too) of W XP SP2 where the TS Player was working with no problems. Do you please have any idea what to check? Quote
Griga Posted November 3, 2005 Author Posted November 3, 2005 Sorry, no idea. Are there settings which prevent this error from occuring? Different decoders, different renderer? Try to play a MPG or MP2 (audio) file with TSPlayer. Is the error related to TS/video only? AFAIK the Cyberlink decoder from PowerDVD 5 insists on using the Overlay Mixer 2. It may cause strange effects when trying to use a different renderer, but I've never encountered that kind of message. It does not originate from TSPlayer. Must be some component, that causes a severe error, so the only thing for Windows left to do is to close the whole app. Quote
TNT Posted November 3, 2005 Posted November 3, 2005 Ok, thanks for the hint... I usually do not use the Overlay Mixer, since sometimes it caused non fluent replay. Now I switched that on and voila - it works. Apparently the simplest solutions come last - for me that is... :-) Thank you, thank you, thank you! Quote
Griga Posted November 3, 2005 Author Posted November 3, 2005 I'd use the decoder from PowerDVD 6. It's much better and more flexible. You can get it from PowerDVD 6 trial. The decoder still works after the trial period has expired. Quote
TNT Posted November 7, 2005 Posted November 7, 2005 That sounds great, thank you! Just one minor question - the mentioned BDA support in DVBV GE 1.7 means it will work with other DVB-T card brands too or just more instances of TS (or Twinhan) cards? In any case it is excellent news, since I have been considering to add SS2 to my AS2 and if I get it right, the new version of DVBV GE should allow this, correct? Quote
Griga Posted November 7, 2005 Author Posted November 7, 2005 it will work with other DVB-T card brands ...if they provide a BDA driver. Successfully running with TerraTec Cinergy T2 here. Quote
Dvb-tv Posted October 17, 2006 Posted October 17, 2006 Last time i downloaded and tried TSPlayer i found it would not output .mpg to .ts format. Is this the same, if so so can it be made possible to do this, in an upcoming version. Quote
Griga Posted October 17, 2006 Author Posted October 17, 2006 Reconstructing the original TS from MPG ist not possible, because some of the information is lost. It would always be a kind of fake. However, you may use ProjectX for it. Quote
Dvb-tv Posted October 20, 2006 Posted October 20, 2006 Thanks Griga i have tried projectx in the past. But with everything nearly disabled, it was still fixing some things. I have a very old Dec dtt device that outputs .mpg files, it has no ts save option. It is not as good as the Nova-t bda devices. Though it serves as an extra tuner when it is occasionaly needed. It sometimes has video errors albeit not many or big ones. Then needing to edit the errors out, first needing to locate them in each mpg. For this task the files have to be in a ts format. I am presently evaluating hdtvpump with it's tsconverter utility. So far it seems to do everything that is needed, looks ok by fixing anything in each ts file, i have convert so far. I agree some information is always lost converting mpg to ts, i think it is the extra padding or other that is removed. Ts files having more of what is removed, making the ts format a more resiliant format. Which matbe why broadcasters use the ts format for broadcasting. Quote
Derrick Posted October 20, 2006 Posted October 20, 2006 making the ts format a more resiliant format. Which matbe why broadcasters use the ts format for broadcasting. ..and that's why the "t" in ts stands for Transport What you want is of no use. Afaik said Dec dtt card already drops the ts_packet_headers internally. There is no way to reconstruct the original ts_packets from mpeg PS. But only the original headers could tell you, where ts_packets have been dropped due to transmission errors. Try to fix the stream with excellent tools like pj.x Quote
Dvb-tv Posted October 20, 2006 Posted October 20, 2006 I tried with projectx, i could not get to turn of all its internal switches. It was still modifing the stream a little. Tsconverting that i'm using now is a good, the only program so far. Quote
ilhyfe Posted November 9, 2006 Posted November 9, 2006 I use TSPlayer to demux h264 streams, but the media player shows a different playtime after demuxing. E.x. a 3 Min video is suddenly 10 min long. How can I fix this? Quote
Griga Posted November 9, 2006 Author Posted November 9, 2006 I use TSPlayer to demux h264 streams, TSPlayer (the one from DVBViewer.com) doesn't provide demuxing. So what do you really do? Quote
oleg_s Posted November 11, 2006 Posted November 11, 2006 hello! i'm using tsplayer to play a video services from prerecorded ts files (the whole transponder). but tsplayer very offen cant see a video pid in some video services. in different files, recorded from one transponder, tsplayer cant recognize different video services. any ideas? Quote
hdv Posted November 11, 2006 Posted November 11, 2006 Hello oleg_s, look at this http://www.DVBViewer.com/forum/index.php?s...st&p=114488 Quote
Ludwig2 Posted February 16, 2007 Posted February 16, 2007 How can I get DVB-subtitles working in TS-Player, I'm using TS-format file but can not find any menu (like in DVBViewer) to get textning? Quote
Shomac Posted March 27, 2007 Posted March 27, 2007 Hi! Where are the members area? I cannot find it'. Sorry for my bad englesh Quote
Tjod Posted March 27, 2007 Posted March 27, 2007 Look here it is the place where you have downloaded DVBViewer Pro after you had bought it here. Quote
Sven Killig Posted April 5, 2007 Posted April 5, 2007 - Added: Output with two or more audio streams (TS and MPG) Works great thank you very much! I hope my donation to Greenpeace is in your interest. Quote
Griga Posted June 24, 2007 Author Posted June 24, 2007 The Videorecorder Plugin has been updated to version 3.4.4.2 in the members area, plugins section. There are only small adjustments in anticipation of changes in the DVBViewer channellist structure. People who still need this plugin are recommended to use the new version. 3.4.4.1 or earlier will not work correctly with future DVBViewer versions. Quote
harryharry Posted October 23, 2007 Posted October 23, 2007 Bug TsPlayer: .TS files with teletext and AC3 audio I do not manage to choose both a AC3 audio stream and show teletext at the same time. If I choose the teletext stream in TSPlayer I only get stereo sound. I can provide you with a clip from such a file if it is needed for testing. I use TsPlayer 1.8.3. Quote
Anders R Posted October 24, 2007 Posted October 24, 2007 (edited) Im running firedtv-c with conax ci module and a subscription card with DVBViewer 3.9.0.0. But i havent managed to get the viderecorder plugin to record a channel when viewing another one. I choose a channel from the channels tab which should be channels from the same transponder. If i try record in mpg format the recording won't start at all. But if i choose ts all seems fine. But when i open the recorded file with tsplayer it says "Cannot find valid video/audio streams" I started to dig in this and recorded the channel i was viewing and another one from the same transponder as a ts stream. Now i could open the file in ts player and saw that only the videotext was recorded from the channel i didn't watch. But the channel i watched when recording was all fine in the ts file. What is causing this problem? Edited October 24, 2007 by Anders R Quote
Griga Posted October 24, 2007 Author Posted October 24, 2007 Now i could open the file in ts player and saw that only the videotext was recorded from the channel i didn't watch. Videotext isn't encrypted, right? Seems only one channel can be decrypted at a time - maybe due to the Conax CA? Check it with DVBViewer Pro 3.9. Usually it is able to handle two or more recordings simultaneously resp. playback of a channel and recording of another channel from the same transponder without any plugin. Quote
Derrick Posted October 24, 2007 Posted October 24, 2007 Seems only one channel can be decrypted at a time - maybe due to the Conax CA? AFAIR multichannel descrambling has been abolished. It wasn't a big success after all.. ..so only one service/CI-module at a time. Quote
Anders R Posted October 24, 2007 Posted October 24, 2007 Videotext isn't encrypted, right? Seems only one channel can be decrypted at a time - maybe due to the Conax CA? Check it with DVBViewer Pro 3.9. Usually it is able to handle two or more recordings simultaneously resp. playback of a channel and recording of another channel from the same transponder without any plugin. Your right, videotext isn't encrypted. I tried without the plugin and only with DVBViewer and no luck there either. The ci i have is this one. http://www.technisat.de/index55d8.html?nav...Module,de,68-32 In the pid dump you can see this for the channel im viewing. x 4103 (0x1007) Video and for the channel im not viewing x 4102 (0x1006) ?$ Quote
Derrick Posted October 24, 2007 Posted October 24, 2007 ..you can keep on trying but it wont work Quote
Anders R Posted October 24, 2007 Posted October 24, 2007 ..you can keep on trying but it wont work I understand that now. Why was the multichannel descrambling abolished? Would been nice to have that. Did a search on the forum and found this. http://www.DVBViewer.info/forum/index.php?...st&p=139057 That old beta version would be nice to test and see if it works. Quote
reis Posted January 10, 2008 Posted January 10, 2008 (edited) Hi, I save my recordings to a NAS drive attached via gigabit ethernet. Cutting files with tsplayer from NAS to NAS only runs at very slow speed, i.e. it takes the real time length of the scene. Cutting files from NAS to a local drive runs at normal speed. Is that an intended behavior ? And is there a workaround ? Actually the network bandwith should allow a speed many times as high. Thx Reis Edited January 11, 2008 by reis Quote
Moses Posted January 11, 2008 Posted January 11, 2008 reading and writing to the same harddisc will always be slower than reading from one disc and writing to the other. Quote
reis Posted January 16, 2008 Posted January 16, 2008 (edited) reading and writing to the same harddisc will always be slower than reading from one disc and writing to the other. You were absolutely right. I took the chance to test it with another gigabit pc, which boosted the performace up to 5 movie seconds per second. It was the slow CPU in my NAS pc that resulted in such a poor performance (though it has gigabit). Sorry for that! EDIT: btw, i was talking about 1080-recordings from AnixeHD. Edited January 19, 2008 by reis Quote
Derrick Posted April 8, 2008 Posted April 8, 2008 (edited) Is it normal that TSPlayer 1.9.0.1 doesn't recognize AC3 in a TS with stream type 0x081 ? Same with DVBViewer GE (2.4.5). DVBViewer Pro (3.9.3.30) works ok. Either ac3 with 0x06 or 0x81 is accepted. Edited April 8, 2008 by Derrick Quote
Barry Chum Posted June 12, 2008 Posted June 12, 2008 Hi, I am new to DVBViewer. The main reason for me to buy DVBViewer is the program accept command line interface. CLI may not be very useful to a lot of users but I think this feature is also a reason for many buyers of DVBViewer. I basically need CLI for interaction with my self-developed scripts and programs. However, I am now stuck because I couldn't find a way to use scripts to transcode / convert the h264+ac3 .ts file that DVBViewer recorded to mp4 (either mpeg4 or h264 with aac). I searched here and on the Internet but with no luck. I then find this VRplugin and hope that can work with DVBViewer Pro / GE, but I failed to use the plugin to record mpg. The mpg file recorded is always 0 byte size. I am using the latest DVBViewer Pro / GE / and VRplugin. Does anybody have similar experience and help me? Thanks a lot. Barry Quote
