commando Posted June 26, 2012 Posted June 26, 2012 (edited) commando myMiniEPG myMiniEPG.rar -> OSDSkin/concinnity 3D miniepgvars.rar -> Plugins Regards from Serbia myMiniEPG.rar miniepgvars.rar Edited June 26, 2012 by commando Quote
cismondo Posted June 26, 2012 Posted June 26, 2012 Grafiken für SNR-Balken vergessen, bei 100% Platzproblem, Stereosymbol gequetscht, SNR geht bei mir nur bei DVB-C, nicht DVB-T, mal so auf die Schnelle gesehn....aber danke für die DLL und die Verfügbarkeit der Zusatzinfos. Greets cismondo Quote
cinergy Posted June 26, 2012 Posted June 26, 2012 Hätte auch gerne ein Symbol für laufende Aufnahme drin Quote
parabolin Posted June 27, 2012 Posted June 27, 2012 commando, it would be nice if you add to your files the images used by that myminiEPG, because many of them are not from concinnity package. Specially the ones used for the signal progress bar. I can find many of them on other OSD skins, but not that one and its background. Best regards Quote
commando Posted June 28, 2012 Author Posted June 28, 2012 (edited) MIX concinnity 3D myMiniEPG.xml + X-Skin Black Glass MOD http://letitbit.net/download/16828.183f2b40da696b2b52585912ca9c/X-Skin_concinnity_3D.rar.html http://euroshare.eu/file/13840369/x-skin_concinnity_3d.rar http://rapidshare.com/files/612382776/X-Skin_concinnity_3D.rar http://www.ziddu.com/download/19787448/X-Skinconcinnity3D.rar.html Edited June 28, 2012 by commando Quote
commando Posted June 30, 2012 Author Posted June 30, 2012 (edited) Final miniEPG http://euroshare.eu/file/13952451/miniepg-commando.rar http://www.ziddu.com/download/19803877/miniEPG-commando.rar.html Edited June 30, 2012 by commando Quote
Lukaldo Posted June 30, 2012 Posted June 30, 2012 NEW-epg2 Hi, I like this mod, but I don't have progress line and green and yellow circles before TV tittle (attachments nr.1) and when I push green or yellow button I see new menu where I don't have some texts (attachments nr.2) Could you fix it for me? You're doing a great job, thanks. 1 Quote
moris187 Posted February 9, 2013 Posted February 9, 2013 könnte jemand das auf deutsch übersetzen die anleitung damit es auch korrekt gemacht wird. mein englisch ist not so god. Quote
Tjod Posted February 9, 2013 Posted February 9, 2013 @moris187 Bring erst mal deine Installation in Ordnung bevor du irgendwas anderes anfängst. http://www.DVBViewer.tv/forum/topic/51760-osd-problem/page__pid__382056#entry382056 Quote
